2004 jeep liberty runs hot. changed the water pump, thermostat, and radiator. does not run hot all the time. ran all day yesterday fine. ran hot today in car line at school. any suggesions
1- The water level in the auxiliary deposit. 2- the ventilator, some one have in the center a viscosity licuit that become hard when the temperature increase, if not, the air flow slowly and the water increase the temperature. 3- the valve, this is locate in the return tube from the radiator to the motor, this one regulate the pass of water to maintain the temperature stable.
Suspect you have a loose clamp on a radiator hose or the oil change guy made something leak. There is a tool which is similar to a a bicycle pump in that it pressurizes the water system and your engine does not have to run or be hot to test. Some major auto parts stores may have a loaner.
Its going to stay hot and lose pressure until you fix the leak.
Firstly do not use the car, it is either the water pump or the thermostat, sounds like the thermostat as you said it showed no signs of overheating. check that first as that is the cheapest part. if it is the water pump then again this might cause it to suddenly bubble up as the water is not been sent through the rad to cool. that rumbbling noise is the hot water and air, this will blow the head gasket and would be very expensive to get fixed.
Finally and quite unlikely the radiator could be blocked, doubtful but again worth a check, I would go for the water pump though as you said the water is coming from the middle of the engine. do be aware though that water could have came from the water bottle where you put it in. So would suggest the thermostat again.
Need to know what caused the overheating, possible broken serpentine belt, thermostat, water pump, radiator, fan clutch, cooling fan motor. After motor has cooled down fill radiator with water till full, look make sure serpentine belt not broke, start engine run about 5 minutes, turn off, let sit 3 minutes, start engine look at temperture gauge is it over half way of gauge, Do you have a fan blade driven by water pump or electric fans?
