My bosch classix washing machine is not dispensing the fabric conditioner properly. Often the fabric conditioner is left in the dispenser unused, just now it went in with the washing powder. It has worked fine in the past. I am using the same wash. I have taken the tray out and cleaned it in case it is blocked. I am not sure what else could be wrong.
The water going in to the dispenser is blocked by sludge.
Remove the dipenser tray.
Look up inside the tray hole, at the 'roof' of the tray hole, and there are four holes (square on my machine) where the water flows in - in the middle of the 'roof'. These will be blocked with sludge. Try to poke them clear with a nylon tie or plastic coated wire - should go in a few inches.
It worked for me.
Posted on Oct 14, 2009
  • Washing Mach... Master
  • 744 Answers
Bosch classix washing machine This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Jul 30, 2013
Dispenser fabric softener slot
Fabric Softener Compartment Full Of Water - White Goods ... > ... > DIY Washing Machine Repair Help
Jul 9, 2013 - The small fabric conditioner compartment in the soap dispenser drawer has a plastic cap or tube at the back for the water to siphon up through. ... Make sure the washer is level front to back as well as side to side. .... If the washing machinehasn't been used since there's always the possibility that the plastic ...
The fabric softener part of my washing machine drawer keeps ... > Topics > Housekeeping
MumsnetAfter each wash, the fabric conditioner part of the drawer is f. ... The fabric softener part of my washing machine drawer keeps filling with water ... Stopped using thedispenser compartment for fab softener and instead did I separate ... see if that clears it up and also try cleaning behind the drawer in case there is a blockage.
Washing Machine ' Fabric Softener ' Problem ' Won't Empty
Jan 16, 2016 | Washing Machines
Fabric dispenser leaves water in dispenser after wash is done
Jul 9, 2013 - The small fabric conditioner compartment in the soap dispenser drawer has a ... filter at the bottom of my machine is also full of water after every wash my machine is Russell ... My washer flushes out the softener but then leaves the water at the end. ... When the wash cycle has finished the fabric conditioner ...
Bosch washing machine - electronic timer goes down to 1 minute remaining and stays there. Washing liquid has been drained from drawer, however, fabric softener is still there. We have resorted to stopping...
Check if drain filter is clear and drain pump is working properly. Also remove soap conditioner tray and check if you have black residue inside the soap/conditioner dispenser. Sometimes this can prevent water from entering the conditioner tray.
Oct 24, 2013 | Bosch Washing Machines
Where do you pour bleach
The detergent dispenser draw where you put in the detergent has 3 sections.The compartment on the far right is for soaking agents. The compartment on the far left is for wash and stain removers (like bleach). The middle compartment is for fabric softeners, fabric conditioners.
Apr 10, 2012 | Bosch Axxis WFL 2060 Front Load Washer
Fabric tray does not clear
Usually means soap dispensing drawer needs to be cleaned, as conditioner is dispensed by syphoning system, Take out soap detergent drawer, clean thoroughly in warm water, make sure drain hole in conditioner compartment is clear.
Nov 20, 2011 | Washing Machines
I have an Aqualux 1200 washer/dryer. After the wash cycle the fabric conditioner compartment of the tray is full of water and the fabric conditioner appears not to have been flushed into the machine
If the dispensers are in their proper spot it is normal for some water to be left in the fabric softener dispenser. When you add your softener add water to dilute it as some softeners are very thick and don't dissolve well especially in cold water
Nov 18, 2010 | Electrolux EW1200i Front Load Washer /...
Conditioner is staying in draw when water should be feeding into draw at end of cycle it is going into both other draws but not the conditiner one any ideas
Hi, welcome to Fixya. Immediately what comes to mind, actually two things. Fabric softner can often be too thick to dispense properly in front load dispenser's unless deluted half & half with water before adding. The other thing is this, it could be the water inlet hoses connected backwards, i.e. Hot going to cold and cold to hot at the washer, hence in the rinse cycle when cold water should enter the fabric softner chamber it doean't. Let me know what you find as I will look for your reply. Thanks for visitng "fixya". Please take a moment and rate this info accordingly but also let me know if you need further assistance. Good luck. Macmarkus :)
Jun 22, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Bosch Nexxt series washer - water in softener dispenser
Hi. Remove dispenser, and thouroughly clean.
This should solve problem. If problem persists, don't worry about it tomuch, as long as it takes the conditioner down that is the main thing.
Nov 23, 2008 | Bosch Nexxt 100 Series WFMC1001UC Front...
Front Load Washing Machine
Filling laundry detergent and/or additive
Dispenser I: (RIGHT SIDE)
Detergent for soaking agent.
Dispenser II: (LEFT SIDE)
Detergent for wash, stain remover.
Dispenser 2: (MIDDLE)
Cleaning product, e.g. fabric softener, fabric
conditioner (do not fill above the lower edge of the
insert 1).
Dec 29, 2007 | Washing Machines
Washing Machines Logo
256 people viewed this question
Top Washing Machines Experts
