Question about HP LaserJet 3015 All-In-One Printer
Problem 3501 printer
The printer says that there is no cartridge in the printer. We have re-installed the cartridge and put in a new one. Turned off an then on. No change. I would appreciate any help. Thanks
Power circuit problem
Posted on Aug 31, 2008
I have a kodak esp3200 series printer, I replaced both cartridges but it still prints blank sheets of paper. What does error 3501 mean
The Kodak Printhead has electrically failed. A new one can be purchased from Kodak.com support website...I think they are around $35 or so. Just remove cartridges, then you can 'pop out' the printhead to remove/replace.
Mar 16, 2014 | Kodak ESP Office Equipment & Supplies
Will not print after changing ink cartridges
Defective cart or not genuine cart. Also be sure cart is installed properly, take it out and put back and listen for the click.
Jan 27, 2014 | Epson WorkForce WF-2540 All-in-One Inkjet...
On the Kodak ESP 5200 series what does a 3501 error mean? can it be fixed by a user? will new cartridges fix the problem?
Hi!
The 3501 error code means "acces door open"
Please be sure that the printer's acces door is well closed.
If this doesn't fix the problem, please do the following:
1. Turn the printer off by pressing the on/off button
2. Unplug the power cord
3. wait for 1 minute
4. plug the power cord back in
5. turn the printer on
Hope it helped.
Regards,
Bogdan
Aug 20, 2011 | Kodak EASYSHARE 5300 All-In-One InkJet...
I not only recieved the error 3501 but the top of the page only come out clear the rest fades, although i inserted new ink cartridges tonight. Why?
Hi crromeo,
Error 3501 indicates a hardware error. The only way to fix it is to it repaired if it's out of warranty or replaced if it's in-warranty. Bring it to a Kodak Service Center.
Feb 23, 2011 | Kodak EASYSHARE 5300 All-In-One InkJet...
TURNED ON THE PRINTER---UP CAME ( CARTRIDGE
please put on the printer, open the lid, the ink tray will slide out, kindly replace as you remove, and ensure you have the recommended inks,
regards
Apr 27, 2010 | HP Officejet 5610 All-In-One InkJet...
Errors on my Kodak ESP 3250
error 3501: STATUS_ERROR_UNIT_OPENED_WHEN_IDLE. You probably had it open when you inserted your cartridges.
Error 3502: STATUS_ERROR_MAIN_PAPER_TRAY_EMPTY. You must have inserted some shortly after you turned the printer on for the first time so don't worry.
Error 3609: STATUS_ERROR_UNIT_OPEN_WHILE_PRINTING. This is also another basic function on the printer.
I would recommend not looking at the errors on a printer test page as they show all errors that come up on the printer, even if they are not important.
Apr 08, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak easyshare printer 5300 error code3501
3501 error code indicates that the printer access door is open(The door that you open to able to see the ink cartridges).
If you recieved this error code and yet printer access door is open try to reopen it and close it, then unplug the power cable of your printer for 10sec then Plug the power cable back.
You cannot do any task on your printer if you have this message 3501. if this isue not solve call kodak tech support toll free 1 800 421 6699
Nov 07, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Cannot print true color.
How do I resolve the error message "Calibration Page Not Found"? Error code: 3610 Question : How do I resolve the error message "Calibration Page Not Found"?
Answer : To resolve this error condition, correctly position a calibration page on the scanner. See the User's Guide for more information. How do I resolve the error message "Cover open"? error code : 3501 Question : How do I resolve the error message "Cover open"? Answer : To resolve this error condition, close the access door. The printer will not operate while the door is open. How do I resolve the error message "Color ink cartridge missing or not installed correctly"? Error Codes : 3511 Question :
Answer :
To resolve this error condition, reinstall the ink cartridge:
  1. Remove the color ink cartridge:
    1. Open the printer access door by lifting from the front center of the unit.
    2. Wait until the printhead is idle and silent, then pinch the latch on the color ink cartridge with your thumb and forefinger and lift it out of the printhead.
  2. Check the two electrical contacts on the ink cartridge for small marks, which should appear if the cartridge was installed correctly.
    If the electrical contacts do not have small marks:
    1. Reinstall the ink cartridge, making sure you press down on it until it clicks into position.
    2. Remove the color ink cartridge, then check the two electrical contacts on the ink cartridge again for small marks. Repeat if necessary.
    3. Reinstall the ink cartridge.
  3. Close the printer access door.
NOTE: See the User's Guide for more information about removing and installing the ink cartridge.
If the error persists:
  1. In the KODAK All-in-One Home Center, select the Help (?) icon.
  2. Select Maintenance.
  3. Select Firmware Upgrade, then follow the prompts to download the latest version of firmware, free of charge.
From Kodak support:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=9104/7269&pq-locale=en_US
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 11, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
HP LaserJet 3015 All-In-One Printer Logo
Seeker5211
Seeker5211
