My fan on my furnace continues to blow even after it is cut off. What could cause this, something in the box is blinking
    Problem Solver:
  • 9 Answers
This evidently is a newer furnace with a circuit board in it. Count the number of blinks. Somewhere on the blower motor door is a place that will tell you what the blinks mean. Get back with me when you read what the number of blinks means. If you can find the instructions on the door, you can probably find it in the furnace instructions.
Posted on Apr 09, 2011
Furnace starts and ignites and fan comes on but when thermostat is turned off the gas shuts off and flame off but furnace continues to run. whu?? any suggestions?
The fan normally runs for a few minutes or so after the gas shuts off.
This removes the heat from the furnace and transfers it into the living space instead of just letting it possibly cause overheating of the furnace until it dissipates. If it is a fan that blows outside, that fan also needs to run for a few minutes to clear exhaust gasses from the furnace - to keep them from dissipating into your home.
Sep 28, 2015 | Heating & Cooling
I have a evcon EB12B where is the reset button. The blower stays on even if heater is turned off at thermostat. I have to turn off in breaker box
This may need the furnace technician to repair.
I can locate the manual for your heater and the parts list but I cannot locate any reset button.
Blowers that run all the time have either a stuck fan relay or depending on age, have either a defective "fan control and limit switch" or a breaker that operates the fan. When the furnace ignites the fan waits until the air get hot before it blows. When the heat goes off, the fan continues to run until the furnace is cool.
You probably can replace the parts yourself but please make sure it runs safely. The making sure is what the furnace tech will do.
Apr 18, 2015 | Heating & Cooling
My furnace fires up run for about five minutes then fire box shuts off and the fan runs until my furnace runs through its cycles but the fan runs almost continually runs it only shuts done for a few...
On a conventional furnace of today, your furnace may have a flame sensor which is typically located in front of an end burner opposite the ignitor. It is connected by 1 wire. This metal rod needs to be removed by 1/4'' screw in most cases and cleaned. Clean with steel wool or even a clean greenie scrubber will work. Wipe clean and re install. Many problems can cause these symptoms, but this is a very common one.
Mar 02, 2015 | Heating & Cooling
After preheat the fan cuts in for 10 sec then cuts out, cuts in for 15 sec, then cuts out. this continues to longer interviles. I have replaced computer box twice and have spent hundreds and problem
Try Googling the problem. Who have you paid so far, someone from the gas company, or a private technician? Was the technician from an Intertherm dealer? I would think a dealer would have qualified techs.
Nov 26, 2013 | Intertherm 56000 Btu Gas Furnace
I have a new Salem travel trailer with Dometic products. Everything appears to work fine, but when I run my furnace and it turns on, my fan blows from my AC unit. I have owned 2 other RV's but...
Yes it sure does sound like something may be wired wrong, Could you please reply with model number of your AC unit as well as thermostat model? To find your AC unit model number if you don't already have it, remove your ceiling air filter assembly, and it should be on the base of the roof unit, facing you.
The base of the roof (upper) unit will have a model and serial number, and if you see a control box where all the wiring attaches as well, get model number from that too if you will. Those numbers should make it easier to determine exactly where the problem is. Thanks.
May 28, 2011 | Dometic Rooftop RV Air Conditioner
Furnace blower runs continuously but no heat
sounds like the furnace control (low voltage) circuit is open, or in other words you either have a fuse blown or a limit switch that needs to be reset. Most newer furnaces have a small knife like fuse, usually 3 or 5 amp located directly on the circuit board. Limit switches that have a manual reset are usually located in the fire box just above the burner. There may even be a limit switch located on the blower assembly. If you fuse was blown, you may need to find out what caused the short in the circuit or it will do it again. If the limit switch was tripped, you need to turn the furnace back on and watch the flame to see if there is "roll out". It it continues to trip or blow fuses you need to have the unit serviced.
Apr 10, 2011 | Dayton Gas Furnace Heater
Gas furnace cycles on and off every 2-3 mins. then the gas cuts off and the fan keeps blowing until the power is cut off. The led light blinks twice.Any ideas?
check out your fan control could be dusty at the back remove it and clean it also check air fiter is clean , or tthe fan conrtol could need replacing
Dec 03, 2010 | Honeywell Programmable Thermostat Heater
We have a White-Rodgers 1F80-51. The fan blows
Usually when the furnace blower motor runs all the time
The limit switch or rollout switch is usually open or bad.
The furnace board is seeing that one of those switches is open, so it brings the blower on to try to get the heat out of the combustion chamber area, so the switch will close. But if the switch is bad and won’t close, the furnace board will keep the blower running continuously.
May 31, 2010 | Heating & Cooling
Induced Draft Blower Not Blowing- 3 Blinks on LED
Your doing well just right. When the call for heat is on the draft motor gets a call from the board to come on. When this happens if no voltage is present at the motor then you ahve abad baord. Replace it.
Nov 28, 2009 | Heating & Cooling
Heating & Cooling Logo
35 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
