Question about Whirlpool ED2SHAXM Side by Side Refrigerator
Water filter The change filter light is on but we can't find the filter. Where would it be locator on our model? Our mod # ED2SHAXMB10 and the ser # is SS3639497.
    Novelist:
  • 116 Answers
If you look on the toekick on the lower left hand side you should see a circular tab that is about 2 inches in diameter. This is your filter cover if you turn it 90 degrees counter clockwise your filter will release(if there is one installed)
Posted on Aug 06, 2008
SOURCE:
WHIRLPOOL REFRIGERATOR MODEL ED2SHAXMB10 ICE MAKER NOT WORKING
Here is the ice maker service manual for that unit. Go to the trouble shooting section and check the test points. Post back the results.
Jan 19, 2013 | Whirlpool Refrigerators
I can't find the wiring diagram for my whirlpool refridgerator.... MOD.#ET19RKXFN01 SER.#EG3222178. Can you please help. I need to change the defrost timer.....Thanks
I will try to locate a wiring diagram for your model ET19RKXFN01 but to change the defrost timer you will only need to know its location. Here is a link to the repair parts=> ET19RKXFN01_Repair_Parts_List
Go to page 5 of the repair parts list and you will see item number 4 Then on page 6 of the parts list you will see the timer part number beside the item 4. That is your defrost timer part number 2193084 Defrost Timer
Your refrigerator is an older model and may have the wiring digram in a packet behind the kick plate in the front near floor. Changing the defrost timer will not require use of a wiring diagram. Simply remove the old timer and replace the new defrost timer by plugging it into the wiring harness. The defrost timer can be found behind the control panel inside the fresh food compartment where the controls are located above the top shelf. If you have questions just let me know, Thanks Sea Breeze
Nov 30, 2012 | Whirlpool Refrigerators
No heat where is heater in kenmore mod.110.c66542500 ser.m53701943
I can't locate that model number..please recheck..most elements are located behind back panel, however, some are under front..there is a kickplate on some models on the lower front that comes off...it could be anything from a bad thermostat to low voltage causing this no heat.
Feb 08, 2011 | Dryers
Hi, In my refrigrator there is no water and ice coming.and i dont find where is the fiter.my refrigrator type is 2255a mod # ed2choxkb07 ser,# issu4235315.thanks
Since you did not provide a model number this is the best guess. On 25 Cu Ft and above models no matter the manufacturer most of the filters are in the left portion of the grille at floor level. You turn the tab and the filter pops free. If yours is not in this are just respond here with a model number and I will help you.
Kelly
Oct 03, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Looking for refrigerator use and care guide for mod.ed2vhextbo1 ser.hrt4930458 and info about changing filter and type of filter
i do not think that is a good model serial number. at least not the format that whirlpool has used in several years or in the u.s.a.
the model serial numbers should be on a tag easily located with out moving unit.
unless this is a vendared product with a Whirlpool name on it (usually a dorm frig or the like)
May 15, 2008 | Whirlpool Refrigerators
Water Filter Indicator
I discovered by sheer luck that if I hold down the OK button for a few seconds the filter indicator changed from the flashing 1% to 99%.
Aug 01, 2007 | Whirlpool S20DRSS33 Side by Side...
Whirlpool ED2SHAXM Side by Side Refrigerator Logo
169 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Bruce Denton
Steve Allison
Steve Allison
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
