Question about Facebook Social Network
Why am i getting syntax error on my facebook i can not open my page
Go into tools, Delete Browsing History and delete temporary Internet Files. This usually fixes it.
Posted on Apr 09, 2011
Cannot view my own website. it reads: "Parse error: syntax error, unexpected $end..." in my index.php file. HELP
Syntax errors are the most common problem for developers. A single syntax error can cripple even the best applications and websites. You can correct syntax errors easily once you find them. Typical errors include missing commas, semicolons and parenthesis. Debuggers are available in many software development kits to aid you in the location of syntax errors. However, you can find and correct syntax errors manually as well. Learning how to correct syntax errors is an essential part of being a software developer.
Locate the syntax error manually. Step through each section of your code. Most code will be sectioned off into groups or functions. Carefully proof your code. Be sure to pay close attention to how lines are grouped. A common syntax mistake is incorrect grouping.
For instance, if you have an If Else statement embedded in another If Else statement, be sure the embedded statement is surrounded by a separate set of parenthesis or brackets, depending on your language. Double-check notes sections. Notes are only for the developer to see. However, if the syntax isn't correct, the notes may become part of your application, which may not agree with existing code. Ensure the syntax around your notes is correct. Run a debugger if possible. This will make locating errors much easier. A debugger will be found under a menu such as Debug, Run or Tools or as part of your SDK's toolbar. Allow the debugger to run. Errors will be listed at the bottom or right side of your screen. Many debuggers will highlight possible errors in your code as well. A line number, along with the possible error, will be listed in the error message. Locate your syntax error if the debugger isn't correct. Sometimes a debugger will show you where your application stopped working correctly. The syntax error itself may be above or below the line listed in the debugger message. Check all syntax within the surrounding area, especially within the line's function. Run your application after correcting the syntax error. Check every possible function of your application to ensure it works correctly. If you find a problem, double-check the syntax in your code that surrounds the problem area. For instance, if your application has a log-in screen that isn't accepting passwords correctly, check the code for the log-in screen. Remove Syntax Error syntax error typically occurs when the Web page you are loading causes a script error in the browser. This is caused by incorrect code that displays an error message or results in a Web page that does not load correctly. You can remove a syntax error by making a change to the settings of your Web browser. Common Web browsers that can experience this type of error include Internet Explorer, Mozilla Firefox and Safari.
Double-click the "Internet Explorer" icon to open the program. Click the "Tools" drop-down menu and select "Internet Options." This will display the Internet Options window. Go to the "Advanced" tab and scroll down to the "Browsing" section. Remove the check from the box for "Disable script debugging (Internet Explorer)," "Disable script debugging (Other)" and "Display a notification about every script error." Click the "Apply" button to save the changes. Click the "OK" button to close the Internet Options window. Close and restart the Internet Explorer browser for the changes you made to take effect. b> Mozilla Firefox b> Double-click the "Mozilla Firefox" icon to open the program. Type "about:config" into the address bar and press the "Enter" key. Type "dom.max_script_run_time" into the Filter text box and press the "Enter" key. Double-click "dom.max_script_run_time" to display the Enter Integer Value dialog box. Enter a value of "10" or "15" into the text box and click the "OK" button to save the change. Close and then restart the Firefox browser for the change to take effect. b> Safari b> Click the "Safari" icon to open the Web browser. Select the option for "Preferences" from the menu bar. Go to the Advanced tab and click the option for "Show Develop menu in menu bar." Click the option for "Develop" from the menu bar. Click the option for "Disable Runaway JavaScript Timer." Close and re-open the browser for the change to take effect.
b>
b>
Apr 06, 2013 | Computers & Internet
I keep getting a box on my screen every time i try to do anything. it says EvalInsandbox:SyntaxError:syntaxerror
Correct a Syntax Error Syntax errors are the most common problem for developers. A single syntax error can cripple even the best applications and websites. You can correct syntax errors easily once you find them. Typical errors include missing commas, semicolons and parenthesis. Debuggers are available in many software development kits to aid you in the location of syntax errors. However, you can find and correct syntax errors manually as well. Learning how to correct syntax errors is an essential part of being a software developer.
Double-click the "Internet Explorer" icon to open the program. Click the "Tools" drop-down menu and select "Internet Options." This will display the Internet Options window. Go to the "Advanced" tab and scroll down to the "Browsing" section. Remove the check from the box for "Disable script debugging (Internet Explorer)," "Disable script debugging (Other)" and "Display a notification about every script error." Click the "Apply" button to save the changes. Click the "OK" button to close the Internet Options window. Close and restart the Internet Explorer browser for the changes you made to take effect. b> Mozilla Firefox b> Double-click the "Mozilla Firefox" icon to open the program. Type "about:config" into the address bar and press the "Enter" key. Type "dom.max_script_run_time" into the Filter text box and press the "Enter" key. Double-click "dom.max_script_run_time" to display the Enter Integer Value dialog box. Enter a value of "10" or "15" into the text box and click the "OK" button to save the change. Close and then restart the Firefox browser for the change to take effect. b> Safari b> Click the "Safari" icon to open the Web browser. Select the option for "Preferences" from the menu bar. Go to the Advanced tab and click the option for "Show Develop menu in menu bar." Click the option for "Develop" from the menu bar. Click the option for "Disable Runaway JavaScript Timer." Close and re-open the browser for the change to take effect. Hope this helps.
b>
b>
Dec 06, 2012 | Mozilla Firefox
1650en produces syntax error when printing
Have the DRAM and SRAM cleared. Will lose a lot of settings so make sure they are written down.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 21, 2012 | Konica Minolta MAGICOLR 1650EN COLOR LASER...
I GET ON FACEBOOK THEN I GO TO WSOP SITE CLICK TO PLAY AND NOTHING HAPPENS OR I GET A MESSAGE TELLING ME THERE IS A SYNTAX ERROR (12) . I DON'T HAVE A CLUE WHAT THAT MEANS. ANY HELP WOULD BE APPRECIATED
syntax error - an error of language resulting from code that does not conform to the syntax of the programming language; "syntax errors can be recognized at compilation time"; "a common syntax error is to omit a parenthesis"...
("syntax error" is a kind of...):
programming errorsoftware error (error resulting from bad code in some program involved in producing the erroneous result)
Apr 25, 2011 | Playdom WSOP Poker
For about 6 days now i havent been able to post comments open messages or comment on another profile i keep getting an error which is syntax eror es3_0_7n8B8.js please help thanks jessica
(.js) means for javascript.. try another pc.. if its still doesnt work, its only means that you were blocked by the facebook team. these are the causes of been blocked:
your adding unknown person
, flooding comment/message,
posting nude photos,
or you were report by other facebook user.
just send your report to facebook team to retrive your account.
hueverctk@yahoo.com.ph my facebook.
Feb 07, 2011 | Facebook Social Network
Syntax error on facebook
close your web browser and open it again. and log in.
Feb 06, 2011 | Facebook Social Network
Every time i log on it wont show my friends or i
It seems some scripts on that page did not run well. You can try to adjust some settings of your browser or try to disable some antivirus firewall. Or you can try another web browser. To see the detail of the error, you can double click on the icon of the error on the bottom of the page and see what is the description of the error and then maybe google it for an existing solution for that. If it is something like object error or syntax error, most of time it is about the setting and permission of the browser. You can reset the options of Internet Explorer by clicking on Tools menu and then Internet Options. Then on that dialog box opened, you can try to change the security setting to a lower level and restore the Advanced Settings, or try to add this site to your trusted sites, but adding it to the trusted sites does not always help.
Jul 22, 2010 | Facebook Computers & Internet
Problem loading Facebook. Page don't show up with graphics.
It isn't Facebook, it is Internet Explorer which Microsoft bundled within their operating system, this is why users of Facebook and Foxnews have repeated problems when using Internet Explorer and it seems the gap is too wide now for Microsoft to catch up. Any respectable programmer now uses Mozilla Firefox as their browser of choice because it allows for more robust applications such as used on Facebook and Foxnews. Microsoft will always be in a catch up of patches and downloads as browser technology continues to advance unless they complete redesign a new stand alone browser to take the place of I.E., but they cannot do that since I.E is tied to the operating system. What a nightmare and terrible decision made years ago by Microsoft which they curse to this day.
Apr 03, 2010 | Microsoft Internet Explorer 8
When using facebook I keep getting this message and a little yellow exclamation mark on bottom left of screen. Syntax error www.facebook.com Line 1 also Syntax error www.facebook.com Code:0...
try this.... go to tools>>>options>>>privacy>>>>(scroll down to) Accept all cookies ............. use google chrome instead of internet explorer if this doesnt work.....
Feb 10, 2010 | Microsoft Internet Explorer 8
Can you correct my error message? command line option SYNTAX ERROR I get this message when I try to open a pps file. I have Microsoft Power Point installed on the computer. Thea.
In computer science a syntax error ( IPA: /ˈsɪntæks ɛrə(ɹ)/ ) refers to an error in the syntax of a sequence of characters or tokens that is intended to be written in a particular programming language.
For compiled languages syntax errors occur strictly at compile-time. A program will not compile until all syntax errors are corrected. For interpreted languages however syntax errors cannot be detected until runtime and it is not necessarily simple to differentiate a syntax error from a semantic error.
A syntax error may also occur when an invalid equation is entered into a calculator. This can be caused, for instance, by opening brackets without closing them, or less commonly, entering several decimal points in one number.
copy and paste this link in your internet address bar for more information:
http://www.google.com/search?q=SYNTAX+ERROR&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a
feel free to ask any other questions
Oct 13, 2009 | Microsoft Windows Vista Home Premium with...
Facebook Social Network Logo
128 people viewed this question
Top Facebook Computers & Internet Experts
David Payne
David Payne
Are you a Facebook Computer and Internet Expert? Answer questions, earn points and help others
