Question about Dryers
Kenmore Dryer will not run unless you pull out slightly on the timer
  • Dryers Master
  • 8,220 Answers
Worn contact in the timer. Get ready to buy another timer.
Posted on Apr 09, 2011
Testimonial: "Awesome Thanks"
  • 1 more comment
  • Dan Webster
    Dan Webster Apr 09, 2011
    OR do an autopsy. Go in there and sand down the timer contacts. The secret is to remove the small shank ring around the stem so that the plate can be removed without disturbing the wheel. Then use a file to remove any burrs on the contacts.
  • topshelfcars Apr 09, 2011
    I took the timer apart and that is exactly the problem. I could see the burned residue on the plastic case.
    The cantact is 95% gone.Looks like I will be ordering a new timer tonight.
    Thanks alot for the advice!
  • Dan Webster
    Thank you
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
I have a Kenmore gas dryer model 97591220. wont
Disconnect power to the dryer and remove the screws attaching the console rear panel to the console and pull the panel off.
Inspect the wires connected to the timer and ensure a snug fit connection. Clean the connectors and terminals then reseat it several times to ward off dirt within the connectors.
Reconnect power to the dryer and start it; replace the timer (part number 3398195 ) if the dryer still won't stay running. Unplug the dryer and pull the timer knob off the console. Remove the screws securing the timer to the bracket and remove it. Secure the new timer in place then disconnect the wires from the old timer one at a time and connect it to the corresponding terminal on the new timer.
Push the timer back into position on the console and secure the console rear panel in place.
Apr 14, 2010 | Dryers
Dryer won't run unless I put pressure on the cycle control knob after pressing Start
sounds like you need to replace your timer, or either unplug the machine, an open the head panel an see if any wires are loose in there, changing the timer is an easy job, you should have no problems doing it ......good luck!
May 27, 2009 | Whirlpool LGR8648 Gas Dryer
Dryer heats timer advances however won't shut off
Timer replacement needed unless you can deal with it.
Jan 20, 2009 | Dryers
Kenmore gas dryer Model 110
hi. thanks for the question . i would replace the timer . the contacts Y and BU. Are welded together . replace the timer . thanks the appliance doc.
Aug 01, 2008 | Kenmore 74602 Gas Dryer
Dryers Logo
96 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
