Question about Kenwood KAC-5204 350 Watt Max Power Stereo Amplifier with Variable LPF
No power to sub.. redlight flashing on top of amp
  • 24 Answers
Put a meter across the speaker without disconnected and measure the impedance, it should show you the stated rating say like 4 ohms or 30 ohms. if it shows nothing then you have blown it up. If it shows you a dead short then its still blown up and probably burnt out and is shorting. Try very gently pushing in and out the cone with both hands 1 on each side if it is stiff then you have knocked it of center or burnt it out. if you get a reading with the meter and the cone has not frozen then try another speaker on the amp. if this fails they the sub on another amp. if this fails look for a reset button on the amp. you could try giving the amp a new signal that you know works finally if this fails then it looks like you have taken both of them out
Posted on Apr 09, 2011
Kenwoood kac-7202 redlight/no output
you blew the output Ic's (amps one or more ) you can fix this by replacing the output IC's
Jan 29, 2014 | Kenwood KAC-7202 Car Audio Amplifier
Ngv510 red light blinking
hello i was wondering if anybody can help me out here,recently my att unverse dsl nvg510 modem redlight (wifi setup ) is flashing red and sometimes flashing green. my internet is running good, all the device that connects to wifi is good also. and also i unplug the power for few minutes and plug it back in and still that redlight keeps on flashing. nobody can answer my question. thank you
Jul 29, 2012 | Arris Nvg510 At&t U-verse Modem Gateway...
Just hooked up mtx 500d mono amp and 12 inch sub worked for a 1/2 hour then sub quite and led on top of amp just flashes.
either ur ohm load is way off ur pos n neg might be touchin or more than likely u blew u sub is it scratchy when u push in the middle of the cone ? does it push in at all?
May 14, 2010 | Car Audio & Video
Your amp went in to power protect. You must adjust the settings on amp. This is usually very time consuming to get it right. Good Luck
Mar 24, 2010 | Car Audio & Video
Um the power light will flash then the protl. light will flash its all hooked up right but weird sounds coming out my subs.
Disconnect subs from output of amplifier and then turn on car and radio. Does amp stay on or go into protect? If it stays on then there is something wrong with the subs or how they are wired (series, parallel ) to the box and amp. If it still goes into protect then something internal with amp.
Feb 23, 2010 | Concept Car Audio & Video
How do i connect my pv2600amp to my peavey subs and top speakers, i have the leads but what do i do?
Line outs Left and Right from mixer to power amp Left and Right inputs,
Power amp outs to Subs(if they have passive crossovers built in check specs on subs).
From Subs then to Main spkrs. Make sure power amp is set in stereo mode using this way.
Alternative: You will need at least a 2-way stereo crossover unit inline after mixer and before power amps if the subs don't have a built in passive crossover. Most of them do have passive crossovers in the subs these days. Then separate amps or one channel would drive the subs and the other the main speakers. True stereo would require at least a 2 way crossover and two stereo power amps if hooking them up this way.
There is another option as is common with many sub setups. Send the signal to the mains using L/R outputs from mixer and a separate Mono output to the subs only. Putting only bass/kick and low frequency outputs in this send would help too.
Oct 13, 2009 | Peavey PRO-12 (00497070) Main / Stereo...
My Crunch Amp In My Blazer Has Stopped Working! Please Help!
NO if your amp is good any battery will turn it on. changing batterys does not require a reprogram?. id say amp is damaged from being wet. test to see if power is going in and out if nothing out bad amp..
Jun 01, 2009 | Crunch GP1100.2 GroundPounder 1100W 1/2...
??Confused and angry!
Try hooking an mp3 player or some other source into the amp (in place of your car stereo)while the car is running to test it. You may have damaged the output of the radio. If not report the results here.
Sep 12, 2007 | Jl Audio 250/1 Car Audio Amplifier
No Sound/ lights flashing on Amp
Disconnect your subs from the amp. If the lights go out then your sub is blown and is putting the amp into protect. If the lights keep flashing even with the subs disconnected than the Amp is toast.
Jul 09, 2007 | Sony XM-752EQX Car Audio Amplifier
Kenwood KAC-5204 350 Watt Max Power Stereo Amplifier with Variable LPF Logo
157 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
