Question about Bose Companion 2 Computer Speakers
My right speaker is making a fuzzy noise while my left one works perfectly. How do i fix the right one?
  • 27,725 Answers
Try swapping the speakers around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer
Posted on Apr 09, 2011
Left front speaker channel not working
Check that the green plug is properly inserted or it is not bent
Dec 09, 2014 | Pioneer VSX-D307 Receiver
Bose acoustimass 3 left channel fuzzy
Being Bose, the service department will require the unit back for service.
Jun 14, 2017 | Bose Audio Players & Recorders
2011 GMS Sierra 1500 Sound / speakers / blinker
on all modern gm vehicles , the blinker noise and dining noise goes through the left frt speaker so if you speakers arent workin thats your problem call a dealer with your vin
Oct 24, 2012 | 2011 GMC Sierra 1500
Fuzzy sound
Hi. Try moving it to a different room. If you have florescent lighting or too close to a fan or running electric motor. Check for bad ground on unit.
Make sure speakers are connected properly. + to + - to - left to left and right to right. Hope that helps.
Mar 09, 2012 | Audio Players & Recorders
My Logitech Z523 Speakers make a loud humming noise when plugged into my PC. When i plug it into my phone or laptop there is no humming noise. Sometimes there is a fuzzy crackling sound when it is not...
Mine did the same thing then I found the solution by accident. After reading a post about moving the sub to different positions and making sure connections were tight to the sub , I loosened the right speaker connection screws to the sub and noticed the humming stopped completely . I know it sounds crazy but it worked for me.
Nov 30, 2010 | Logitech Z523 2 Speakers
My Blaupunkt car radio produces noise to both left speakers
hi, you might have a wrong speaker wiring system, try to check for loose wires and fit them perfectly, hope this helps, have a nice day
Feb 09, 2010 | Car Audio & Video
No Sound From a Denon AV Amp
maybe your speaker are busted tyr to check it...the connection of the speakerwire sometime may be lose...or try check the wire to speaker by the tester, if had a rading continuity
Feb 29, 2008 | Audio Players & Recorders
Speaker problem
check for the connections! unplug and plug then back! test it! if it still have the same problem then it might be at the circuitry already! maybe some electronic components were busted or malfunctioned already!
if you happen to open it! check for bulged capacitors or loose connected components on the circuity!
Nov 15, 2007 | Altec Lansing ATP 3W Computer Speakers
Reception problem
Hello, Suse! One of my closest friends had the IDENTICAL system, and had to replace TWO transmitters before getting one that finally worked long-term. (A total of three - the original, plus the two replacements.) Before making the same assumption, however, there are two simple things to check: 1) Inspect the connection between your receiver and the WSP transmitter to make sure everything is secure. 2) IF you're using the speakers with batteries, try an AC adapter instead. Batteries - even brand new ones - aren't ideal for every application. There is NO QUESTION that the WSP system - at least, the one my friend uses - performs better when connected to AC power than it does when using batteries. Good luck!
Jul 17, 2007 | RCA WSP155 Main / Stereo Speaker
Bose Companion 2 Computer Speakers Logo
317 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
