Have a problem with brown pieces going through my washing,have cleaned the machine with white vinegar many time but problems still persists. Does the agitator come out mine doesn't seem to
    Problem Solver:
  • 9 Answers
Go to Home Depot and purchase "washing maching cleaner" and run it through with nothing in it at least twice. I think the cleaner costs about $8
Posted on Apr 09, 2011
Can you remove the drum from lg fuzzy logic WF-T65T1 to get rid of mouldy smell
It is a big job. Why did you use vinegar and bicarbonate of soda? They cancel each other out. The drum is stainless steel, it can't smell. The smell is from mold on the rubber pipes and in particular the door gasket.
Put 2 cups of bleach in the machine and a couple of white towels or a load of white tea towels. Run the hottest wash for the longest time.
After you do a wash, dry the door seal and leave the door open for a couple of hours so everything dries out..
If it persists, get an engineer to replace the door gasket. Then keep it clean and dry.
Dec 18, 2017 | LG Washing Machines
We have a LG He washing machine. It is 3 years old and get light use. Recently after each use the clothes are covered with brown soft specks How can we deep clean out machine?
hi David.
  1. Fill the washer using the highest load size, hottest water setting, and longest wash.
  2. Open the lid and as the washer tub fills, add a quart of white vinegar (or bleach). ...
  3. Next, add a cup of baking soda. ...
  4. Meanwhile, remove any parts you can and soak them and clean nooks and crannies under the lid.
More items...
How To Clean a Washing Machine ' Apartment Therapy
https://www.apartmenttherapy.com/how-to-clean-a-top-loading-washing-machine-apart...
How do you clean a front loading washing machine
Pour the vinegar into a measuring cup and head over to your washing machine.
  1. Add the baking soda mixture to the detergent container of your machine and pour the vinegar into the drum. ...
  2. Use a clean scrubber to rub around the opening of the washing machine, removing stubborn mold or residue.
how to deep clean washing machine Google Search
Dec 03, 2017 | LG Washing Machines
Kenmoore 600 washing machine. Clothes comes out with brown spots.
Are you on a well, or town water supply? If machine needs cleaning you could try running a load with just water and a bottle of CLR it is a cleaner for calcium, lime and rust I think, if it smells after that of the cleaner run a load with white vinegar in it with the water. hope it helps, good luck
Jul 03, 2017 | Washing Machines
I have a AWS45NW and we cannot get the grime from building up around the top rim. We cannot wash any light or white clothes as it leaves them with grim on them.
Sounds like soap residue buildup. Try cleaning the machine with very hot water and vinegar. Fill machine as full as it will go and pour in a gallon of white vinegar. Run thru longest cycle and you might have to scrub a little. Rinse with hot water a couple of times. Then switch detergents.
Oct 07, 2015 | Speed Queen Washing Machines
How to clean wash machine tub
with acetic or formic acid its clean the calk residu
Jun 28, 2014 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
How do I clean the washer to eliminate the dark spots of lint and dirt on laundry?
Prevent lint from clinging to clothes by adding 1/2 cup white distilled vinegar to the wash cycle.
To remove soap residue that makes black clothes look dull use white distilled vinegar in your final rinse.Get stained white socks and dingy dishcloths white again. Add 1 cup white distilled vinegar to a large pot of water, bring it to a rolling boil and drop in the articles. Let soak overnight. Some stains on clothing and linens can be soaked out using equal parts milk and white distilled vinegar.Before washing a mustard stain, dab with white distilled vinegar.ttack spaghetti, barbecue, or ketchup stains with a white distilled vinegar and water solution.Remove perspiration odor and stains on clothing, as well as those left by deodorants, by spraying full-strength white distilled vinegar on underarm and collar areas before tossing them into the washing machine.Forgot that you left wet laundry in the machine and it now smells moldy? Pour a few cups of white distilled vinegar in the machine and wash the clothes in hot water. Then run a normal cycle with detergent.Remove smoky odors from clothes by filling the bathtub with very hot water and 1 cup white distilled vinegar. Hang the garments above the steaming water and shut the door so the steam can penetrate the fibers.Keep the steam iron clean and in good working order by getting rid of mineral deposits in steam vents and spray nozzles. Fill the water chamber with a solution of equal parts white distilled vinegar and distilled water. Set it in an upright position and let it steam for about 5 minutes. When the iron is cool, rinse the tank with water, refill and shake water through the vents onto an old cloth. Test before using.Remove scorch marks from an iron by rubbing it with a warmed-up solution of equal parts white distilled vinegar and salt. If that doesn't work, use a cloth dampened with full-strength white distilled vinegar.Remove musky smells from cotton clothes by sprinkling them lightly with white distilled vinegar and then pressing them.Get water and salt stains off shoes and boots by wiping them down with a solution of equal parts white distilled vinegar and water.Give patent leather shoes and bags a better shine by wiping them down with white distilled vinegar.Get cleaner laundry! Add about 1/4 cup white distilled vinegar to the last rinse. The acid in white distilled vinegar is too mild to harm fabrics, yet strong enough to dissolve the alkalies in soaps and detergents. Besides removing soap, white distilled vinegar prevents yellowing, acts as a fabric softener and static cling reducer, and attacks mold and mildew.Eliminate manufacturing chemicals from new clothes by adding 1/2 cup white distilled vinegar to the water.Remove soap **** and clean the hoses of your washing machine with white distilled vinegar. Periodically run the machine with only a cup of white distilled vinegar in it-nothing else added to the wash cycle.Bring out bright colors by adding 1/2 cup white distilled vinegar to the rinse cycle.Fluff up wool or acrylic sweaters (hand- or machine-washed) and rid them of soap smell with 1/2 cup white distilled vinegar in the last rinse water.
Get rid of the tiny holes left along the hemline when you take out the hem of any garment by moistening a cloth with white distilled vinegar, placing it under the fabric and ironing.
Oct 31, 2011 | Whirlpool Washing Machines
A build up of brown slimy mould which marks clothes after washing. The door seal is stained brown in places and the brown slime is building up in the folds of the doo seal. What can I do?
try manualy cleaning the door seal with bleach and then amonia, ( NOT TOGETHER, ONE AT A TIME )
then pour some amonia into the machine and run it. amonia and/or vinegar work great to clean washing machines. but please note : this should be done seldomly as Amonia is a corrosive towards electrical parts.... hope this helps.
Oct 18, 2009 | Washing Machines
Hard scratchy towels. Have used all wash cycles, and use fabric softener
have you tried just white vinegar as your rinse aid. Do a full cycle of your washing machine using white vinegar instead of detergent, to clean any residue from pipes, and then in the next wash try white vinegar as your rinse aid.
Apr 18, 2009 | Bosch Nexxt 700 Series WFMC6401UC Front...
White wash contaminated with brown marks
drum bearings are leaking oil into the drum..they need replacing.
Mar 11, 2007 | Hotpoint Aquarius WMA52 Front Load Washer
Washing Machines Logo
111 people viewed this question
Top Washing Machines Experts
