Question about Brother Office Equipment & Supplies
Get a black strip when I try to copy or fax a paper. Able to receive a fax without problems. Replaced drum and cartridge and cleaned what I could see, but strip is still there.
  • 591 Answers
Sorry but the drum has nothing to do with the SCAN problem, only for PRINTING problems, if you have a BLACK STRIP when you scan, you must check the SCANNING lamp for obstruction (liquid paper contaminant) on the scanning window or for other debrie that prevent the scanner to scan properly is it a dual feed??? (flat bed or top load)???
Posted on Apr 09, 2011
Papers come out with black streeks on them from my sharp FO 4450
If everything is coming out with streaks, it's most likely your cleaning blade which is part of the drum cartridge. I've also seen this from 3rd party toner. Get Sharp toner for your Sharp fax if you don't have it already. If your black streaks are only on copies and sent faxes, this indicates that your scanner is dirty. It's located where you feed your paper in. Lift this part up and you'll see a strip of glass running front to back about 1/2 inch wide. Clean it and that will get rid of lines.
Oct 12, 2009 | Sharp FO-4400 Fax
Faded strip down length of paper
CLEAN DRUM UNIT AS PER MANUAL . IF THAT DOSN''T WORK TRY REPLACING DRUM AND/OR TONER
Aug 26, 2009 | Brother Office Equipment & Supplies
Black Vertical Lines
This can be caused by a damaged fuser or drum try to change the cartridge and if that does not resolved the issue then its the fuser
Mar 27, 2009 | Sharp FO DC500 Plain Paper Laser Fax
When received a fax, there is a black shade on one side of paper
Take out the toner cart and turn it upside down. Swing away the drum cover. The drum should be clean, if not replace the toner cartridge.
Jan 28, 2009 | Panasonic Panafax UF-890 Plain Paper Laser...
Black strip Mark on paper after print
Ramana is the black stripe just showing up on copies or faxes or does the stripe occur when you are printing from your computer. If the stripe only occurs when copying or faxing then more than likely the scanner glass is dirty. White out liquid on the scanner glass is a common.If it happens when printing fromyour pc, the problem will be in the toner cartridge or the fusing assembly.
Change the cartridge first to see if it goes away. Check the scanner glass, especially the small glass strip on the left side of the scanner or the right side where you place the original paper. These areas should be completely clear and clean of any scratches or smudges.
Last is the fusing assembly. If you tried everything else and theline continues to bother you, the fusing assembly sleve is probably torn. This would have to be replaced. The part number is RM1-0865-040CN.
Jun 23, 2008 | HP LaserJet 3030 All-In-One Printer
Poor quality fax to fax, copy great, computor fax great.
beware of generic toner!
you may need to change out your drum unit
the drum unit may have been contaminated by the staples toner.
also clean laser window under drum cartridge.
Mar 17, 2008 | Brother IntelliFAX 2800 Laser Fax
Brother Intellifax 2820 printing problems
If it is on copying it can be a build up of ink on the scanner glass. Open the cover in which the the original is scanned. There will be glass strip that can be cleaned also check the white plate that sits above the scan glass.
If it is recieved faxes and prints as well the problem is going to be the drum has worn out. You have two machines, try interchanging the drums to see if the lines that are present on one machine travels to the next. That way you can see if it is definately the drum. If so change the drums on the machines and they should be fixed.
Jan 31, 2008 | Brother IntelliFax-2820 Laser Fax
Fax not clear
Noisy phone line can cause this or it could be drum cartridge or even fuser, check phone line for noise by listening to it, if noisy report it or put on required filter if using ADSL.
Also test machine when doing a copy, and when printing a report, is there a problem too?
without more info you fault is one of these.. line, drum cartridge , fuser or dirty scan glass (where originals are fed.)
Nov 08, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
370 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
