Question about Karcher 2500 PSI Pressure Washer
Honda XP2600 - Leaks at tip connection
The tips all leak at the connection & they are in all the way.
  • 80 Answers
Try using a teflon tape before installing the hose.
Posted on Aug 07, 2008
Honda wave dash 110 is leaking gas out of the overflow hose
Hi, Ronnie and the usual suspects are:
1. Damaged or restricted fuel tank venting system.
2. Loose float bowl screws.
3. Damaged float bowl o-ring.
4. improper fuel level in the float bowl.
5. Worn or dirty inlet valve or seat.
6. Damaged or leaking float assembly.
7. Particle contamination in inlet fitting cavity.
8. Damaged petcock diaphragm allowing fuel to flow through the vacuum line into the combustion chamber.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
http://www.miniriders.com/carby-and-tuning/25015-fuel-leaking-out-overflow.html
Carburetor Carb Leaking Gas How to Fix Repair it Motorcycle Honda DIY...
http://www.family-motorsports.net/GY6-50cc-150cc.pdf
http://www.partsfish.com/page/oem-parts-for-honda
Oct 15, 2017 | Honda Motorcycles
How do i stop it from pulsing?
Getting to much air to carb probably.
Jul 11, 2015 | Karcher Garden
How do i replace the o-ring on the tip of bit 101 tip
with a new one of course . but lube it first with vasoline
Feb 22, 2015 | Garden
How to fix leaking reservoir
I believe that many have encountered small leaks in the cooling system, which end up becoming a nuisance both the "puddle" that it will make the floor of your garage as well as the verification according to the coolant level.
Many give up tips to eliminate this problem, for example, place egg whites into the radiator. This in an emergency situation can even "troubleshoot" but the problem is after the nice little "odor" produced by the egg.
Already exists on the market that act on the system eliminating small leaks. We will highlight this matter Veda Leaks Stop Leak Petroplus / STP
Product Features:
Not affect the components of the cooling system;
Does not cause blockages;
It can be used as a preventive product;
It can be used with other treatments to PETROPLUS cooling system.
The package has a StopLeak 350 ml, and must be added to one vial of the product to systems with 8 liters of liquid.
Tips and care: Whenever you open the reservoir cap radiator, make sure liquid is not overflowing. If this occurs, close the container again, start the car and let it run until the drive fan. When this switch off automatically, open the tank lid and carefully turn the engine off. If the leak persists, seek mechanical assistance.
Jul 02, 2014 | 1992 Honda Accord
Got a anest 400 and when I put paint in the pot it leaks from side of fluid tip tried another tip but still happens
Some have a white Teflon seal behind fluid tip often get lost in total clean up
Oct 10, 2013 | Cars & Trucks
When using the sweep nozzle (yellow tip), the pressure starts and stops but the machine works fine when using the circluar nozzle(red)
usually when the power washer pressure stops the machine is running out of water. the sweep function uses a little more water than the round wash tip. Make sure there are no leaks in the supply hose and that the supply faucet is turned on all the way and has plenty of "flow". also make sure the water connection at the washer is not leaking. use a new rubber washer to make a good seal on the supply hose on both ends. if either end leaks or can **** air, just a little bit of air into the pressure washer will cause it to loose pressure.
Apr 20, 2011 | Briggs & Stratton Briggs Stratton 1800...
Leaking at point of connection between tip and wand
There is a rubber o ring in a groove towards bottom of the snap in connector.This seals around the tip as you insert it. It will never seal without it. The ball bearings you mention are only to hold the tip in place. The sealing goes on down in the coupler
Jul 02, 2010 | Briggs & Stratton Briggs Stratton ORing...
Idle will not stay set where it should be
You have air leaks in the intake that are causing the bike to run lean and idle fast. Normally the leaks are in the rubber insulator connecting the carb and manifold. The rubber gets hard and cracks. Go to the site below where you can see a parts diagram for your specific bike. You will select the actual brand, year, model, etc., once you go to the site. Part numbers and prices are also shown. You can order parts from this site. In the event no price is shown on a particular part, the part is not in stock. www.babbittsonline.com/pages/parts/viewbybrandand/parts.aspx
A “very helpful” rating for this answer? Thanks!
Jun 13, 2009 | 1987 Honda CBR 600 F Hurricane
Dishwasher Leak
Here is a tip that I wrote about leaking dishwashers...
There also is a link in there to another tip on how to buy parts online for your dishwasher...
Leaking Dishwasher
http://www.fixya.com/support/r4546178-leaking_dishwasher
heatman101
Feb 27, 2009 | Frigidaire 24 in. PLD2850 Built-in...
Karcher 2500 PSI Pressure Washer Logo
104 people viewed this question
Top Karcher Garden Experts
John Trevino
Are you a Karcher Garden Expert? Answer questions, earn points and help others
