Thermostat temp increases to selected temperature and clicks but fan doesn't stop running
  • n15928 Apr 09, 2011
    How would I check the relay out. Do I need a multimeter? Continuity check?
    Robertshaw 9600
  • 1,420 Answers
If the system is less than 6 years old and if the thermostat is not set to "Fan", it may be telling you that there is an error code stored on a LED light on the control board. Look through a small viewing port on the heater near the bottom of the unit. Look for a blinking light. Now remove the front panel and look for a wiring diagram that will also have a diagnostic chart. Not knowing what you have for a system makes it harder to help you, if you could tell us the make and model, we can give you additional information.
Posted on Apr 09, 2011
    Guru:
  • 257 Answers
I understand that you are having a problem with your air conditioner system. The fan will not stop running when the thermostat reaches temperature. This is usually caused by the sensor in the thermostat that turn the fan on and off on automatic.
You can check you thermostat by doing the following.
1. Remove the cover on your thermostat.
2. Remove the wire attached to the contactor (screw) label G
3. If the fan turns off the thermostat is bad
4. If the fan does not shut off you have a bad fan relay or circuit board (do not know the model hard to tell which one it can be)
To replace the thermostat once you have purchased another one
1. Turn off breaker two the unit
2. Label all of the wire on your old thermostat
3. Mount your new thermostat
4. Replace the wires to the corresponding letters from the old thermostat
5. Turn unit on
6. Set temperature so that unit comes on (2 degrees cooler if in summer)
7. Wait for thermostat to reach temperature (usually 2 degrees higher or lower than set)
8. See if fan turns off
This should take care of your problem if it is the thermostat. If this does not work re-post to the thread and I will walk you threw so more trouble shooting steps. This is the first on you want to try.
Thank you for choosing FixYa.com
Justin
  • Justin Burnett
    Justin Burnett Apr 09, 2011
    Yes, you will need a multimeter to check the relay. Can you post the make and model of the unit that you have?
  • 5,370 Answers
If the fan is running non -stop then there is a short in wiring.The wiring is getting short. The thermostat wires needs to be disconnected and fan wires needs to be disconnected and rechecked.Mark the wires before disconnecting.The fan relay is getting stuck open.Its not getting close can also cause this.If the relay checks out short, then it has to be replaced.But first, the wirings needs to be checked.---------- This will help.Keep updated.Thanks.Helpmech.
  • raj somaiya Apr 09, 2011
    Yes relay has to be checked by meter.Also if it looks burnt or cracked from its body.Then it has to be replaced.--------- The thermostat is 24 V AC--Low Voltage Thermostat.so you can also check the thermostat volt to confirm.If relay fan and wirings al checked out ok, then its faulty thermostat.Its getting overheated and not cooling.So the fan runs non-stop to cool down the thermostat.Thanks.Helpmech.
Compressor relay switch
What temperature is this heat pump being run at? If it is low ambient temp outside this may be running in what is called defrost mode to where the compressor will run without a call for heat. This seems normal to me as long as the setpoint temperature is being reached.
Dec 25, 2013 | Honeywell Heating & Cooling
Can't increase the heat on the thermostat
Instructions1 On nearly every Honeywell thermostat, the heat setting can be increased by simply pressing the HEAT option or AUTO and using the arrow keys to adjust the setting higher or lower until the desired temperature is reached.
2 To set an automatic heating schedule for Wake, Leave, Return and Sleep, press the SCHEDULE button, then EDIT.
3 Select the current day and use arrows to select the time and temperature for Wake. For example, if you typically awake for work at 6:00 a.m. and want the heat to come on, use that as your Wake time and adjust the temperature to suit.
4 Select the day and use arrows to select the time and temperature for Leave. Since you will be leaving the home empty for several hours, this setting will allow the thermostat to lower the heat until your arrival back home.
5 Select the day and use arrows to select the time and temperature for Return. This is the time and temperature that you will choose for returning home from work and may want the heat on to warm the house for your arrival.
6 Select the day and use arrows to select the time and temperature for Sleep. Set the time you normally go to bed. The thermostat will automatically adjust itself to your selected temperature at that time.
Thanks
Apr 01, 2012 | Lakewood 2096ET Oil Filled Radiator Heater
Radiator fan runs too much
You more than likely installed a high temp thermostat, which takes more heat to open than the factory one.
One way to solve this is to install a lower temp thermostat. Or you could try another temperature sending unit, That should run your fan like normal again. But if it doesn't try to swap your fan relay out.
Nov 18, 2011 | 2002 Jaguar S-Type
Filled Coolant reservior and radiator Drove trailblazer at highway speed no cooling problem. When slowed down in traffic temperature increased to about 220 and higher, could hear coolant bubbling in...
If there is bubbles occurring even inside the top part of the radiator (where you have the coolant put in), you may have a leak on your head gasket. You may be loosing coolant through the engine.
Sep 15, 2011 | 2004 Chevrolet TrailBlazer
My car temp gauge showed over heating at highway speed. Then upper rad hose blew. Pulled over and had car towed home. I have a Matco tools code reader. Computer doesn't show any codes. Why would that...
Using your tatco code reader, select current data (real-time data) and select engine coolant temp sensor (ECT). Run engine to operating temperature (A/C off). Monitor the temp reading - when the temp reaches approx 204 deg farenheit, the fans should kick on, after the temp drops to approx 198 deg farenheit, the fans should turn off. The fans are controled by the ECM (Engine Control Module). The ECM controls the cooling fan relays.
Sep 06, 2011 | 2006 Hyundai Sonata
The temperature fan doesn't work (is it work when the car running engine or after the car heating.
It is failure of the thermostat , failure of the fan/motor or failure of the fuse/relay in the section. The thermostat will detect the increase in temperature as the posisitor triggers the fan relay to clicks and work the fan to cool, when it comes to desired temperature the relay cuts off till the temperature builds up.
So it is irrespective if the car moves or idles.
Jan 20, 2011 | Daewoo Lanos Cars & Trucks
2002 Dodge Intrepid Radiator Fans Not Working
CHECK YOUR SPEED FAN RELAY ONE SIDE IS FOR YOUR AIR CONDITIONING YOU HAVE HI AND LOW RELAYS
May 23, 2009 | 2002 Dodge Intrepid
Help! My GE Profile Arctica runs 24 hours a day...sounds like a fan. It stops when either door is opened, then starts as soon as the door closes. The temps on either side are higher than what they are set...
It is normal operation for ARTICA fans to run continuosly except when the door is open. If the door remains open for 3 minutes the fans will run anyway.
The temperature will vary about 6 -8 degrees from the selected temperature. The temperature will increase during a defrost cycle.
I do not believe you have a problem.
Apr 21, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
