Question about Dell Inspiron 1100 Notebook
De computer isn't detecting any boot device - Dell Inspiron 1100 Notebook
    Problem Solver:
  • 20 Answers
The computer boots from the hard drive, if it isn't seeing the boot device the hard drive must be defective.
Posted on Apr 08, 2011
HardDisk detected by BIOS, but DOES NOT run
  1. It's looking for a device that has boot sequence so your HD may have a damaged MBR or boot sector. A few ideas:
  1. Restart / Power on the computer.
  2. At the first text on the screen or when the Dell logo appears, tap <F2> until the message Entering Setup appears.
  3. Boot Mode will be listed under Boot.
  4. Select UEFI using the arrow keys to navigate and press enter.
  5. Save and Exit the System Setup.
  6. Check if the system is booting normally.
For an HP machine:
https://support.hp.com/us-en/document/c01443463
Any PC:
https://www.partitionwizard.com/partitionmagic/boot-device-not-found.html
Mar 08, 2018 | Computers & Internet
DR-9080c Isn't being detected via USB
Uninstall the device driver, restart the Comp and reinstall the software. If the scanner is not detected, try inserting any working device on the same USB port. if it detected, thee could be problem in the Scanner, if the new device is not detected, then it may be port problem.
S. Mohan, India
Feb 07, 2013 | Canon DR-9080C Path-Through Scanner
Unable to boot internal devices? bug?
Did you go into the bios settings and check the status of the hard drive? it would seem that is where the problem lies.
Jul 06, 2012 | ASUS Computers & Internet
I dont have boot dissk for my asus f5r laptop what can i do it says reboot and select proper boot device or insert boot media in selected boot device and press a key_
Your ASUS cannot find the hard drive to boot up.
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Mar 08, 2012 | ASUS F5RL-B1 (90NM6A233474421L750Y) PC...
The dvd player wont open and it isn't reading dvd's.
You will want to check in Device Manager to see if the device is even detected by the computer. Right Click My Computer, Properties, Click Hardware Tab and Device Manager. If it isn't recognizing the DVD drive then it is most likely bad.
Nov 30, 2011 | HP Compaq Presario SR5010 Desktop PC...
Eclipse 180 Will not load
Hi Mike, the play button in that player have 2 functions depending on the time you keep pressing it.
If you press it for 5 secs it turn the device on or off, (only is a stanby mode, to really turn it off , wich must be made to save battery if not used, you really need to slide the upper left on/off switch).
Now to send mp3 or other files FROM the pc INTO the player.
-Turn the SWITCH (upper left) to ON
-Connect the usb cable to de device
-Coneect the usb cable into the pc
Now the pc must detect the device and you should be able to open "My computer and just copy the files from the pc and paste it into the Music folder into de device.
Or I recommend to use a file manager like Total Commander to send the files into de device, google for it, its shareware but no limitations.
Hope this solves your problem!
Nov 22, 2011 | Audio Players & Recorders
Acer 5534 will not boot up....tried recovery disk....but nothing......error message PXE-E61-media test failure..........no bootable device
Hello:
Your Acer laptop is not detecting a bootable device, for sure your hard disk is:
1.- Malfunctioning and has lost its master boot record.
2.- It can be ruined and must be replaced.
In the first case, primary and recovery partition are bad, as you mention the recovery process failed (ctrl +F11). First, press F2 during POST, when "a enter Setup message" is prompted on the bottom of screen to check if the hard disk is listed on the Main BIOS properties. If detected, the hard disk can be recovered booting from DVD-ROM. In the BIOS setup utility, you need to select boot from de DVD-RW. Insert Windows 7 setup disk and it will check for possible boot errors, choose repair when prompted. Follow the instructions. The system will restart.
If the hard disk was not detected in BIOS properties, you should ask Acer for guarantee.
You may review this link for further information: http://www.acerlaptoprepairs.info/aspire-5534/
I hope this helps. Thanks
Jan 30, 2011 | Acer Computers & Internet
Ik heb een nieuwe computer (HP pavilion p6320 met windows 7 en een bestaande printer HP PSC 1410. Hoe kom ik aan een besturingsprogramma.
Hallo,
Voor de PSC1410 is een software en driver programma beschikbaar in het Nederlands, kijk op de volgende site onder Software en Drivers Downloads:
http://h10025.www1.hp.com/ewfrf/wc/product?product=441115&lc=nl&cc=nl&dlc=nl&lang=nl&cc=nl
Selecteer je besturingssysteem Windows 7 (32 bit of 64 bit): volg de instructies op in het download overzicht.
Let tevens op de updates die voor Windows 7 vermeld staan.
Feb 28, 2010 | HP Office Equipment & Supplies
Intermittent failure to boot up does not detect
hi.. have some idea on that... when you try to format your computer.. pls make the SATA as "first boot" or "second boot" then try to boot again your computer.. thank you very much...
Jul 08, 2009 | Biostar G31-M7 TE Motherboard
Reboot problem..
Easiest possible solutions first:
1) download and install the latest drivers for your video card
2) see if there is an update for the game that causes the problem
3) run memtest86 from http://www.memtest86.com/ to check if your RAM is bad
4) swap out the current video card with a known good video card
Nov 09, 2007 | MSI MS-6366 Motherboard
Dell Inspiron 1100 Notebook Logo
20 people viewed this question
Alun Cox
