Question about TurboChef C3 Single Oven
When I close the door I get warning message close door_ _m and when the open door we get message psm
    Problem Solver:
  • 17 Answers
Faulty lHS or rhs door switch.
Posted on Jan 21, 2014
Oven showing door close error with _ _ M
there are little switches inside that the door hits when you close it. open both side panels then open and close the door. you'll see them in the upper left. there primary, secondary, and monitor. PSM. they either broke or something need adjusted. easy and cheap fix. you could take the leads off and jump them until you get switches. but they are a safety feature so do at your own risk.
Jul 12, 2015 | TurboChef TORNADO Electric Oven
Door open message
door not close enough to contact
Nov 19, 2013 | Kenmore Ovens
Oven door doesnt close well
I'm not familiar with your oven but most oven doors are very similar in operation. When the door doesn't close well it's generally because the hinges have been stretched/bent when the oven door has been open. To see if this is the case, open the door fully. If it's stretched the door will open past 90 degrees (slope down instead of being horizontal). The easiest way to fix this is to bend it back. Place something as a spacer between the door and the oven on both sides (like a spanner handle or anything strong and about 8mm thick) as close to the hinge as possible. Close the door against it carefully and push the door closed. Do it a little at a time and remove the spacers and try the door each time until you are happy that it closes nicely again. It should be spring loaded closed slightly.
Aug 14, 2013 | De Dietrich DOC310 Electric Single Oven
I get the error code FSE1, lock won't engage message for the bottom oven everytime I turn on the top or bottom unit. The message will not go away until I turn the top unit off. The bottom lock keeps...
F5 - E1 Self clean latch will not lock
1. If door latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Replace door switch.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
2. If door not latched:
  2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
Note: Applies to all F5-E... codes.
Apr 19, 2011 | KitchenAid Architect KEBS208S Electric...
How do I remove the oven door
Welcome to FixYa.
Most if not all Thermador owners manuals have this outlined in them, however, here you go.
Removing the Oven Door
  • Fully open the oven door.
  • Raise the U-clip over the hook on each of the hinges to the "locked" position (see illustration below). This will prevent the hinge from snapping closed when the door is removed.
  • Grasp the door by the sides toward the back. Raise the front of the door several inches (there will be some spring resistance to overcome because of the hinge being locked). When the front of the door is high enough, you will be able to lift the hinges to clear the indents.
  • Pull the hinges out of the slots in the oven front frame.
To Replace the Oven Door
  • Grasp the sides of the door at the center and insert the ends of the hinges into the slots in the oven front frame as far as they will go (see illustration below).
  • With the door open all the way, lower the two locking clips.
  • Raise the oven door and make sure that it fits evenly with the front sides.
DOOR HINGE WARNING:
**CAUTION** With the door off, never release the levers and try to close the hinges. Without the weight of the door, the powerful springs will snap the hinges closed with great force.
Let me know how you make out or if anything is unclear. Thanks for choosing FixYa.
Good Luck,
Macmarkus :)
Sep 01, 2010 | Thermador SMW272 Electric Double Oven
I programmed my frigidaire to self-clean this morning at 10 for 3 hours to complete and 1 hour to cool. The door will not unlock even after it has cooled. Model #CFEF372ES3.
I finally got it !!!!
Click on the Clean Button - Then click on the Up arrow - a 3:00 hours should appear on the screen (In fact you are fooling the system by starting another self-clean session. Then click on Cancel, this should unlock the door. When door is open you might then get a warning message but it should disappear after a couple of seconds.
Feb 19, 2009 | Whirlpool RBS275PD Electric Single Oven
My oven doors wont close all the way
When the door came open you may have bent the hinges. Open the door fully and it should stop at 90 degrees. If lower than that, then the hinges are bent and will need replaced. Also you may look at the install directions and see if your model shows removing the door. If it is removable for install, you can try removing and reinstalling the door. It is possible with removable doors for them to slide up during install and then they are out of alignment for closing. Hope this helps.
Jan 04, 2008 | GE Profile JTP56 Electric Double Oven
No power to clock or oven with the door closed
it sounds like the oven lost its neutral feed. I would check where the cord goes on for a good connection at the middle terminal(white) if not there it may be lost elsewhere Dont forget to rate my solution as solved if i answered you question accurately....Thanks!!!
Sep 30, 2007 | Whirlpool RBS245PDS Electric Single Oven
Open Door Message
are you positive the switches are good?those switches go back to a relay board,turn off the unit and trace the wires from the switches back to the board.lighty tap on the relays (they could be stuck closed prompting that message}.if that doesnt work the relay board may be bad and yes they are expensive but i think $1000 is on the high end.
Aug 13, 2007 | KitchenAid Architect Series KEMC308KSS...
TurboChef C3 Single Oven Logo
145 people viewed this question
Top TurboChef Ovens Experts
Dennis Boxerman
Shehu Pro
Shehu Pro
Are you a TurboChef Oven Expert? Answer questions, earn points and help others
