Question about Cuisinart DCC-1200 Coffee Maker
The model dc1200 periodically stops brewing before finished the cycle, the warming plate shuts off prematurely and the clock doesn't work right.
Mine started doing this yesterday. I fixed the problem by changing the amount of time the burner stays hot.
Posted on Apr 09, 2011
Need cleaning info
Manual version: Prepare a cup of white vinegar and 4 cups of water. Pour into reservoir and initiate "clean" cycle. Boiler was warm up, shut off and repeat over the period of about a half hour, and then finally cough up all the stuff and end the cycle. Then, fill with cold water and run a full brew cycle to rinse.
My version: Dump about a quarter cup of CLR into the reservoir, let stand for a half hour. Then, add 4 cups of water and run the "clean" cycle. After finishing, unplug and turn unit over over the sink to completely drain, use tap water to clean and flush the reservoir thoroughly, dry thoroughly and then plug in, reset the clock and brew time, and run a full load of drinking water/distilled water through to final rinse. It will last forever with my method.
Feb 19, 2013 | Mr. Coffee 12-Cup Programmable Coffeemaker
Whirlpool ggw9868kq .Ducts are clean, airflow is good. Drum rotates. Dryer warms up then heating stops. happens in both auto and timed cycles.
My whirlpool dryer Model GGW9896KQ2 seems to run ok but it doesn't seem to heat up properly and takes several cycles to dry clothes. I checked the exhaust vent and it seems to be blowing air out ok. Also, it appears the dryer goes to the cool down cycle way to early. In addition, the dryer will sometimes shut off before the time is acutally done. help--I don't want to spend money for a tech or even a new dryer. It's only 8 years old.
Aug 06, 2011 | Whirlpool GGW9868K Gas Dryer
Have a Mr. Coffee SKX12 - shuts off right after brew cycle
Sounds to me like you need to set the unit to the correct/actual time.
Apr 10, 2010 | Mr. Coffee 12-Cup Programmable Coffeemaker
The clock works but nothing else, could it be programed and I need to reset? how do I reset? I am talking about a cuisanart grind and brew.
there are thermal protection switches under the warming plate there is usually 2 of them if one blows it will stop all function but usually not clock. youcan fix them yourself youfirst need to remove bottom to get under warming plate and there will be two little bullet shapped fuses made from copper youcan use a test meter to see if there is current passing through them both fuses must pass current through to work if one is bad and other is good it will not work . you can aquire the fuses on the web just do a google search for inline thermal protection switch and type name of pot or maker you have to get right ones .. but let me warn yout these are in place for a reason they usually only blow when there is a problem usually overheating problem . so it may be a wise choice to just replace product.just incase
Mar 17, 2010 | Cuisinart Grind and Brew 10 Cup Coffee...
Brew shuts off before brewing has ended or warming
Hello CJ, it sounds as if you've got a faulty control board. I would contact Cuisinart and see if they can assist you with either a repair or a replacement unit.
Cuisinart is pretty well known for their customer service and I would expect they will handle yor request promptly and most likely will get you a replacement at little to no charge.
You can call them at 1-800-726-0190 from 7 AM to 11 PM Monday-Friday and from 9 AM to 5 PM Sat & Sun.
Here's the link to their web site, for any other questions you might have
http://www.cuisinart.com/support/us.html
Hope you find this Very Helpful and best regards!
Merry Christmas!
Dec 13, 2009 | Cuisinart DCC-1200 Coffee Maker
Coffee maker shuts off too soon after brewing.
Hello FloydBob, The Cuisinart DCC-1200 has the ability to program the auto-off function that keeps your coffee warmer plate on after brewing is complete.
The unit lets you select the time increments from zero up to 4 hours.
See page 6 of the attached manual for the full instructions for reprogramming the coffee maker.
To program the Variable Auto Off:
1. Turn the FUNCTION KNOB to the “Auto Off”
position. Press and hold the “Hour” button
for 2 seconds. The clock display will start
blinking.
2. Program the coffeemaker to shut off from
zero to four hours after brew cycle is
finished by using the “Hour” and “Minute”
push-buttons.
I figured you might also like to have a complete instruction/owners manual so you can have access for any other questions you might have about your coffee maker, in the future.
http://www.cuisinart.com/share/pdf/manuals/dcc-1200.pdf
I hope you find this Very Helpful and best regards!
Nov 09, 2009 | Cuisinart Brew Central DCC-1200W, 12-Cup...
WARMING PLATE DGB 300
The Automatic Shutoff Time can be programmed
anywhere from immediate shutoff
after completion of the brew cycle up to four
hours. When the coffeemaker shuts itself off,
two tones will sound. Four hours is the default
time. The 0:00 setting shuts the unit off immediately
after brewing is complete. To check the
current setting, press the “On/Off” button and
the Automatic Shutoff Time will be displayed.
To change the preset time, press and hold the
“On/Off” button until the red “power” light
begins to flash. This signals that you have
entered the “Set Automatic Shutoff” mode.
Press the “Hours” and “Minutes” buttons
to scroll forward through the digits until
desired time appears. The first setting which
appears is preset at “4:00” and the next
display will be “0:00”, since four hours is the
maximum Automatic Shutoff setting. Pressing
and holding either button will allow you to
scroll continuously, slowly at first, and then to
accelerate to the rate of about three digits per
second. As the desired time setting approaches,
release the button and then press repeatedly
to advance one digit at a time.
The Automatic Shutoff Time (ASO) may be
programmed either before or during coffee
brewing. You may also re-program the ASO
time when brewing has been completed. If you
do so, the Automatic Grind & Brew™ will automatically
account for any time that has already
elapsed after brewing.
Feb 01, 2009 | Cuisinart Grind and Brew DGB-300BK 10-Cup...
Using a thermal pot
I also bought the thermal carafe; before I could hack the warming plate, my wife set the "Auto Off" feature to 1 minute, which shuts off the carafe heater. The settings are preserved unless you lose power for an extended period.
The warmer does still warm through the brewing cycle but it doesn't overheat the carafe (IMO.) Hope this helps.
May 29, 2008 | Cuisinart DCC-1200 Coffee Maker
Mr coffee model isx43 12 cup
Turn the :Warming Temp." dial to the right, this is the hottest the heating plate will get and should resolve your problem. THedial is locatedjust under the clock.
Feb 02, 2008 | Mr. Coffee 072179228578 12 Cup Coffee...
Coffee maker shuts off too quickly
It seems this coffeemaker insists on shutting itself off after 4 hours,
or whatever "auto-off" time you've programmed in. The only work-around I've found is to switch it to "Brew" and cycle the power switch off and on every time you pour a cup. That will start a new
4-hour timer cycle. Since the pot's still hot, it will go quickly to the
"brewing done" state and render 5 beeps.
Jan 08, 2008 | Cuisinart DCC-1200 Coffee Maker
Cuisinart DCC-1200 Coffee Maker Logo
583 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
