Question about Whirlpool Washing Machines
My washer don't spin or drain the water - Whirlpool Washing Machines
  • 6,993 Answers
welcome to Fixya.
There are several reasons why a washing machine won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes.
Find some possible cause and how to solve the problem:
A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall.
Good luck.
Posted on Apr 08, 2011
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
Kenmore washer model #796 front load washer - washer will not spin out - went to drain water from drain hose - no water will come out - so I unscrewed pump filter - water is pouring out of there - help
OK....I am here to RESCUE you...1st, DON"T do that anymore! You will get wet! LOL. Simple solution. You need a New Drain Pump replaced and installed. Once that is done. I do NOT want to hear about you going down there anymore and doing....That! LOL...
Your machine will be happy and spin.and drain all day Long!
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Mar 05, 2014 | Washing Machines
Will not fill spin or drain
Hello Don Perna - I understand that the washer will not spin or drain; however is it making a humming noise? If so, either the drain hose or pump is clogged and needs cleaning. Try setting the washer to a spin cycle only. Will water pump out? If it does not, then the unit could possibly be experiencing a communication error with the control board, faulty pump, timer or door lock assembly. If I was in your position, I will personally contact a professional for an accurate diagnosis and to assist with the repairs. You can often locate a qualified service provider by visiting the manufacturer website.
Mar 03, 2013 | Frigidaire GLTF2940ES Front Load Washer
It will hum on spin but water will not drain and it won't spin
First thing you have to do is unplug the machine and get the water out. (The second part is optional but if you don't you'll have a big mess on your hands). Next you will need to remove the front of the washer by pushing the two clips in, one located on the left and the other on the right, between the front and the top of the washer, while pulling forward on the front a little . Once you have that done I would disconnect the wires from the pump, then the drain lines see if there is anything inside binding it up. If so, remove the object, reconnect everything but dont put the front on that way you can see whats happening. Plug the machine back in, turn it on and put some water in it and then move the cycle to spin/drain and see if it works. If it does your done, if it doesn't your pump is bad, and that part number is WH23X10013. You can buy this from apdepot.com or repairclinic.com
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 03, 2012 | GE WBSR3140DW Top Load Washer
Hot water stops filling too soon.
Fill setting has to be adjusted and the belt is slipping on the spin cycle and not generating enough centrifugal force to get the water out.
Aug 25, 2017 | Kenmore 22422 Top Load Washer
Fridgedare front end washer! Water don't seem to drain for washer, looks like the spin cycle do not spin water out.
if you can hear pump motor, then there is a blockage somewere, check see if filter is clear,check outlet pipe is not kinked,disconect outlet pipe hold over pan as close to floor as posible see if water comes out if it does then there is a problem with pump.
Aug 12, 2011 | Washing Machines
I have an affinity washer and dryer. The last loand did not complete its cycle. It is partially full of water, but not enough to seap out. Itmakes a buzzing sound and will not spin. It is not the type of...
It sounds like the drain pump has stopped. If it still has water in it and you turn it on (in the spin only cycle) the drain pump should be running and you sould be hearing the water drain. The washer will not spin until the water is out. Depending on how handy you are determines whether you can access the drain pump and remove the obstrustion. There is also a trap to catch debries from going into the pump. This could be plugged, but normally you don't hear a buzz. You hear the drain pump working but no water going out. Good luck
Apr 23, 2011 | Frigidaire Affinity ATF7000E Front Load...
My washer dont drain water and don spin but aggigates.please help
your washer house is to low it has to be sink level or 90 dgree angle for it to drain after drain it sould go in faze mode to spin if not your belt is bad.
Feb 06, 2011 | Westinghouse WWS833ES Super Capacity Top...
MY WASHER IS NOT DOING THE SPIN CICLE, DRAINS ALL THE WATER OK, PUMP IS FINE, JUST DOES NOT SPIN
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 06, 2010 | LG WFT1071TP Top Load Washer
Washing Machines Logo
399 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
