Question about Maytag Bravos MVWB400V Washer
What does the code F51 mean? - Maytag Bravos MVWB400V Washer
  • 1,998 Answers
The F51 code is a motor rotor position sensor (RPS) feedback error. In other words the control board is not sensing any motor rotation ive seen this same problem in whirlpools calypso, cabrio, and kenmore's oasis you will need to support the machine on a diagonal and go in from under neath removing the motor to gain acces to the rps sensor if you have any further questions message me back and dont be surprised these codes usually hide other codes in the kenmore i mentioned i went from rps sensor to lid switch to erc to entire wiring harness cost me like 260 in parts for a machine that maybe costed 499 at that time not a great fan of the rps sensor in any unit they seem to fail within 3 years hope this helps and please remember to rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
Posted on Apr 08, 2011
What does an error code F51 on a whirlpool cabrio washer mean?
Cabrio F51 Fault (Stored Fault Code F51) The Cabrio's F51 fault code flashes on the washing machine's display when there is a motor rotor position sensor (RPS) failure.
Check for good contact at the control Board and at the RPS. Sometimes disconnecting and reconnecting the RPS plug connection several times will clean off corrosion that may be affecting the contacts.
Here is an earlier Fixya answer addressing the query:
Whirlpool cabrio error code f51 what does it mean
Sensor is item 20 below. Clean it.
Nov 27, 2017 | Whirlpool Washing Machines
What does a flashing F51 code mean?
Dump the appliance. sears delivers the worst garbage available
Mar 22, 2016 | Kenmore Elite Oasis 27052 Top Load Washer
What does code F51 mean
Code F51 means there is a problem with the Rotor Position Sensor. This could be something as minor as a bad plug connection. However, there have been many cases of socks or other small garments being flung over the top of the tub rim and getting caught between the metal tub and the plastic tub which contains the water. The "errant" clothing keeps the tub from returning to it's original position thus preventing the Position Sensor from aligning.
Mar 06, 2015 | Maytag Bravos Series MVWB850YW 28"...
What does F 51 mean?
The F51 fault code on your Cabrio washer indicates that the control board is not sensing the proper drive motor spin. To clear the fault code, press the Pause/Cancel button.
Make sure that the drain hose is not stuck way down the stand pipe. This can cause siphoning of fill water which will inhibit proper motor rotation.
Check to see if the wash basket spins freely. If it does not, you may have an item of clothing stuck between the outer tub and the inner basket. This restriction in rotation will also cause an F51 fault code.
If these tips do not help you resolve the F51 problem, then you probably have a component failure. Possible failures include: wire harness or wire connection problem between the machine control and the RPS sensor (Rotor Position Sensor), a failed RPS sensor, a failed drive motor, and a failed machine control board.
Mar 08, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My Maytag 300 quite series has a code F51 what does this mean?
Hi and welcome to FixYa, I am Kelly The F51 code is a motor rotor position sensor (RPS) feedback error. In other words the control board is not sensing any motor rotation. It is fixable but will result in the replacement of failed parts. (Sensor or electronic control board) The control board is not cheap. Hopefully you only have a failed sensor.
Thanks for choosing FixYa,
Kelly
Feb 16, 2011 | Maytag Bravos MVWB400V Washer
F51 problem
f51 code is the tachometer rps sensor saying that the drum is not spinning at proper speed usually means something is stuck between the inner and outer tub
Jan 23, 2011 | Kenmore Oasis HE 27082 Top Load Washer
F51 code
The F51 error code indicates that the control is not sensing proper motor movement through the signals from the RPS (rotor position sensor) circuit. This can be caused by several different problems. Make sure that you are not overloading the washer. Overloading can cause this problem. A toy or foreign object could be under the washer that is interfering with motor rotation. With the washer empty, spin the basket inside the washer tub to see if it spins relatively easily. If not, you could an item caught between the spin basket and the tub. You could have a wire harness problem causing signals to not be transmitted properly between the RPS and the machine control board. A failed RPS sensor or a failed control board could also cause this problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 17, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Whirlpool Cabrio W10106470 has an F51 code. What
F51 error is a rotor position sensor error, two parts really need to be replaced. 1) the rotor sensor itself ($43) and 2) the control board ($197)
Jun 23, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Maytag Bravos MVWB400V Washer Logo
314 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
