Question about Kitchen Ranges
Just purchased 4 replacement balance rods for the Fisher Paykel EcoSmart washer. they did not come with instructions. HELP. How do I do it??
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 12 Answers
I have a Fisher Paykel dishwasher, and needed to call their customer support. They were wonderful, they spoke to myself and my plumber for 30 minutes. Have you tried their customer support? Their accent was a little hard to understand....but worth a try.
Posted on Apr 08, 2011
How to fix my fisher & paykel washer machine from shaking and knocking
Your 4 suspension rods will need replacing as they are loose & worn.
Or the bowl has lost its ballast water from the top & bottom balance rings of the bowl.
Jan 05, 2013 | Fisher Paykel WA42T26GW1 EcoSmart 25" Top...
Fishwe&Paykel GWL10 won
It could be the out of balance switch faulty & need replacing.
Nov 17, 2012 | Fisher Paykel EcoSmart GWL15
THE WINGS ON THE AGITATOR ON MY FISHER PAYKEL ECOSMART TOP LOAD WASHER ARE BREAKING OFF. CAN I REPLACE THIS EASILY?
yes loosen the wing nut nd remove nd replace , u can order part from F&P direct 1800650590 ask for spares
Jan 28, 2010 | Fisher Paykel EcoSmart GWL15
Our gwl11 fisher paykel washer will start to fill for about 5 seconds then stops
This is either your lid switch not working or your out of balance switch the latter being located under the large motor controller board under the controll panel.That should fix it.Kind Regards Stefan.
Jul 08, 2009 | Fisher Paykel EcoSmart GWL15
Fisher and Paykel Ecosmart continually gets off balance
at the very top of the bowl is a fluid filled balance ring, I would say that all the fliud has leeked out into your wash over time and now you fluid level is low or dry , what i did is drilled two 8mm holes one on each side of the balance ring then pumped it full with 5 tubes of cheap and nasty grey plumbers silicon (only inject in one side to avoid air bubbles in bal ring keep pumping until the whole ring is full let half a tube or so squirt out the other side to get rid or air bubbles , let it dry for 48 hours cut the silcon flush with a sharp knife then all sweet as bro .
Feb 09, 2009 | Fisher Paykel EcoSmart GWL15
Fixed basket came loose...
if less than 2 yrs warranty and washer has 2 yr warranty (ck owners manual) call service ..if not remove plugs on front sides of top remove phillip screws lift top outer tub is supported by 4 swing arms one or more is probably loose or broke but can be replaced also have known then to just pop out of position with really bad off balance load
Aug 20, 2008 | Fisher Paykel EcoSmart GWL15
Fisher Paykel ecosmart purchased 3-4 years ago.
I too am having this problem.  I am checking out if anyone has a solution.  Somewhere someone said to change the "Fill switch"  I don't know what that is or where it is.  Does this help?  If you have found anything let me know. monica.roberts@usa.com
May 23, 2008 | Fisher Paykel EcoSmart GWL15
Getting inside the Fisher-Paykel GWL15 washer
thats it , remove those 2 screws and the top will flip back, the new "clothes guard"( neck ring), will snap right into place, be sure to rehook the spring to hte left front susension rod!
Mar 25, 2008 | Fisher Paykel EcoSmart GWL15
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
