Question about GE 24GP653 24" TV
Hi...my[ ge 24gp653] tv..will not come on...an ui am hearing a clicking in the tv near the fuse....[ a little white box thing-eee..can some one help.....thanks....
  • 6,993 Answers
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck.
Posted on Apr 08, 2011
  • 5 more comments
  • Albert Greene
    Albert Greene Apr 09, 2011
    hi ..thanks for the reply....but.....the electrolytic capacitor #cd293h[200v330..]is the only one i see with a little bulged up.........can that be it?????
  • Walesarumi
    Walesarumi Apr 09, 2011
    Yes.
  • Albert Greene
    so get the same one...?????
  • Walesarumi
    Yes, the same one. Use the defective one as a sample in order to get the right one.....
  • Albert Greene
    "Thanks so much for the quick reply.i am going to look for it today.....
  • Walesarumi
    Okay.........
  • Albert Greene
    hi..i got the the electrolytic capacitor #cd293h[200v330..] and still the same thing......the clicking noise...an will not come on.........
Screen is cut off at the bottom, preventing viewing of things such as espn's bottom line or video game menus
It can be adjusted only through service menu. Code to open the menu will be available to the authorized service provider. You have contact them.
Oct 05, 2010 | GE 24GP653 24" TV
The vertical is out on my GE 24GP653.
around center off to side la7838
Aug 05, 2009 | GE 24GP653 24" TV
WATCH DVD AND HEAR WHILE CONVERTER BOX
If you the video works and no picture you may have the audio and video on different inputs. Meaning Input 1 could be the video and Input 2 could be the audio.
Please provide furtehr detail on connection type from DVD sing red yellow and white cables to TV input X on the back of teh TV. I can not find teh original post. I can help you through this with a little more info.
Jan 17, 2009 | GE 32GT740 32" TV
Colors on the tv are dark
the screen control on the flyback transformer needs to be turned up a little
Nov 10, 2008 | GE 24GP653 24" TV
GE Television 24GP653 - Vertical out
change the vertical ic la78--
Oct 30, 2008 | GE 24GP653 24" TV
GE JVM2070 issue
what is the make and model number
Mar 26, 2008 | GE JVM2070 Microwave Oven
Microcam pro
first thing to do is connect your microphone at the back of the computer near the audio out socket.( color pink socket). if not solve then try to do this.
On task bar you can see the volume control. point it and double click. can see master volume window. click option then " properties" on show the following volume control. check the " Mic Volume" click ok.you can now see the "mic volume" Uncheck the "mute box" and drag up the volume meter.then close.
hope this solve.
melnavz
Nov 30, 2007 | GE EasyCam Webcam
GE 24gp653 Overscan
if you take the back off the tell their should be two plastic screws one is view and the other is focus they should be by the arial socket have a look for them if you are unsure take it to repair shop they should do this for next to nothing hope this is some help ...............................................
Nov 15, 2007 | GE 24GP653 24" TV
GE 24GP653 24" TV Logo
120 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
