Question about Western Digital Wd Elements Se 1tb Portable Black Wdbabv0010 USB 20 Hard Drive
My hard drive is recognised by windows and shows the memory used but shows no files - comes up as empty. I have done a disk check and this reports that there is no problem. I have also tried this on 2 different computers. This occurred when my computer came up with a hard drive error, while fixing this error I removed the external hard drive from the computer.
  • Western Digital Master
  • 27,725 Answers
Did you turn of your computer or click on remove hardware safelty link before diconecting this external hard drive if it shows how much is being used it is being recognised you could run the chkdsk utility
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start might or might not schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
then defragment your hard drive
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
hope this helps
Posted on Apr 09, 2011
Power supply went off while using this HD
Recuva (pronounced "recover") is a freeware Windows utility to restore files that have been accidentally deleted from your computer. This includes files emptied from the Recycle bin as well as images and other files that have been deleted by user error from digital camera memory cards or MP3 players. It will even bring back files that have been deleted from your iPod, or by bugs, crashes and viruses!
  • Put the memory card into an USB card reader and plug it into the USB port in your computer, then run the Recuva program.
  • Simple to use interface - just click 'Scan' and choose the files you want to recover
  • Easy to use filter for results based on file name/type
  • Simple Windows like interface with List and Tree view
  • Can be run from a USB thumb drive
  • Restores all types of files, office documents, images, video, music, email, anything.
  • Supports FAT12, FAT16, FAT32, exFAT, NTFS, NTFS5 , NTFS + EFS file systems
  • Restores files from removable media (SmartMedia, Secure Digital, MemoryStick, Digital cameras, Floppy disks, Jazz Disks, Sony Memory Sticks, Compact Flash cards, Smart Media Cards, Secure Digital Cards, etc.)
  • Restores files from external ZIP drives, Firewire and USB Hard drives
  • It's fast, tiny and takes seconds to run!
Go to these WEB sites to down Recuva http://download.cnet.com/Recuva/3000-2242_4-10753287.html www.filehippo.com/download_recuva
Aug 22, 2012 | Samsung G3 Station 1TB USB 2.0 Black...
Tip
5 ways to speed up your computer
By following a few simple guidelines, you can maintain your computer and keep it running smoothly. This article discusses how to use the tools available in Windows 7, Vista, and XP Service Pack 3 (SP3) to more efficiently maintain your computer and safeguard your privacy when you're online.
1. Free up disk spaceThe Disk Cleanup tool helps you free up space on your hard disk to improve the performance of your computer. The tool identifies files that you can safely delete, and then enables you to choose whether you want to delete some or all of the identified files.
Use Disk Cleanup to:
  • Remove temporary Internet files.
  • Remove downloaded program files (such as Microsoft ActiveX controls and Java applets).
  • Empty the Recycle Bin.
  • Remove Windows temporary files such as error reports.
  • Remove optional Windows components that you don't use.
  • Remove installed programs that you no longer use.
  • Remove unused restore points and shadow copies from System Restore.
Tip: Typically, temporary Internet files take the most amount of space because the browser caches each page you visit for faster access later.
2. Speed up access to dataDisk fragmentation slows the overall performance of your system. When files are fragmented, the computer must search the hard disk when the file is opened to piece it back together. The response time can be significantly longer.
Disk Defragmenter is a Windows utility that consolidates fragmented files and folders on your computer's hard disk so that each occupies a single space on the disk. With your files stored neatly end-to-end, without fragmentation, reading and writing to the disk speeds up.
When to run Disk Defragmenter
In addition to running Disk Defragmenter at regular intervals—monthly is optimal—there are other times you should run it too, such as when:
  • You add a large number of files.
  • Your free disk space totals 15 percent or less.
  • You install new programs or a new version of Windows.
3. Detect and repair disk errorsIn addition to running Disk Cleanup and Disk Defragmenter to optimize the performance of your computer, you can check the integrity of the files stored on your hard disk by running the Error Checking utility.
As you use your hard drive, it can develop bad sectors. Bad sectors slow down hard disk performance and sometimes make data writing (such as file saving) difficult, or even impossible. The Error Checking utility scans the hard drive for bad sectors, and scans for file system errors to see whether certain files or folders are misplaced.
If you use your computer daily, you should run this utility once a week to help prevent data loss.
Run the Error Checking utility:
  1. Close all open files.
  2. Click Start, and then click My Computer.
  3. In the My Computer window, right-click the hard disk you want to search for bad sectors, and then click Properties.
  4. In the Properties dialog box, click the Tools tab.
  5. Click the Check Now button.
  6. In the Check Disk dialog box (called Error-checking in Windows 7), select the Scan for and attempt recovery of bad sectors check box, and then click Start
  7. If bad sectors are found, choose to fix them.
Tip: Only select the "Automatically fix file system errors" check box if you think that your disk contains bad sectors.
4. Protect your computer against spywareSpyware collects personal information without letting you know and without asking for permission. From the Web sites you visit to usernames and passwords, spyware can put you and your confidential information at risk. In addition to privacy concerns, spyware can hamper your computer's performance. To combat spyware, you might want to consider using Microsoft Windows Defender, which is included in Windows 7 and Windows Vista, and is available as a free download for Microsoft XP SP2. Alternatively, there are other free anti-spyware software programs available.
5. Learn all about ReadyBoostIf you're using Windows 7 or Windows Vista, you can use ReadyBoost to speed up your system. A new concept in adding memory to a system, it allows you to use non-volatile flash memory—like a USB flash drive or a memory card—to improve performance without having to add additional memory.
on Jan 01, 2010 | Computers & Internet
How can i speed up my aircel internet on pc
5 ways to speed up your PCBy following a few simple guidelines, you can maintain your computer and keep it running smoothly. This article discusses how to use the tools available in Windows 7, Vista, and XP Service Pack 3 (SP3) to more efficiently maintain your computer and safeguard your privacy when you're online.
  6. In the Check Disk dialog box (called Error-checking in Windows 7), select the Scan for and attempt recovery of bad sectors check box, and then click Start.
    checkdisk.jpgExample of Check Disk Local Disk dialog box
4. Protect your computer against spywareSpyware collects personal information without letting you know and without asking for permission. From the Web sites you visit to usernames and passwords, spyware can put you and your confidential information at risk. In addition to privacy concerns, spyware can hamper your computer's performance. To combat spyware, you might want to consider using the PC safety scan from Windows Live OneCare. This scan is a free service and will help check for and remove viruses.
Jun 13, 2010 | Microsoft Windows XP Professional for PC
FREE UP HARD DRIVE SPACE
Hi! Your 3 Gigs of memory have nothing to do with your disk storage. You may try freeing some disk space by doing the following:
Clean up your recycling bin by selecting the Empty Recycle Bin option, after right clickin on the icon.
Clean up the All User's temp directory, usually within your Windows installation drive-> Windows folder, called TEMP folder.
Clean up your own TEMP folder, usually hidden and found within your own user name folder. To make this folder visible, in File Explorer, go to Folder Options, and find the entry that reads: Hide system files. Uncheck the option. Make sure you reset it after you're done.
A little riskier is to try to resize your virtual memory, or the amount of disk space that Vista (and other versions of Windows) uses to emulate physical RAM, when you have exhausted it.
You may also save disk space by sacrificing the Hibernation feature by disabling it. If you do this, by going to the Advanced Settings of Vista, under System, uncheck the box next to your drive, and while having Hide System Files also unchecked, you can physically delete the file, usually found at the root of your main drive (usually C:) Note: For this change to take effect, you will have to restart your system with a cold boot.
Try buying some software similar to Norton Utilities (a reduced of it is available in Norton 360) that will defragment your drive but will also clean up stray and orphan files left behind by improper uninstallation of other software and temp files left behind when an application like Word, or any other, crashes.
Oct 08, 2009 | Computers & Internet
My laptop is really slow
It could be due to clogged Registry. Use a good registry cleaner to do that. Even I had the same prob. my laptop used to take 20 mins to boot. After cleaning the registry it runs now.
Sep 17, 2009 | Gateway MT3705 Notebook
Data lost in usb after moving from harddisk
1.
Update Your Windows Operating System.
2.
Check your computer.
with antivirus and antispyware program.
3.
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
3.a) Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
3.b) Format pen drive
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Dec 31, 2008 | Apple iPod nano
I want to know all files being read/used at any time
The follwing command will get you a complete list of files in your hard drive.
To list every file on your hard drive, you could pull out some combinations with DIR /S to show files in all subfolders, or you can just type in CHKDSK /V.
Doing so will show every file on your hard disk, and at the end, will show you a report of the total disk space, total free space, and more.
Save this report to a text file for later viewing. Type in
CHKDSK /V > DISKREPORT.TXT
Second :
This can be done by th following software which can be downloaded from here
http://www.refog.com/free-keylogger/key-logger.html
Good Luck.
Live, Love, Laugh.
May 11, 2008 | HP XW6000 PC Desktop
USB flash disk not working
Assuming you are using a Cruzer Micro Drive with U3 Smart, things can be a little confusing because the drive actually shows up as two independent devices. When you insert the drive, there should be two devices showing up in your list of drives. One of them is installed as a CD Rom Drive and the other one is a Removable Drive. If you double click on the CD Rom Drive instead of the Removable Drive and you don't have any U3 applications mapped to the CD Rom Drive, then you'll get an insert disk message because Windows thinks that the CD Rom Drive is empty. Just use the Removable Drive if you want to simply install and transfer files.
Jan 05, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Storage Limit incorrect
If you are using windows XP then when you open the hard drive folder, select "folder options" from the "tools" drop down menu. Then select the "view" tab, fairly close to the top of the list that appears is the show/do not show hidden files and folders option, ensure "show hidden files and folders" is selected. Then check the hard drive again and see if anything has appeared. Check that there is not a drive partition that you didn't know was there - it will come up under "my computer" as a separate drive letter that you don't relate to any of your other drives. Check the hidden files routine for the "my computer" folder too. If you have nothing that was hidden large enough to make the difference, then the most likely problem is a minor corruption of the file allocation system, sometimes happens when a tiny surface fault in the disk which would otherwise be no problem happens to land exactly where some important data is located. The cure for this would hopefully be to save anything you want to keep from the drive and reformat it. (right mouse click on the drive, select "properties" and follow the instructions for whichever File allocation table system you want to use. If you are not using windows XP, the comments are almost certainly valid, there may be minor differences in the process - ask if you need more help with anything. Hope this helps :)
Jun 27, 2007 | LaCie d2 Extreme (300790U) 250 GB Hard...
Western Digital Wd Elements Se 1tb Portable Black Wdbabv0010 USB 20 Hard Drive Logo
125 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
