Question about Samsung LN32A330 32 in. LCD TV
Where to put the power cord - Samsung LN32A330 32 in. LCD TV
  • 591 Answers
Usually in the back of the unit...
Posted on Apr 08, 2011
How to turn on my Toshiba satellite L305D-S5974, YESTERDAY IT WENT DEAD AND NOW I GOT THE CHARGER BUT ALL I SEE IS AN ORANGE LIGHT BLINKING BUT IT STILL STAY OFF NO FAN,NO SCREEN AT ALL, HELP PLZ
Remove the power cord and remove the battery. Press and hold the power button for 30 seconds... no less... Put the battery back in and plug in the power cord. Try to start it.
If it doesn't work, try again without the battery, just the power cord.
If that doesn't work neither, remove the power cord, and leave it without the battery or power for a couple hours. 3 minimum.
Put everything back and try to start it up again.
Good luck.
Apr 25, 2016 | Toshiba Computers & Internet
I need a power cord for it.
hello nancy, what is the type of your power cord? i put a picture so you can see what type of cord.. you can buy a power cord at your local electronics store or appliances store..
Aug 04, 2015 | Kitchen Appliances - Others
How do I replace power cord?
Well I would take it apart and put a new one on.
A power cord for...? Extension cord? tree saw. Shuttle launch power module cord?
Aug 30, 2014 | Vacuums
THE SWITCH ON IS NOT WORKING CAN YOU HELP ME TO FIX IT
The Switch ON? Are you talking about the Power Button? If so it could be that your Power Cord is bad. Some models of the Power Cord has a light on it and some laptops light up somewhere when the power cord is plugged in and working.
You might have been working off your battery and if the power cord is bad it was not charging the battery and now nothing will work because the battery is completely drained.
If the power cord is good, you might have a Static Charge Buildup. Remove the power cord and the battery, then press and hold the power button for 30 seconds. After 30 seconds put the power cord back in (not the battery, leave it out) and press the power button. If it starts booting you had a Static Charge Buildup and can put the battery back in now.
If all fails, take an ink pen and stick it inside where the power cord goes. If it is not tight then the DC Power Jack is bad and need to be repaired. This will require a complete disassembly of your laptop.
Mar 23, 2012 | Samsung N150 Netbook
My samsung N150 power switch is not working
Mar 23, 2012 | Samsung N150 (36725723009) Netbook
How to replace Seine Module Board
After a LOT of screw removal, AFTER disconnecting the power cord, I did EXACTLY as they said and simply removed the plug PJ36A, just as told. Then I vacummed out all the dust!
Before putting the cover back on, I plugged up power, being SURE to only touch the power cord and the TV turned right on! :)
Removed the power cord, put in all the screws, reconnected the power cord and 'good as new'. :)
Thanks a bunch guys!!
Mar 14, 2012 | Televison & Video
I have an acer 7741z that is only a few months old and will not power on with battery or power cord
Okay.. Try taking out any cords and take out the battery and hold the laptop upside down and hold the power button for 30 seconds then turn it right side up and put the cord back in try to turn it on then put the battery back in.
Jul 06, 2011 | Acer Computers & Internet
You have to hold up on the power cord to make it power on. Put tension on the cord so it will work.
One of the wires in your power cord broke. When you hold the cord up or put tension on it, you are pushing the broken ends together, allowing the electric current to flow through the cord.
You need to replace that power cord. It is both a nuisance and possibly a fire hazard.
Nov 26, 2009 | Sony PlayStation 2 Slimline Console
Push the on button and nothing happens
I believe you are using a new power supply now.
Before you start, first check if your Power button is OK.
To do this, first unplug the power cord from your PC.
Remove POWER-Button connector (with black/white or blue/white wires) from you Motherboard
Remove RESET-Button connector (with black/white or blue/white wires) and put it on the place of POWER-Button. (polarity for these buttons is not important)
Plug the power cord back and press RESET.
Does it change things ?
If it starts, then your Power-Button is broken.
If not, remove the power cord and then put te POWER-Button and RESET-Button on their places on the Motherboard.
Now do the following:
(please remember the position and polarity of all cables/items you remove/unplug, Use Digital camera if necessary). Be patient, don't hurry!
- Unplug the power cord.
- Press power button few times (power cord is unplugged).
- Remove the Battery.
- Unplug the Monitor cable and remove VGA card.
- Remove RAM module(s).
- REMOVE any PCI cards(Modem. Lan, Audio etc.).
- Unplug any HDD/FDD/DVD cables from the Motherboard.
- Unplug Power from all your HDD/FDD/DVD devices.
Now:
- Put the batery back (be careful to the polarity)
- Put the Computer power cord
- Turn on your PC.
Is the Processor Cooler running ?
Are there Beeps from PC Speaker?
If not, then your Motherboard is broken !
If there are some beeps, then your Motherboard is OK, but some component(s) is broken.
Turn Off your PC by pressing the Power button for about 4 sec.
Unplug the power cord and press Power button few times.
Put your VGA back, and connect the monitor cable, too.
Put back ONLY ONE memory module (if there are more).
Connect the Power cord and press Power button.
Do you have a picture now ?
If you have a picture, put back all other memory modules and PCI cards, connect Data and Power cables to your HDD/FDD/DVD units, but ONE at TIME.
Do not connect and put everything back all at once!
After each change, see if there is a Pcture and (one) beep.
It needs some time but that's how you will detect which device/cable is maybe broken!
And remember:
Before you do any change, AALLWAYS do that with power cord unplugged and power button few times pressed !!!
If there are Beeps, try another memory module.
Again if there are still beeps, you have problem either with your RAM or VGA.
If there are infinite long beeps, than it is your RAM.
If there is one long and many (8) short beeps, then it is your VGA
Replace it!
Regards.
Mar 23, 2009 | HP Computers & Internet
Samsung LN32A330 32 in. LCD TV Logo
Henry  Thomas
Henry Thomas
