Question about GoVideo Go Video VR3840 DVD Recorder/VCR
Trying to record to disc from VHS After recirding 8 copies, it now reads "Unknown disc, Please check disc" This is a Go-Video VR3845 Unit.
  • GoVideo Master
  • 6,993 Answers
I answered this question previously and the solution remains the same;
how long have you been using the player and has it ever accept blank DVD-R discs in the past.
The problem might be as a result of weak laser (lens) or the blank discs inserted might not be compatible with player.
When the laser(lens) of a player becomes weak, it will not be able to read blank discs. It only takes a very strong laser to read/accept blank discs. If it happens that the laser (lens) is the cause of the problem, then it means you will need to replace the laser (lens) to a brand new one to be able to read blank disc. Though the player might be playing DVD and CD, note that blank disc is stronger when it comes to reading from the laser (lens), it requires sharper laser. I hope you understand this.
So, insert a CD into the player and observe if it will play.If it plays, then its obvious that your laser is very weak.
Concerning the incompatibility issue, I hope you are aware that there are various kinds of empty DVD discs such as DVD +, DVD -, DVD RW. Try any of this empty DVD discs as one of them as to be compatible with this DVD recorder.
Amongst the two topics discussed above, one has to be the cause of the problem. So its up to you to figure out which is the cause of the problem.
I hope you understand the above....
I wish you good luck.
Posted on Apr 08, 2011
Trying to copy VHS to Disc-Says"Unknown disc"
Apr 08, 2011 | GoVideo Go Video VR3840 DVD Recorder/VCR
I am trying to copy a VHS to DVD from a VHS player. I have a Sony VRD-MC6 multi-function DVD Recorder. I am using the A/V cable and have verified that they are correctly placed. The Sony player will...
Is it possible the VHS you're trying to copy is copy-protected? Apparently, the MC6 displays "waiting for signal" when you're attempting to copy a copy-protected (commercial) video. I had success converting my own homemade VHS tapes. I just bought my MC6, and thought I'd pass along some tips I got from others: You know you're recording when a red ring around the large Record button lights up and it actually says "recording" on screen, and adjust HQ to SP to get 2-plus hours of video on the DVD.
Jan 24, 2011 | Sony VRDMC10 DVD Recorder
I was copying vhs tapes to dvd successfully and then it started saying disc unknown.cant figure it out
this issue calls for a little info from my brain
have you tried to reset the recorder if so is there firmware updates for the burner
have you changed the brand of dvd disks lately if so sometimes a different disk has issues for some odd reason i have run into this problem before
Jan 03, 2011 | GoVideo VR3845 DVD Recorder/VCR
How do you record a VCR tape to a DVD?
Import the video on your pc using something like
http://www.newegg.com/Product/Product.aspx?Item=N82E16815260028&cm_re=av_card-_-15-260-028-_-Product
and convert it to dvd format using the supplied software..
Jan 16, 2010 | GoVideo VR3845 DVD Recorder/VCR
Samsung dvd vr357 Can not watch copied dvd on other dvd players
I know with the Go-Video, the DVD disc has to be 'finalized' before it's compatible with other DVD players/computers.
Check your 'set-up' menus while that disc is inserted into your Samsung DVD machine and see about pushing the 'up' arrow, if you have one, to see the contents of the DVD disc...then see if you can toggle to the right to see options for that disc, for instance, the title of it. You might see the 'finalize' option there.
Feb 27, 2009 | GoVideo VR3845 DVD Recorder/VCR
How to record a VHS tape to a DVD disc
Read your manual first to make sure the unit will do this.If it does chances are it won't record unless it has a decoder built in.Most VHS tapes have macrovision protection that prevents you from copying them.It will however,record homemade VHS tapes.There are decoders out there you can buy to enable you to copy VHS tapes.
Dec 30, 2008 | Samsung DVD-V4600 DVD Player/VCR
VHS to DVD recording
Yes, just turn off the tv.
Walt
Apr 08, 2008 | GoVideo VR3845 DVD Recorder/VCR
Go video dvd recorder vhs combo vr3845 - won't read discs - says unknown disc
FIRST UNPLUG THE UNIT FROM POWER !!!!! The problem is dirt/dust/****/crud/stuff on the tiny, little ***** laser lens. Remove the case screws ( 2 on each side, some in the back) with a correct size driver. The cover must be pulled open at the bottom, side to side a tiny bit ( use a hand on each side) to allow the cover to lift up at the rear, it must come up quite a bit as if it is hinged at the front and THEN pulled back out of the front panel. Set the cover to the side. The DVD reader/Burner is covered with a small black cover, it is held on with two TINY screws, STOP!!!! Get yourself the CORRECT size driver at Fry's or Radio Shack, DO NOT get cheap here!!! Remove the two screws and find the two plastic grip tabs, push them to release and lift the cover. There is the laser! It is a tiny blue lens about the same diameter as the tiny screws. find a very, very well washed CLEAN 100% cotton T-shirt. The softer the better, get 70% or higher rubbing alcohol, pull the fabric over the tip of the finger and wet with the alcohol. VERY GENTLY wipe the lens 4 to 5 wipes and the 3 wipes with a dry spot. That should clean the lens. USE NOTHING ELSE!!!!!! The lens tracks back and forth on two tiny bars. The stuff I use is WD-40 wet on a Q-tip swab. Go to a safe place to spray the WD-40 on the Q-tip. The lube should drip. With the Q-tip apply the lube to the tiny bars at the ponts of rider contacts and wipe the bars too. Put the top of the burner back> BE CAREFUL!! Use a magnet driver and then repower and try to read a known good dvd. You will have to do this more in the future, you understand, dist dirt etc in the air. Put the top back on. Enjoy.
Mar 02, 2008 | GoVideo VR3845 DVD Recorder/VCR
GoVideo VR3845
I too have this problem, will read regular CDs but no DVDs. I get the sme message, then the disc ejects. Is there a RESET function?
Jun 30, 2007 | GoVideo VR3845 DVD Recorder/VCR
Televison & Video Logo
90 people viewed this question
Top GoVideo Televison & Video Experts
Demonic-2011
Demonic-2011
 Grubhead
Grubhead
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
