Question about Crock Pots & Slow Cookers
Still very new Tedelex pressure cooker: the red-headed pop-up valve seems to take for ever before "popping" and allowing steam pressure to build up. How long should I wait? Thanks, Nic
    Sergeant:
    Champion:
  • 342 Answers
My pressure cooker does that too, you would have to wait until the steam starts to come out a lot, then it will pop out and start building up pressure. Hope this helps.
Posted on Apr 08, 2011
Manual for Mirro pressure cooker Model M- 0536-1
go google and type in -- user manual for mirro pressure cooker model m-0536-1-- and if there is one it will be a pdf version down load
make sure that the lid seal went in without any twists
put something under the seal and go around the lid several time to allow the seal to untwist
Oct 26, 2015 | Crock Pots & Slow Cookers
I have a Deni pressure cooker. 1 out of 10 times it works correctly. The last 2 times the top exploded off and spread liquid through the entire kitchen. Thank god nobody was injured. I have went through...
All pressure cookers should have a release valve. Be sure that is clean and allows a free flow of steam when the weight is not on it. Test it with just water in the pot. Heat the water until its just about to boil (with the lid off) then close and lock down the lid. Steam should start to come out of the release valve. If not .. clean it again.
Dec 11, 2014 | Deni Crock Pots & Slow Cookers
Why is steam and water coming out of the safety valve of the Russel Hobbs preasure cooker
When a pressure cooker is working normally, some steam and a little water is supposed to come out of the valve, that's how you know it's up to pressure.
Aug 29, 2014 | Crock Pots & Slow Cookers
Steam is escaping from floating valve
It is supposed to. If steam did not escape it would explode
Apr 21, 2012 | Wolfgang Puck Electric Pressure Cooker...
Just bought the 5 Qt electric pressure cooker. Tonight is the first time I'm using it. Got two questions.....is the pressure release valve supposed to be so loose? I'm also seeing steam and condensation...
Your gasket is no good and needs to be repaired. The water is supposed to be pressurized as high heat steam and when pressure is excessive the valve does its thing to lower to acceptable levels.
Aug 31, 2017 | Wolfgang Puck Electric Pressure Cooker...
Steam coming out of floating valve on handle.
No. if the steam is coming out, the vent valve is not seated on the vent and pressure won't build up. Either remove the plastic cover from the vent valve or slide it up enough so that the valve seals on the vent. If you remove the plastic cap, you will need to manually tilt the valve to "quick-vent" the cooker. Watch out for steam burns! Should work fine after that. You need to unplug the cooker and re-plug it to reset the "E4" error message.
Jan 16, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
My Wolfgang Puck pressure cooker shows 'E4' in the display.
There doesn't seem to be any legit way of fixing this. I tinkered with the pressure sensors and valves, kicked the pressure cooker a few times, still the E4 error presented itself.
I was able to bypass the E4 error by completely bypassing the electronics and wiring the heater coil to get power whenever the pressure cooker is plugged in. It was a very simple job, anyone with any electrical experience can do this.
The only problem is that it is a safety concern as there is no way for the heater to turn off even if pressure is getting to be way too high. There may be a pressure relief valve in the lid but the heater coil won't shut off, so don't leave it unattended! But at least this way to you can still pressure cook.
Pics of process:
http://s909.photobucket.com/albums/ac295/danwat1234/fixing%20the%20pressure%20cooker/
May 10, 2009 | Wolfgang Puck 5-Quart Electronic Pressure...
Steam escapes from pressure cooker
the gaskets are junk , i had to toss one myself i used one time then stored for a year and the gasket went bad , mine came from hsn when i called them ,there where no parts made for it . so out it went cheep china junk . sorry , good luck
Jan 14, 2009 | Wolfgang Puck 5-Quart Electronic Pressure...
Crock Pots & Slow Cookers Logo
365 people viewed this question
Top Crock Pots & Slow Cookers Experts
tsalagi152
charles
Irene Tulloch
Are you a Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
