Question about Marantz PMD510 Single Cassette Deck
I just bought a used PDM510. Most everything seems to be in working order, however, I can't seem to enter record mode or hear audio through line inputs. I'm not sure if the machine is broken or if I'm doing something wrong! Any info would be very helpful. Thank you.
  • 24 Answers
To hear the audio fold back in prerecording mode you will need a tape that still has a security tab in it if not put some tape over the whole or even block the hole up
supply the tape unit with a good signal and then hold down the pause button and press the record and play button at the same time. you will then be able to monitor the sound you are about to record. use headphones as this to stops background noise in your ears and allows you to focus on the sound, "its another world inside your cans" adjust the input level until just peaking into the red. when you are ready to record leave the record button alone and the stop button and the play button just release the pause button and away you go. to stop press stop to stop recording say to cut out an advert or something just press pause.
Posted on Apr 09, 2011
Enter button not working
If this is a traditional keyboard (not laptop) or extremely fancy keyboard.
Try unplugging the keyboard. Then.
  1. Take a butter knife and slide it into the crevice next to the "enter key".
  2. Apply a small amount of pressure to pry the key upward.
  3. With little effort the key should pop off or slide off.
  4. Check the spot the key was for dirt, dust, food, etc. Clean it if you must. Make sure the actual key does not have anything stuck to the bottom of it.
  5. Push the key back onto it's place on the keyboard.
  6. Plug back in and see if that worked.
If this did not work, you may need to replace the keyboard OR you may want to make sure no viruses are playing an aweful trick on you.
Nov 22, 2013 | Roland Boss BR 900cd Digital Recorder BR...
Enter buttion not working
Hello, that seems to be a bad contact on the enter button, the solution is to take a part the key and clean it, otherwise you need to replace the under key switch.
Thanks
Line in / Mic jack help
So we're talking PC here, right?
I don't understand what you want to record. Going from the PC Headphone jack to the PC Line IN might be unwise in order to prevent a feedback loop. External (non-PC) source and PC MIC might work but you would probably want to monitor it on headphones again because of possibe feedback.
Does your MIC work?
Right click the speaker icon again and select Adjust Audio Properties or open Control Panel and select Sounds & Audio Devices. Select the box to place the icon on the Taskbar for future use.
Right click on the little speaker icon in your Taskbar and select Open Volume Control, if it's there. From there you're on your own. I have a sound card so I don't know what you will see. Look around, there may be a bunch of audio outputs and inputs with Master and individual volume & balance controls plus one for your Mic. Make sure it's not muted.
Apr 21, 2009 | Audio Players & Recorders
LG RHT397H DVD Timer record problem
Sorry used wrong site have moved to LG DVD forum. Ta
Jan 17, 2009 | LG Corbel A- Accessory Range Hood
LP audio recording seems to be at the wrong speed
1- The turntable is set to 45 rpm and the album is recorded at 33 rpm. Press the 33 rpm button the red light should come on turn the and be fine.
or
2- This turn table has a fast record mode where you can record a 33 rpm LP faster by spinning it at 45 rpm. If you are trying to use this mode you will have to make a software setting to tell the TTUSB10 digital converter program what mode you want to run.
Nov 29, 2008 | ION Audio TTUSB10 Turntable
SH-550T
The Camera has no speaker therefore you can't hear anything. I presume that when you play the recording back through your computer you should hear it through the computer's speakers.
Mar 18, 2008 | Audio Players & Recorders
Lambda doesn't record, though it seems ready to go
you need to go to the "control panel" on your computer.....click on sounds and audio devices, then hit the "audio" tab...make sure the lambda is selected on the recording and playback device....then apply...this should take care of it
Jan 16, 2008 | Lexicon Lambda Usb Desktop Recording...
Marantz PMD510 Single Cassette Deck Logo
146 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
