Question about Honeywell Heating & Cooling
We have just bought a house in Canberra with a Honeywell Thermostat to operate gas central heating system. There is no manual and we do not know how to programme it. I would guess that it is about 10 years old (beige, rectangular shape with digital screen). There is no model no. on it anywhere. Can you refer us to an instruction manual we could use please.
    Problem Solver:
  • 9 Answers
I have put many of those in and yes, they are hard to program compared to the new ones. You will probably not find any instructions unless you go on line to honeywell and ask. Otherwise it may be worth your time and less head ache to just go get a new thermostat even the ones at Home Depot are a lot easier.
Posted on Apr 09, 2011
Honeywell thermostat blows cold air on heat
Thermostats don't actually blow anything, the heating system might though. Check the breakers for your heat system, then call a heating specialist. They're really not that expensive.
Oct 06, 2014 | Honeywell Heat/Cool Thermostat
Replacing WHITE-RODGERS manual thermostat with 3 wires ( red, white, blue and installing Honeywell electronic thermostat RTH110B, how do I connect it? The heating is not central, baseboard heating.
I have only seen one Honeywell thermostat that would work with a 3-wire heating system.
I would replace it with a White-Rodgers 1F80-0471. They are about $100, but they are a good thermostat, and they work well with the 3-wire zone valves.
Most other thermostats have the "Y" terminal that you need, but do not control the zone valve correctly.
Helping Hands Services
- Fairbanks, Alaska -
Jan 30, 2010 | Honeywell Electronic Programmable...
Honeywell Central Heating temperature control
R comonY cool W heat G fan C other side of 24 unless you are battery operated. On the back of the Tstat tou should have switch that says gas or electric this controls how the fan operates. If not go into programing and program 1 stage heat one stage cool.Let me know I will walk you thru this.
Nov 18, 2009 | Honeywell Electronic Programmable...
St6400c thermostat wont run the central heating independantly
This does not sound like a thermostat problem. I would be looking for a zone valve or circulator pump problem.
Nov 05, 2009 | Honeywell Programmable Thermostat Heater
Wiring of gas central heating
you have a link pin on 3-4 or 1-5 or seperate 2 pin connector,thats were the stat goes,any way round with wires
Mar 05, 2009 | Honeywell Programmable Thermostat Heater
Forced Hot Air Heating system doesn't maintain thermostat setting
It sounds like you may have issues with the furnace. A qualified professional can go over the system and the house to let you know if the system and unit are properly sized. The poor performance of a furnace can be a sign of carbon buildup in the furnace.
Good luck, hope this helps.
Matt
Jan 10, 2009 | Honeywell Focus 6300B 5-2 Days...
Thermostat auto-changeover mode unavailable
when you programed it did you go through all the setup #1-0 ,#3-0 ,#5-5 ,#12-1
Nov 24, 2008 | Honeywell Electronic Programmable...
Honeywell Thermostat RTH 7500
Assumed all the wiring are correct,
to change from manual switching from heat to cool, press [system] button ( left ) to go into system setting.
then press and hold the [fan] middle button untill option display 120
use up down button to select option 300 ( Manual/Autochangeover) ,
select 0 for manual, 1 for automatic. ( read caution in page 22 of installation manual )
Good luck
Sep 30, 2008 | Heating & Cooling
Central heating thermostat
Looks like it was replaced by the CM67 series, try this link for the manual:
http://www51.honeywell.com/pacific/common/documents/CM67_User.pdf
Geno
Feb 29, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
130 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
