Question about Rain Bird Hardware & Accessories
I have installed the timer i have 4 wires to go into the 4 zones no wire to go in the master only one zone works??
    President:
  • 1,273 Answers
Do you have ground wires to each station in series? Without the grounds, the other stations will not work. Determine the ground wire at the working station. The power wire will correspond to the color of the wire on the terminal at the controller; the other wire will be the ground. The ground wire should continue to the next station, then next station, and so on.
Best regards, --W/D--
Posted on Apr 08, 2011
Why isn't the timer going off/changong zones?
Go to the Intermatic website and download the instructions. There may have been a design change. If possible, compare old and new instructions.
Jun 19, 2015 | Intermatic T8845PV - Sprinkler-Irrigation...
MVP short when put in run mode is the display . System will not function in manual or run at all. Thank you.
If the timer shorts out at the first zone (1) skip and test zone 2. and so on testing all the zones. If all short out, disconnect the wire in the "Comm" pin and start timer manually again, if it shorts out the problem is in the timer call the manufacturer. If it does not short out the short is in the white wire or whichever color was in the Comm pin. Look for a damaged section of wire from a shovel or other gardening equipment. If non found run a separate wire above ground from timer "Comm" pin to the same wires it is connected to at the valves if this works this your problem the common wire has a short suggest replacing entire stretch.
Jan 18, 2014 | Weathermatic SL1600 - SmartLine 4 Zone...
I have city reclaimed water source for my sprinkler system. My problem is I connected the waterlines to the solenoid (1) and then the zone index valve (4 zones ), then i wired the solenoid to my spr
What model number of timer? I have to see exactly which timer you have to answer question.
What wire goes where?
Are you using 120Volts?
What is output voltage of timer?
What voltage is solenoid? 24Volt or 120Volt?
Copy following links for Orbit manuals:
http://www.orbitonline.com/support/guides/Manualsearch3.cfm?Brand=02&Type=Timers
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
Aug 09, 2012 | Orbit Hardware & Accessories
Sprinkler timerwont change stations
Re-post question with model number so expert can read manual alongside you. Otherwise it is guesswork trying to match your description to a timer.
Copy following link for assortment of sprinkler timer manuals
Aug 08, 2012 | Hardware & Accessories
Hunter pro C will not allow all zones to water.
The fact that you are getting no error message indicates that programming is not right, or there is electrical short between timer and sprinkler solenoid:
With all digital timers, it is important to clear memory before starting, and then double-check there are no conflicts in programming.
Page 22-23 of the manual has quick-check procedure for identifying shorts that would cause problems.
Check outlet with circuit analyzer to check for correct polarity and grounding.
Google search Hunter Pro C manual to download searchable pdf manual
Keep in mind also that digital timers are susceptible to line noise, and power surge. Simple power outage can disable digital timer. There are no replacement parts.
That's why I recommend good old fashion 14-day repeat-cycle mechanical sprinkler timer with fewer features, but replaceable parts.
For example T8845PV with 24Volt ac output
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
http://waterheatertimer.org/How-to-wire-Intermatic-sprinkler-timers.html
http://waterheatertimer.org/How-to-wire-Intermatic-sprinkler-timers.html#T8845PV
Jul 15, 2012 | Hardware & Accessories
Wires were disconnected from timer and need to reconnect do not have manual
First, assume that the white wire is the common and connect that to the C terminal.
Then connect all of the other colored wires to station terminals, starting with terminal 1 until you are out of wires.
Then turn on zone one manually. If it works, note where it is on your property and turn on zone 2. Do the same until you have run all of your zones.
Lastly, move the wire connections on the terminals so that there is some order as to how the zones come on around the property.
If no zones run when you try to run zone 1, disconnect the white wire from the C terminal and try connecting the green. Try your zones again.
If none of this works, you need an electrical testing meter (multimeter) to determine which wire/wires are the common(s).
Gary
Apr 30, 2011 | Orbit 57882 9 Station Super Dial...
Rain Bird sprinkler timer blowing fuses
Disconnect all zone wires and see if timer blows fuses. If not, one of the zone valves is drawing too much amperage.
Oct 02, 2010 | Rain Bird 4 Station Single Program...
How do I test a specific Orbit Watering station without turning on the whole system?
I have done this in a couple ways. With a digital timer you can select a zone on manual and turn only that zone on. with a mechanical timer, you can set the dial to that zone and increas the duration. You can "hot wire" the zone by moving the zone wire to connect to the low voltage wire input to the zone. You can take a transformer out to the ground box and with an extention cord "hot wire " the zone at the ground box.
May 06, 2010 | Orbit 57882 9 Station Super Dial...
Orbit sprinkler system
Have you programmed the new one with all the info for date and time? Did you set the zones for the days you want and watering times?
Jun 16, 2009 | Orbit Sprinkler System Power Source...
Bought a Intermatic sprinkler timer. need help.
reading the specs i should say its a timer for only one zone. you can use it for one zone switching or for the pump. sorry.
May 09, 2009 | Intermatic & Indoor/Outdoor Rain Tight...
Hardware & Accessories Logo
93 people viewed this question
Top Rain Bird Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Rain Bird Hardware and Accessory Expert? Answer questions, earn points and help others
