Question about Amcor 3900 GPS Receiver
Need clip that attaches gps to mount stick - Amcor 3900 GPS Receiver
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 332 Answers
I looked on Ebay and found several items that match your request.
I hope this helps you out. Any positive feed back would be greatly appreciated.
Posted on Apr 08, 2011
I need instructions on how to mount the nuvi 200w to my windshield
To secure the nuvi 200w to your windshield with the included suction cup mount (pictured below),
center the GPS on the clip, and tip the bottom edge on the bracket. Push the top of the GPS against the top clip until it clicks into place. Hold the bracket and GPS near the windshield where you like it best. Note where the suction cup is on the windshield in relation to the mirror, etc. Remove the GPS from the mount's clip by pushing the top tab back from the top of the GPS.
Clean the windshield (or portion that the suction cup will be stuck against) with a paper towel or newspaper and ammonia solution like Windex, etc. Clean the suction cup with the paper towel and Windex, too.
Lift the lever at the base of the mount - is shown in the picture above - if it isn't already. With the mount oriented as shown in the picture above, press the suction cup against the windshield where desired with one hand. Hold the mount firmly against the glass and use your other hand to press the lever on the base back toward the suction cup and glass. Press until it lays flat against the base / suction cup. Plug the power cord into the GPS and reinstall the GPS in the mount clips as done earlier.
To remove from the windshield, release the GPS from the mount clips, and lift the lever away from the base / suction cup. Locate the tab that is connected to the suction cup edge near the lever. Pull on the tab away from the glass to break the suction seal and remove from the windshield.
If this was helpful, please rate it 4 thumbs up. Thanks & good luck!
Sep 20, 2011 | Garmin GPS
How do you attach the garmin clip on bracket to the ball of the stationary mount?
press them together firmly and quickly with the ball in the indented area, it will snap into place
Sep 03, 2010 | Garmin nuvi 205W GPS Receiver
Mount no longer sticks to windshield
Well a new mount suction cup will need to be purchased. you can grab one at radioshack.com you alsmo might want to wet the plunger then try to stick it. Or clean of that dirty windshield and try again.
2 solutions
1. clean the windshield and apply a little water to the back of it.
2. Buy a new suction cup.
thats all I hope you to stop by and rate it thanks.
Apr 16, 2010 | Tomtom ONE GPS Receiver
Won't stick to windshield
The suction cup mount should be attached on a clean, flat surface. If the windshield is too dirty or curved you'll have problems. Try first to find as flat spot as possible and then clean the glass with dish-washer liquid (the type you use for hand wash - not for the dish-washer machine) or similar agent.
Dec 27, 2009 | Tomtom XL 330 Car GPS Receiver
Do i use both the hard plastic adhesive disc or just the one that holds the tomtom to fix onto windscreen.Mike.
The disc is for attaching your unit to the dash. On the glass, you just need to stick the mount to it. Make sure the glass is perfectly clean or the mount and GO720 will eventually fall off. Also the oem mount is just a general pain at best. I went with an aftermarket mount to eliminate the problem.
Nov 20, 2009 | Tomtom GO 720 GPS Receiver
How do you attach a garmin portable friction mount to a garmin nuvi 780?
Your 780 should have came with a plastic bracket that clips onto the back of the unit and the ball of the mount goes into the back of the bracket. Hope this helps!!!
Sep 21, 2009 | Garmin Portable Friction Dashboard Mount...
Windshield Mounting Unmounting
first the round plate... that has a sticky circle on the bottom.... you remove the tape and stick it on a surface where you want the gps... then when you want to mount the gps you suction cup it to that disk. now for the suction cup... when it is disengaged the plastic suction cup will be loose. to attach it to the plate or window... you swing the small arm on the base of it up or down... you will see as it will lock the suction... the gps should clip onto the holder so you can leave the holder where it is and remove the gps and slip it into your pocket.
Not the best instructions but you will get the idea
Robert
Please take a moment to rate this solution thanks
Jan 24, 2009 | Tomtom XL 330 Car GPS Receiver
Assembling nuvi 760
Attach the window mount to your GPS unit ...it clips into the bottom. Insert the power supply into the mount on the right side. Of course plug it in to your power supply in your vehicle that is hot or turn on your cars power supply
Dec 08, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
I recently got a new car and had to transport my GPS to my my new car. Problem is the mount that you put on the dash will no longer stick to it. How do I fix this problem?
Hello Hoshiko,
You don't say what kind of mount you are using. There are a couple different kind. One kind uses an adhesive (like double sided sticky tape) to secure the mount to the dashboard. For this kind of mount you can simply purchase some new adhesive tape to apply. This is available from most hardware or electronics stores.
The second type of mount uses a suction cup type device to secure the GPS to the dashboard. For this type you will want to make sure you are attaching the mount to a smooth, nonporous surface. Make sure that the area you are attempting to afix the suction cup to is clean and dry. Make sure that the suction cup itself is clean and moisten it with just a little bit of water before attempting to get the mount to stick.
If you still can't get the mount to stick to the dashboard you might need to look at other mounting options or purchase a replacement mount.
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 24, 2008 | GPS
Problems with the window mount that comes with the Garmin 360
You just have to push the ball part on the window mount into the socket part that holds the GPS. It's pretty tight, so you have to press pretty hard.
Apr 28, 2008 | Garmin nuvi 350 GPS Receiver
Amcor 3900 GPS Receiver Logo
23 people viewed this question
Top Amcor GPS Experts
Martin Murray
Donald Ayers-Marsh
Are you an Amcor GPS Expert? Answer questions, earn points and help others
