Question about Daewoo Microwave Ovens
How do I replace light bulb - Daewoo Microwave Ovens
  • Daewoo Master
  • 6,993 Answers
Do you mean you want to replace light bulb for your microwave? If yes follow the instructions below;
  1. PLEASE UNPLUG YOUR MICROWAVE!
  2. Picture of your microwave with a phone or camera so that you don't forget how to assemble it back.
  3. Remove the two screws that holds grill. They are located at the edge of the unit. Once the screws are out, rotate the grill forward from the top. It will pop right out.
  4. Once the screws are out, rotate the grill forward from the top. The grill should pop right out.
  5. Locate a small access cavity on the left.
  6. Remove the screw that is located near the front of the microwave door.
  7. Lift up the sheet metal floor to access the bulb. The bulb is located under the sheet metal "floor" on the left.
  8. Place a flash light on the microwave floor and shine the light in the light area. This will help you see better when you replace your bulb.
  9. Look for a small shiny reflector that hides the bulb. Use your two fingers to squeeze it a bit. Making sure not to bend it.
  10. The bulb connection should come right out.
  11. After you replaced the bulb, re secure the reflector and the sheet metal floor with the single screw. Test the bulb by plugging in your microwave.
  12. Once you see that the bulb works. Unplug your microwave again and re attach the front grill. You are now done.
I hope this helps to solve your problem.
Good luck.
Posted on Apr 08, 2011
How do I change the light bulb in a magic chef microwave?
  1. Unplug the Magic Chef microwave from the wall outlet.
  2. Remove the screw from the light cover located on the left side of the underside of the microwave. ...
  3. Unscrew the light bulb, then screw in the new light bulb.
  4. Raise the light cover, then secure the cover with the screw that was originally removed.
More items...
How to Replace a Magic Chef Microwave Light Bulb ' Hunker
https://www.hunker.com/13407988/how-to-replace-a-magic-chef-microwave-light-bulb How do change the light bulb in magic chef microwave Google Search
Oct 24, 2017 | Magic Chef Microwave Ovens
How to replace light bulb in microwave model MMV5208WW-1
The support page with free manuals is here.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=MMV5208WW1&siteCd=WHRCOM&userType=Consumer
The owner's manual says:
Cavity light: The cavity light bulb is located behind the vent
grille at the top front of the microwave oven, under the bulb
cover, and is replaceable. Remove two screws on the vent
grille, tilt the grille forward, and lift it out. Open bulb cover and
replace bulb. Close bulb cover, replace vent grille, and secure
with screws.
Cooktop light: The cooktop light bulb is located on the
underside of the microwave oven, and is replaceable. Remove
bulb cover screw, and open the bulb cover. Replace bulb,
close bulb cover, and secure with screw.
To remove the grille, see my video at microwavecontrol.com.
Sep 28, 2016 | In Microwave Ovens
Replace light bulb.
http://www.ehow.com/how_7614605_replace-chef-microwave-light-bulb.html
Here is one link that i've found. It didn't mentioned the exact model but i hope this one helps...
Mar 07, 2015 | Magic Chef CMV1000B Microwave Oven
How do i replace the light bulb in my maytag microwave oven. the bulb broke in the socket.
The cooktop light bulb(s) is(are) located on the underside of the microwave oven, and is(are) replaceable. Remove bulb cover screw, and open the bulb cover. Replace bulb, close bulb cover, and secure with screw. Cavity light: The cavity light bulb is located behind the vent grille at the top front of the microwave oven, under the bulb cover, and is replaceable. Remove 2 screws on the vent grille, tilt the grille forward, and lift it out. Open bulb cover and replace bulb. Close bulb cover, replace vent grille, and secure with screws.
For more information, your owners manual can be viewed here (scroll to the bottom of page 4):
Maytag MMV1164WB Owners Manual Page 4
Feb 11, 2015 | Maytag MMV1164WB Microwave Oven
Replace oven light bulb in FMV 156D
Hello Jim Rogosheske - To replace light bulbs, first I suggest disconnecting power to the microwave oven at the circuit breaker panel or by unplugging. To release cover, remove the screw on the light cover. Replace light bulbs with equivalent watt bulb available from your manufacturer or a parts distributor that they recommend. Bulbs are also available at most hardware stores or lighting centers. However, it is not recommended to use a bulb larger than 30 watts. Close light cover and secure with screw that was previously removed to release cover. Be aware that light cover may become very hot. Do not touch glass when light is on.
Oct 11, 2012 | Frigidaire FMV156DC Microwave Oven
How to halogen light bulbson my microwave JVM3670Sk03 I have changed one I know there is another one how do i change it please advice thanks anna
That's covered on pages 35 & 36 of your owner's manual.
If for some reason you don't have yours, you can download it here.
Cooktop Light/Night Light
On models JVM1850, JNM1851, DVM1850 and
EMO4000, replace the burned-out bulb with a 120 volt,
40-watt incandescent bulb (WB36X10003), available
from your GE supplier.
On models JVM1870, JVM1871, JVM2050 and
JVM3670, replace the burned-out bulb with a 120 volt,
20-watt halogen bulb (WB36X10213), available from
your GE supplier.
To replace the bulb(s), first disconnect the
power at the main fuse or circuit breaker panel
or pull the plug.
Remove the screw at the left edge of the light
cover and push on the right edge of the cover
to open.
Be sure the bulb(s) to be replaced are cool
before removing. After breaking the adhesive
seal, remove the bulb by either gently turning
(for models JVM1850, JNM1851, DVM1850 and
EMO4000) or pulling straight out (for models
JVM1870, JVM1871, JVM2050 and JVM3670).
Replace with the same size and type bulb.
Raise the light shield and replace the screw.
Connect electrical power to the oven.
Oven Light
Replace the burned-out bulb with a 120 volt, 20-watt
halogen bulb (WB36X10213), available from your GE supplier.
To replace the oven light, first disconnect the
or pull the plug.
Remove the top grille by taking out the screws
on top of the grille that hold it in place and
sliding the grille to the left (opening the door
makes grille removal easier).
Next, remove the light cover.
On some models, the light cover is located
in the center of the top opening. Remove the
screw that secures the light cover and lift the
cover off.
On some models, the light cover is located at the
left of the top opening. Lift the cover off.
Pinch the clips that hold the light socket in
place and lift the socket out.
Remove the bulb from the light socket by
pulling straight out. Replace with the same size
and type bulb, then replace the light socket and
cover.
Replace the grille and screws. Connect electrical
power to the oven.
Jun 08, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Replacing light bulbs?
Replace the burned-out bulb with a 120 volt, 30-watt incandescent bulb (WB36X10198), available from your GE supplier
  • 1 To replace the oven light,
first disconnect the power at the main fuse or circuit breaker panel or pull the plug.
  • 2 Remove the top grille by
taking out the 2 screws that hold it in place.
  • 3 Remove the charcoal
filter (if present) to access the light cover (see Remove Charcoal Filter section).
  • 4 Remove the light cover
located near the center of the oven that holds the bulb. Remove the bulb by gently turning. Replace with the same size and type bulb.
  • 5 Replace the light cover
and charcoal filter (if present).
  • 6 Replace the grille and
screws. Connect electrical power to the oven.
The full owners manual can be found here: http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40474.pdf
Mar 07, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Replacing surface light
That's on page 33 of the owner's manual. If you've misplaced yours, it's archived online here.
Cooktop Light/
Night Light
bulb with a 40-watt
incandescent bulb
1 To replace the bulb(s),
plug.
2 Remove the screw from
light cover and lower
the cover.
3 Be sure the bulb(s) to be
replaced are cool before
the adhesive seal, remove
4 Replace the screw.
to the oven.
Oven Light
bulb with a 40-watt
incandescent bulb
plug.
3 Next, remove the screw
located above the door
oven that secures the
light housing.
to the oven.
May 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
How do i change the bulbs on a jvm1870sk03 microwave
That's covered on pages 35 & 36 of the owner's manual here.
your GE supplier.
or pull the plug. *
to open.
Oven Light
GE supplier.
or pull the plug.
cover off.
cover.
power to the oven.
* If your control board was damaged (lights won't come on, won't go off, fan or turntable not working right) after a cooktop light bulb blew or was inserted or removed while power was on, see here.
Apr 25, 2010 | GE JVM1870 Microwave Oven
Have an installed GE Microwave jvm1870 with a burned out oven bulb. Have replacement bulb but can not see how to get to the old bulb to replace it.
From the owner's manual:
On models JVM1850, JNM1851, DVM1850 and EMO4000, replace the burned-out bulb with a 120 volt, 40-watt incandescent bulb (WB36X10003), available from your GE supplier.
On models JVM1870, JVM1871, JVM2050 and JVM3670, replace the burned-out bulb with a 120 volt,
20-watt halogen bulb (WB36X10213), available from your GE supplier.
To replace the bulb(s), first disconnect the power at the main fuse or circuit breaker panel or pull the plug.
Remove the screw at the left edge of the light cover and push on the right edge of the cover to open.
Be sure the bulb(s) to be replaced are cool before removing.
After breaking the adhesive seal, remove the bulb by either gently turning (for models JVM1850, JNM1851, DVM1850 and EMO4000) or pulling straight out (for models JVM1870, JVM1871, JVM2050 and JVM3670).
Oven Light
Replace the burned-out bulb with a 120 volt, 20-watt halogen bulb (WB36X10213), available from your
GE supplier.
To replace the oven light, first disconnect the power at the main fuse or circuit breaker panel or pull the plug.
Remove the top grille by taking out the screws on top of the grille that hold it in place and sliding the grille to the left (opening the door makes grille removal easier).
On some models, the light cover is located in the center of the top opening.
Remove the screw that secures the light cover and lift the cover off.
On some models, the light cover is located at the left of the top opening.
Lift the cover off.
Pinch the clips that hold the light socket in place and lift the socket out.
Remove the bulb from the light socket by pulling straight out.
Replace with the same size and type bulb, then replace the light socket and cover.
Jun 26, 2009 | GE Microwave Ovens
Microwave Ovens Logo
262 people viewed this question
Top Daewoo Microwave Ovens Experts
William Miller
William Miller
Ian Summerfield
Ian Summerfield
Are you a Daewoo Microwave Oven Expert? Answer questions, earn points and help others
