Question about Honeywell Strong Alarm Sa-avd1 Auto Dialer Ademco, Dsc, Ge, Lk
I have purchased an SA-AVD1 Auto Dialer and hooked it up to an ADEMCO alarm system I connected the yellow+ and green- to terminals 3 and 4 (horn output) and red+ and black- to terminals 4 and 5(+). It goes into self test mode (I think) counts down to 1 then a 5 appears. I programmed it for 2 phone numbers. I pressed "test" on the ademco panel to test the alarm (horn). I did not receive a call on my cell (programmed number). The display on the dialer shows a lowercase zero blinking and I can hear a relay actuating. Is there any way I can send the number by typing in a code on the dialer? At least this way, I can see if it is dialing out. Also there are lights (A to D) Are these supposed to light corresponding to phone numbers programmed in? They don't have any online documentation that I could refer to or a phone number for support?
SOURCE: this is a ademco 4110xm system with 2 wired motion
i can
Posted on Jan 30, 2009
  • 78 Answers
SOURCE: ademco security system every few min the carbon monoxide two beep
This could also be the ADT C.O. detector. they onlt last 5 Yrs. At that point they will beep every 5min nothing will display on keypad. Unit needs to be replaced.
Posted on Oct 11, 2009
  • 10 Answers
SOURCE: ADEMCO alarm system indicates A/C not ready.
Turn the alarm off two times. If it still indicates A/C not ready, press the * key and it will tell you what zone is open or what zone has a low battery.
Posted on Jan 19, 2010
  • 10 Answers
SOURCE: our Ademco 6160 PL3 alarm system keypad has an error message
It is located inside a tan colored metal box 12"wide by 15" tall and 4" deep; unless it is flush mounted, then only .5" deep. inside you will most likely find a 12 volt 4 or 5 or 7 amp hour battery. Note; the door may have a lock on it. I have found the key on top of the box, in the lock, and unlocked. The box could be located anywhere but, many times in closets, utility rooms, garages, crawl spaces, etc.
  • 13 Answers
SOURCE: HOW TO CONTACT PHONE WIRERS TO A ADEMCO WIRELESS
Go to your favorite search engine, Google or whatever, and use the phrase "Ademco Lynx Installation Manual". It has the instructions you need. You may have to look through 5 or 6 hits, but you can download the manual for free.
And please stop shouting. ;-)
Posted on Oct 09, 2010
1980 P-30 chevy wiring schematic for horn
Locate horn relay(under dash)
3 wire connection--terminals are marked 28, 29, and 240
28=Black Wire- to horn ring (colomn)
29= DK Green Wire- to horn(s)
240= ORANGE Wire- to B+
Dec 07, 2013 | Vehicle Parts & Accessories
The system randomly beeps
If it is wireless, then one or more of the switches need a new battery. I suggest replace them all and mark the date inside the box. I assume that there is no yellow triangle showing on the alarm panel. Triangle is for no phone connection.
May 28, 2017 | Ademco 1 Ademco 6150 6150pl3 6150pl2...
Ademco-749 speaker how to install
There are 4 wires on the 749. Two white and two black. The two black wires connect to the bell or siren output of your alarm panel. The 649 needs 6 to 12VDC to work. The two white wires are for a built in tamper switch that can be connected to a zone on your panel if you want.
Hope this helps
Mar 17, 2011 | Honeywell | Ademco Speaker/Horn 749
6160 key pad "open circuit"
open ckt on the keypad refers to the data lines going to the keypad. check to make sure the yellow and green wires from keypad are properly connected.
Feb 17, 2011 | Honeywell Ademco 6160 Alpha Keypad Vista...
The horn honks when I reconnect the battery
If the horn only honked once it may be a symptom of your car alarm being set off after power has been re-applied. If the horn stays on after you reconnect the battery you have either a stuck horn button on your steering wheel or a stuck horn relay. Or it could be the alarm sounding the horn but that usually that occurs in a series of horn blasts (rather than continuous) and the car indicators usually flash in sync with the alarm sounding.
If the horn is stuck on in a continuous blast ie not sounding on and then off and then on etc etc, disconnect one the battery cables then pull the fuse that feeds the horn or pull off one of the removable spade electrical connectors from one of the 2 terminals on the horn itself. Usually the fuse box is either under the dashboard on the drivers side or could be under the hood. Consult your user manual for your car for fuse and horn locations.
If the horn is stuck you need to visit a qualified auto electrician, or perhaps you have a friend who knows his way around auto electrics?
Cheers,
Steve (Melbourne, Australia)
May 12, 2010 | 2002 Acura 3.2TL
Telephone disconnected from first alert professional alarm system
The phone wires run from directly from the telephone company connection to the alarm on the red and green. They return on the other two wires. These wires are hooked to your home phones. That's the UL way to do it. The alarm is supposed to be the first device on the telephone line. You can just run a phone line to the alarm panel. There probably is a diagram inside the cabinet door or a phone jack very near the alarm.
Apr 11, 2009 | First Alert SA302 Dual System Smoke...
How to hook up my car horn to my alarm
Your tech is mistaken. The brown/white wire will hook directly to the lt.green/blue wire at the steering column in your car. Might require some programming at the alarm module.
Jan 12, 2009 | ' II' DIY Car Alarm Vehicle Anti-theft...
It will not burn it up take the two wires from the siren and tape 2 wires of that and run them to your 2 horn wires and tape into the horn. Thats what i did and i havent had a problem since.
Jan 12, 2009 | Toyota Vehicle Parts & Accessories
I installed the honeywell vista 15p and everything works, but I connected the comet pet PIR and can't get the led light to come on eventhough the system says ready. I'm not sure i connected it right. I...
http://www.sourcesecurity.com/docs/fullspec/Comet_PIR-PET.pdf
Leave a short jumper wire between the tamper terminals.
Connect red to +12v and black to -12v on the Motion Detector.
Connect red to Terminal-5 and black to Terminal-4 on the Vista-15P
Connect Green & Yellow to the alarm terminals on the Motion Detector,
Connect Green & Yellow to the desired zone on the vista panel, be
sure to add in your EOL 2K resistor (if using them) in series along
either the Green or Yellow, preferably at the motion, but can be in the
panel box if it's not a "high security risk" install (most residential
systems have them in the box, although any security professional
will say it's not "proper" but go ahead and check other boxes, you'll see).
I think BRINKS is the only one to do the true "end of line" procedure,
but it's a royal pain in the @$$ if you ever change panel types, you have
to pull every wired sensor out just to change the resistors, and if it's a
prewire (put in when the house was built) it's nearly impossible without
rendering the wire run useless unless there's a lot of slack on the line.
Check your vista installers manual for the rest! Good luck!
http://www.alarmeengros.com/installation15P.pdf
Sep 05, 2008 | Honeywell Programmable Thermostat Heater
Honeywell Strong Alarm Sa-avd1 Auto Dialer Ademco, Dsc, Ge, Lk Logo
119 people viewed this question
Top Honeywell Home Security Experts
Sean
Mike
Are you a Honeywell Home Security Expert? Answer questions, earn points and help others
