Question about Troy-Bilt Pony Garden Tiller
Need a manual for a 183631 21A 640071 /sn 1L204KS0033 Also,the wheels are stuck on the axle will not freewheel, from rust. how to free up?
Why did my front drive line free wheel before chaning out the tranny ,and now it will not free spin at all
if trans changed out and no movement and front is not freewheeling did you check and or dropped out the transfer case to check if stuck damaged or engaged ---or the new transmission is operational ---check the 4x4 actuator to see what position it is in or pull it out and check if damaged or stuck --lastly have you pulled the covers off the front and rear axles to make sure their nor frozen or damaged -do the transfer case check first disconnect the front driveshaft and check for freewheel do the same with rear driveshaft and rear with axles off and transmission in neutral try to turn tailshaft of transmission than try yoke of transfer case if any of these units dont move than thats where you check for problem
Jun 07, 2016 | Cars & Trucks
Detailed answer on why my truck wont move in ant gear, or 2wd or4wd after replacing the tranny in 99 4x4 silverado newlight-duty truck
I have a go go elite traveller plus , the battery pack will not lift off my scooter it seems to be stuck , i need to replace the batteries
The manual for this scooter is at http://www.discovermymobility.com/store/scooters/summit-scooters/elite-portable-scooter/manual.pdf
The closest info I can find is page 14. MOVING AND TRANSPORTING YOUR Easy Travel Elite
6.1. Moving Your Easy Travel Elite in Freewheel Mode when unfolded:
The Freewheel switch (Fig. 1/17) is used for releasing the brake and moving the Easy Travel Elite without operating the motor. Before activating, make sure your Easy Travel Elite is switched on. Turn Freewheel switch to the "freewheel" position and push or pull the Easy Travel Elite manually.
NOTE: The Freewheel mode can only be activated after the battery is in place and the power switch (Fig.9/1) is turned on. Doing otherwise will cause a fault situation indicated by rapid flashing of the Indicator light (Fig. 9/4). See section 4.2.
WARNING: The Freewheel switch should never be engaged on a slope.
CAUTION: The seat back must remain in the upright position.
They seem to assume removal is obvious, I would check any connections from battery to scooter are pulled out and that freewheel mode is not engaged.
Oct 07, 2013 | Pride Mobility Products Go-Go Elite...
What does free wheeling hubs do i have lots of noise comming from them while in two wheel drive
Free wheeling hubs are installed on the hubs to engage the axle and lock to the hubs making them turn. When you disengage the hubs (freewheel) the axle is not driving the hub hence you have effective 2 wheel drive I suggest you check wheel bearings or make sure that they are in fact disengaged properly
Jan 29, 2013 | Cars & Trucks
How do I remove a stuck rear axle on 1982 Yamaha TX 750
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Xj650 Maxim 81 removing rear wheel
http://www.r6-forum.com/forums/51-how-tos/294129-how-remove-stuck-rear-axle-07-r6.html
Yamaha TX 750 1974 service manual DOWNLOAD FREE FULLMANUALS COM
OEM parts for Yamaha
2results for yamaha tx750 owners manual
Jul 29, 2012 | Yamaha TX 750 Motorcycles
Rear sprocket turns but the wheel does not engage the bike is a 26" cruiser windwood model. looking for a exploded view of the rear axle
The freewheel has little arms that are spring-loaded and should engage teeth that would drive the wheel. This is exactly like a ratchet wrench. The problem is that those little arms (there are probably two of them) are either broken or they are too dirty to move. You can spray WD-40 into the groove that is about 1.5 inches in diameter. This may work to free those little arms. Or you should just buy a new freewheel. It is unlikely that you will be successful in disassembling the freewheel without special tools. Try this link for some information about freewheel removal and service. http://www.parktool.com/blog/repair-help/categories/cassette-and-freewheel-service good luck, AL K
Sep 01, 2011 | Cycling
We have a elite traveller 4 wheel and have just washed it. We have left it to dry ans just turned it on to use it and it is letting out one continious bleep. Can you please let us know what to do?
Take it out of freewheel and see if it will work Next time just wipe it down with a damp cloth instead of washing Washing can cause the brake to rust on the motor case and thats not good also will rust hubs to axles and you won't be able to replace the wheels when they wear down Hope this helps
Jun 26, 2011 | Pride Go-Go Elite Traveller 4-Wheel Travel...
How do you get it to free wheel? when you have to move from place to place
That's tricky... some of the small TB will not free wheel and either have to be "drug" from place to place or start up and drive it. Some allow to freewheel by pulling the pins on the wheel hubs, pushing the wheels "in" and reinstalling the pin. This allows the hub to "freewheel" on the axle and the pin just keeps the wheel from falling off. Hope this helps.
Mar 07, 2011 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Hello could you please advise on how to get the back wheel sprocket off. thanks tony
Depends on whether it is a freewheel or free hub.
For a freehub, you need a chain spanner -- basically a long lever with chain on it to hold the large sprocket while you use a second one to unscrew the smallest cog. Once that is off, all the other cogs slide off.
For a freewheel (usually only on older bikes), if you look inside the smallest cog, you'll see some sort of a recess. On Suntour it would be 2 recesses to accept a 2-pinned removal tool. For Shimano, it is a splined remover that fits around the axle. Insert the freewheel removal tool, use the Quick release to hold it in place, and a large wrench to unscrew the freewheel. In this case the entire freewheel comes off in one piece. Once off, you can use the method for the freehub to remove the outer cog and each successive inner cog. Often it is easier to put the removal tool in a vice and turn the wheel rather than use a wrench.
Feb 28, 2011 | Cycling
The rear wheel is in free spin in both directions,
If the problem is that the wheel can spin silently in either direction (without the normal ticking sound when it spins forward) then the problem is that the ratchet pawl(s) are either broken, or stuck. You might get lucky and can free it by spraying WD40 into the the freewheel. If that doesn't work you'll have to replace the freewheel.
Dec 29, 2010 | Cycling
Troy-Bilt Pony Garden Tiller Logo
127 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
