Switches on getsound and picture for about 20 seconds then sceen goes blank. Have tried switching off and unpluging leaving for 10 mins then pluging back in and swiching on and waiting for disc to initialise but samething happens
    President:
  • 1,623 Answers
A component inside the tv is causing a short, which in turn , is causing the protection circuit in the tv to shut it down. It could be a lot of things which are causing it, but it definately sounds as though, to me anyway, that is the cause. It could be something like a failed capacitor on the power circuit, or it maybe a IC that has a dry joint, the only way to know for sure would be to open the tv and check, not advisable if you are not trained to do this. There are high voltages in these tv's that can seriously hurt or even kill somebody. If you want you could open it and just check for bulging capacitors. they look like this
good caps look like this
to test other components would require a multimeter and a service manual to get the correct readings to check for.
Next time you ask for help though a tip would be to supply the make and model of tv in your question
If you found this info useful please vote for me
Posted on Apr 08, 2011
My pioneer plasma tv in standby mode and wont turn on
Try restting it by unplugging the tv for a few mins and it should rest to original factory default settings but leave it unplugged 10-15 mins to be sure.
Dec 18, 2011 | Pioneer PDP-4270HD 42 in. Plasma...
When you switch the TV set on, the picture comes up for a second or two then the set turns it's self off onto standby
It sounds like you have a power / short issue. You will probably have to get it looked at and serviced, but you could try plugging it into another power outlet in the house, but first leave it unplugged for about 10 min.
Chris
Aug 15, 2011 | Computers & Internet
How do i logon can't remember
the login for belkin routers is usually 192.168.0.1 and you don't normally need a password
Apr 11, 2011 | Belkin (F5D8231-4) Wireless Router...
Samsungh LA40B530 No picture but sound
try connecting tv to cable direct also try unplugging both converter and tv for wile like 5 mins plug both back in see if tv and converter sync, but if otherwise then
The ysus board is the most common reason.
you can try websites on ebay.com to buy parts for replacement...
Aug 03, 2010 | Samsung LA40B530 40 in. HD-Ready TV
Lcd32880hdf 10 months old. When switched on the picture disappears after 2/3 seconds and will not come back on. Sound still remains un-effected.??
If you can quickly get to menu before picture goes blank, then go picture / backlight / set backlight to minimum and it will work fine.
Jul 04, 2010 | Albatron LNX-21TIS-3 Television
Camera switching on ok but lcd sceen blank
Your problem can be the result of a number of causes - two common ones I will list here.
Most common cause would be a failed printed connecting cable between the main camera electronics and the flip out display panel. This special cable passes through the display hinge and is sometimes subject to failure.
A second possibility is a faulty display backlight.
You can check that the camera is still producing video output by using the AV cables conected to a TV display with the camera set to CAMERA mode.
I trust that this information is of assistance. RHN
Jan 02, 2010 | Sony Video Cameras
Monitor displays the PC screen but switches off within 10 second
Unfortunatley your monitor is going out. I just had that problem. My sceen would come on, but after about 10min. it would blink off and turn black. I would have to hit the off button on the monitor, then turn it back on. It would work fine for a few minutes then black out again. I got a new/used monitor where I no longer have that problem.
I did check to make sure my hybernate was not activated, it wasn't, I had it set to never turn off.
Good luck.
Sep 02, 2009 | Rosewill R900J 19" Flat Panel LCD Monitor
Astar 32 in LCD
Have check internal power board? any way just call me at
323-767-6030 I will help you go through as much as I can to power up your tv.
Feb 09, 2008 | Astar LTV-20PW 20 in. EDTV-Ready LCD...
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
