Question about Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener
The keypad doesn't open or close the garage door any longer. I replaced the battery but it still doesn't work. what should I try next?
  • 591 Answers
Have you tried the default code??, (refer to manual)
Posted on Apr 08, 2011
The garage door remotes and keypad works only when i,m very close to opener, will not work at more then 6 ft away from opener. sears hbw0777
How old are the batteries in the remotes and keypad? Replace the batteries. If that helps, then you have solved the problem.
If it doesn't help, then check the antenna wire of the opener. (Make sure it is extended down from the unit.) Note this doesn't apply to all garage door openers. (We have several models - some with the external antenna and some without.)
Does your garage have metal walls and metal doors? This can shorten the range between the receiver and the remotes or keypad. An antenna extension may be available.
I don't see the HBW077 as a model number at Sears Parts Direct or Manage My Life. Please check the model and let me know if I can provide any additional assistance. (Sears Parts Direct has parts for my garage door openers. Manage My Life has manuals for Craftsman and Sears appliances.)
I hope this helps.
Aug 04, 2011 | Garden
Craftsman 1/2 HP Model 139.53914 The wireless outdoor keypad will not open the garage door but it will close it. The two garage door openers work just fine and the indoor keypad works fine. Replaced the...
Sounds like it has lost signal strength and the door cuts it down to the point that the receiver never gets the signal when the door is in the way. If it did that before you replaced the battery then you will have to replace the keypad.
Dec 08, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a Chamberlain Liftmaster Professional 1/3 hp garage door opener. I'm unable to find the model number, but it was made in April 2004 and has an orange learn button. It has been working fine since...
Do you mean the numeric keypad is no longer controlling the garage door? If so, have you changed the battery for the keypad? Frequently, if the battery is low, the keypad will stop working when the door is closed but works to close an open door. On most Chamberlain garage door openers, this is a 9V battery. You may need a small Philips screw driver to open the battery compartment at the bottom of the keypad.
After changing the battery, try the learn code procedure again. I've found it easiest to have two people involved when programming the keypad to the garage door opener. One handles the Learn button and the other types in the desired code.
I hope this helps.
May 22, 2017 | Vacuums
Remote Control closes garage door but does not open
It sounds like a case of your keypad losing signal strength enough that it cannot transmit through the closed door. If a new battery doesn't do the job a new keypad will.
Sep 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door will only close with keypad code it will not open
UNPLUG THE UNIT AND WAIT 5 MIN.
WHEN YOU PLUG IT BACK IN CLAER ALL CODES BY HOLDING DOWN THE PROGRAM BUTTON FOR 20 SECONDS.
NOW TRY TO PROGRAM EACH REMOTE AND KEYPAD - IF THERE IS STILL A PROBLEM CHANGE THE BATTERIES AND REPEAT THIS PROCEDURE.
I HOPE THIS HELPS
Mar 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Keypad will close the door but not open it
u have to push right side of enter button 3 to 4 times
Feb 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Keypad only works when closing door
MANY OF THE NEWER UNITS WILL CLOSE FROM THE KEYPAD WITHOUT PRESSING THE CODE - OR USING THE WRONG CODE.
WHEN YOU REPLACE THE BATTERY YOU MUST REPROGRAM THE KEYLESS TO THE OPENER.
HOPE THIS HELPS
Oct 26, 2008 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener Logo
244 people viewed this question
Top Chamberlain Car Audio & Video Experts
Glenn Mayer
Glenn Mayer
Vince Heuser
Are you a Chamberlain Car Audio and Video Expert? Answer questions, earn points and help others
