Question about Skull Candy Double Agent Stereo Headphones in Green Ships in ''24'' Hours
Im trying to fix my headphones a friend ruined. there is a red gold and blue wire on the inside of the left headphone. where do the wires go?
  • Skull Candy Master
  • 5,487 Answers
If you click my user name you will find a tip about headphones and wiring them up.
Posted on Apr 22, 2011
Sennheiser head-phone cable problem?
This should help, skip to the part where he starts soldering the parts
http://www.youtube.com/watch?v=OhnXUQRQ4u4
Feb 17, 2013 | Sennheiser HD428 Stereo Headphones
Sennheiser HD 205 Headphones. My cable has had its fair share of pulls and tugs over time and finally the left ear stop working. By fiddling with the cable i was able to get sound from the left ear, but...
Hi, Ian, If you have soldering experience, you might be able to replace it by yourself. If you remove the portion of the wire that is frayed and replace it with new wiring, it might work. If you feel comfortable doing this, I would say go ahead. However, it might be just as cost-effective to take it to a local audio-repair shop and have them do it. I have had multiple sets rewired myself, and it has cost less than $20 each time. Either way, it should be a relatively easy and cheap fix.
Feb 25, 2011 | Sennheiser HD 205 Professional Headphones
I need to replace my headphone plug end
See my tip on replacing dodgy cable and plugs on headphones.
May 26, 2010 | Sony MDR-V150 Professional Headphones
I have to replace the plug on my headphones. I have stripped both wires and found that there are two wires on each side. Am I correct in assuming that the gold wires on each side are the ground wires and...
Yes that's correct! The Red will be right and Green left. You might have to scrape the wire ends with a Stanley Knife to get solder to stick. It's best to apply solder to the wires first. I find that a bit of spit helps to get the solder on to the wires.
Jan 02, 2010 | Sony MDR-V150 Professional Headphones
The headphone jack that goes into the device broke off. Can the wires be soldered back on? If so I see three colors. Red, Blue, and bare copper. Which one goes where on the jack. Do they sell replacement...
Red is for the left speaker, blue for the right and the copper one is the ground. Replacement 3.5mm jacks should be available at all hobby shops. Solder it yourself; the left wire goes to the central connection.
Nov 30, 2009 | Skull Candy Lowrider Headphones
Replacing headphone connector
The impedance or resistance of the two different sets of wires might be different. The higher the impedance the less signal. If your cable is long enough you are better off spending the five or so dollars for a new plug. Red is right, green or blue is left and copper is ground.( Usually) Unfortunately not all manufacturers agree. Also what could have happened is a short between the wires that you soldered.Make sure they are physically separated from each other and insulated.
May 14, 2009 | Sennheiser PX 100 Consumer Headphones
Left side of stereo earphone does not work.
In side of your left wire there are two tiny coper wires (either blue/green/Red and gold) one of which is easily cut off.
Peel off the wire cover (Dont cut it off) near the earphone head (normally not more than an inch) to findout where one of the colored wire is cut off and fix it.
Note: Before you could join or fix this broken one firstly you need to burn up the color coded wire with fire for a SECOND so that all the color (green/Red...) are cleaned up.
If this dont fix Please tell me. Im here to help you
Good Luck!
Dec 05, 2008 | Shure E3C Consumer Headphones
Jack replacement for mdr-v500 headphone
You don't need to look inside the plug... just open up the earcups and test the jack plug with a continuity tester.
But FYI, Red = ring, Green = tip.
Apr 04, 2008 | Sony MDR-V500 Professional Headphones
Skull Candy Double Agent Stereo Headphones in Green Ships in ''24'' Hours Logo
335 people viewed this question
Top Skull Candy Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Joe Lamb
Joe Lamb
Are you a Skull Candy Audio Player and Recorder Expert? Answer questions, earn points and help others
