Question about Dell Inspiron 531s Desktop Computer
I did a disk clean up on a friends computer and now no drives are there ... No USB or CD ... I went to the device manager and there is nothing ... can this be fixed with the mystical F11 key at sartup?
  • 59 Answers
You should be able to do a last known good config or just use a recent system restore point.
Posted on Apr 08, 2011
Error 0xc000000f while formatting hard drive
try some formating toos .. like hiran boot cd or disk or diskformater ...u can use usb bootable device to install windows, u can make ur personal pen drive to bootable pen drive.
Jun 02, 2013 | Packard Bell Computers & Internet
I hooked up the adapter to my computer and the drive I wanted to get information off of. The red light goes on, but nothing else happens I went to windows explorer and nothing shows that it is attached...
hi; do you properly inserted the power cable or even the usb port? try some steps... check the driver if installed. change the USB port . check your HDD if the jumper is in master check device manager if your usb has detected go to disk management in control panel check if the drive is not mounted... thanks.................
Sep 17, 2011 | Diablotek EN2525P USB 20 to IDE Adapter...
I am trying to download movies off my friends portable hard drive onto my laptop but when I plug in my friends hard drive into my laptop, my laptop don't recognize it and nothing comes up???
Your laptop's usb port may not have enough power to keep the portable hard drive running.
You may require additional power to the portable hdd by using a usb cable with 2 usb connectors.
or use a USB port that is powered.
Mar 03, 2011 | Computers & Internet
I have a SimpleTech SimpleDrive 1TB just got it last month. I went to plug it in and light comes on but I can't find it under computer. How do I find it?
Are you trying to connect using USB or eSata. In either case try connecting the drive with the computer OFF. Boot, then look under MyComputer - Properties - Mangage - Disk Management to see if the drive is recognised.
Oct 29, 2009 | SimpleTech 1TB SimpleDrive USB 2.0/eSATA...
CD Disk Drive E doesn't want to open
Right click on "My Computer" and press "Device Manager". See if your CD drive appears in there. If it does, delete it and re-boot. The PC should find the CD as a new device and re-install standard drivers for it. Hope this helps. Ian.
Sep 27, 2009 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
MAXTOR 250 gb usb hard disk is not detected
On some computers the output power of the USB ports is too low to drive the Ext. HDD.
Have you tried other USB ports on your computer?
Get yourself a powered USB hub and try that, borrow one if possible, if that works get one for yourself....
Aug 21, 2009 | HP/Maxtor 40GB 3.5 IDE/ATA Hard Drive...
External USB Disk is installed but not visible under Mu Computer
Go to manage, refresh, and then asign a letter to it.
--- tuljo
Feb 23, 2009 | Western Digital External USB 2.0 80 GB...
Not reading disc.cd/dvds
Solution 1.
Firstly lets see if your drive is working!
Put in a disk you know works and has files of some sort on it
If nothing is still happening , goto my computer and right click on your CD drive and
click "explore"
Do you now see files ?
If not right click on "My computer" and click manage
The "Computer Management" Console will now popup and you will see a selection of
headings on the left , click the plus (+) sign on "Storage" to expand it then click on
"Disk management (Local)
In here you will see all the storage devices attched to your computer , including your
Hard Drives , Floppy Drives , USB Flash Drives etc.. , from here you should see your CD
Drive , if you do and right click it and explore the drive and you do see files ,
change the drive letter of your CD-ROM drive from the default D: to say like F: or
something , right click the CD-Drive in the Disk management and click change driver
letter , and follow the instructions.
If you dont see the files or you dont see the CD-Drive at all do the following:
1. right click my computer
2. click on properties
3. a new window will popup
4. click on the hardware tab
5. click on device manager
the device manager console will now open ,
from within here find your CD/DVD Drive under the DVD/CDROM drive heading,
right click the appropriate drive and click on uninstall.
Now reboot your computer and then windows should detect your CD /ROM Drive and reinstall it , you may now again need to reboot in order for your CD Drive to function correctly If this doesn't fix your problem try upgrading the firmware of your Drive.
**im assuming your running Windows XP for that solution but i would think the process in Vista would be very similar.
If you have a spare computer that is unused maybe you could try it on that machine and see if it works , if it does a fresh installation of Windows on your current machine may be the solution as it could be infected with a virus which just may have corrupted the window drivers.
Solution 2.
If the DVD Drive is connected on the same ribbon cable as the Harddrive , the Hard Drive should be set to Master on the Jumper settings and the DVD Drive set To Slave otherwise if it's on a seperate cable it should be connected at the end of the cable and set to master. If you do / have done this can you see the devices in BIOS ?
Solution 3.
It sounds like some dust or hair has landed on the Laser Lens (The component responsible for reading the data on the CD) and is interfering with the playback , to clean this your self you will need a laser lens cleaning kit to safely remove the debris.If you're finding that after cleaning the disk the DVD is still skipping try cleaning the cd , as debris on the CD itself can also cause interference for the laser lens
Aug 26, 2008 | Lite On Computers & Internet
Connecting with PC
Make sure that the driver letter is not being "shared" with another letter. You might want to check in that "removable device " under "Manage".
May 05, 2008 | Samsung SGH-D600 Cellular Phone
My disk drive isn't working. When I put a disk in and close it, nothing happens.
#put in a disk you know works and has files of some sort on it
#If nothing is still happening , goto my computer and right click on your CD drive and click "explore"
#if not right click on "My computer" and click manage
#the "COmputer Management" Console will now popup and you will see a selection of headings on the left , click the plus sign on "Storage" to expand it then lcick on "Disk management (Local)
#in here you will see all the storage devices attched to your computer , including your Hard Drives , Floppy Drives , USB Flash Drives etc.. , from here you should see your CD Drive , if you do and right click it and explore the drive and you do see files , change the drive letter of your CD-ROM drive from the default D: to say like F: or something , right click the CD-Drive in the Disk management and click change driver letter , and follow the instructions.
#If you dont see the files or you dont see the CD-Drive at all do the following:
3. click on the hardware tab
4. click on device manager
the device manager console will now open , from within here find your CD/DVD Drive under the DVD/CDROM drive heading, right click the appropriate drive and click on uninstall
now reinstall with the drivers and restart.
also if this doesn't fix your problem try upgrading the firmware of your Drive.
Feel Free to ask more if this doesnt fix it:
Thanks!
Apr 02, 2008 | Computers & Internet
Dell Inspiron 531s Desktop Computer   Logo
26 people viewed this question
Alun Cox
