Question about Pioneer PureVision PDP-503CMX 50 in. HD-Ready Plasma Television
When i hook the dvi-d port up it says out of range ?
  • 591 Answers
You need to change the REFRESH RATE from (whatever) to 60Hz in the windows screen preference...
Cheers!
Posted on Apr 08, 2011
Hi i am looking for vga cable 9 Pin Female to 15 Pin Female thanks
The 9-pin port on your PC tower is NOT a video port, it is a serial data port. All VGA connectors are 15-pin. Hooking up to the 9-pin port will not get you a picture. There should be a VGA port on the PC, or else a DVI an/or HDMI port. You can get DVI-to-VGA adapters that work, but only if the DVI port is an analog DVI, not if it is a digital DVI (DVI-D or DVI-DD).
Feb 02, 2016 | LG Computers & Internet
How to hook a pc
hi just hooked up the VGA cable from your PC into the VGA port of the tv unit and then select pc in the source menu. if it is hdmi or dvi you must need a converter , like vga to dvi or dvi to hdmi etc.
Sep 18, 2012 | Hitachi 42HDF39 Television
Can i hook up my PC to hitachi projection 57f510
Yes, if your tv has a VGA port.
if your TV only has a DVI. your PC video card has to a DVI OUTPUT PORT as well, or you may use adapters to convert from VGA to DVI and ...
Nov 12, 2011 | Hitachi 51F500 51" Rear Projection...
I have a syncmaster 400p i need a new graphic processor can u reccomend a compatible one
Good day,
If your screen has a VGA, DVI, or HDMI port, most of the new graphics cards will be compatible with your screen. Most graphics cards come standard with DVI ports and include a vga adapter for the screen cable. Some of the new graphics cards come with HDMI and DVI ports or a HDMI converter if you want to use HDMI.
I would recommend a Nvidia graphics card. Depending on what your primary use is going to be they have an extensive range to cater for your requirements and price range.
Hope this helps!
Regards
Nov 28, 2010 | Samsung SyncMaster 400 T 40 in. Flat Panel...
I have my PS3 hooked to the HDMI port, but the monitor won't switch inputs to the HDMI port. If I have something plugged into the dvi port it works fine, but I currently need only the HDMI port, and do...
There are a varity of HDMI cables, ensure that your version is supported also using the input touch "button" to change the input through VGA, DVI and HDMI.
damnor01
Nov 22, 2010 | Acer H233H bmid Monitor
I'm trying to hook my Macbook Pro to my TV (Samsung 50'' Plasma 720), I have all the cables needed to hook up sound and picture. I have the Mini display port to Dvi Adapter and Dvi to HDMI cable. My...
Hi
It may just be possible that DVI signal does not convert to HDMI signal. So in theory this may not be possilbe for you to get a result with your present attempt. May i suggest connecting to the DVI port of the TV. i.e Mini Display to DVI.
Regards
Dec 29, 2009 | Apple Computers & Internet
I just hooked up my HP Pavilion 9000 Laptop to my Vizio TV and put the TV on correct setting. It is not working on the TV, any ideas? I went on Display setup and kept trying to connect but it says the...
If your laptop has a VGA port, your Vizio needs to have a VGA port too so you can use a standard VGA monitor cable.
If your laptop has a DVI port, you hook it up to the Vizio using a DVI-to-HDMI cable.
And if your laptop has an HDMI port, you hook it up using a standard HDMI cable.
Hope this helps.
Oct 16, 2009 | HP Pavilion dv9000z Notebook
Is there someway to hook up our Hitachi 42HDS69 to our laptop
Your computer should have a DVI port to make this possible since your TV dont have a VGA port. If your computer have a DVI port then an HDMI/DVI cable is all you need. This allows you to connect you computer or laptop to you tv through the HDMI connection on your tv.
Dec 31, 2008 | Hitachi 42HDS69 42 in. Plasma Television
"No signal detected" when LCD connected with DVI-D Cable
Thank you for providing your configuration details.
You have failed to specify wheather or not your LCD Display is under Warrenty.
Perhaps these simple trouble shooting procedures will get the job done.
1. use the DVI to VGA adaptor that came with your card
Plug in a regular CRT monitor to the Primary Display Output Port using the DVI to VGA adaptor
( either port can be designated as the primary by you )
I like to use the Port nearest to the motherboard as the Primary
2. plug in the your LCD monitor on Secondary Display port using your DVI cable
At this point you should be able to see your desktop on the Primary CRT Display
3. Go to the display properties and use the Nvidia Dual Display Setup Wizard
set both desktops to CLONED at a resolution of 1024x768 and set the refresh to 60Hz
which is default for most LCD displays , some have higher refresh rates , consult your user manuel
If the display resolution and refresh are set incorrectly for your CRT or LCD you will see
Signal Out of Range ( if the display has the ability to display that error message )
At this stage both displays should be showing a Windows Desktop
If you now see your desktop on both displays , you can now put the LCD on the Primary Port
No Signal Detected ( this means the display device is not receiving a signal )
If your LCD display is still displaying the error message
"No Signal Detected" after performing the trouble shooting proceedures
You may need to read the user manuel about how to enable DVI signal input.
If you are certan you have done everything correctly but still see only "No Signal Detected"
Your LCD Display may need replacement
Loch Hime :-)
Sep 14, 2008 | BenQ FP71E 17" LCD Monitor
Pioneer PureVision PDP-503CMX 50 in. HD-Ready Plasma Television Logo
177 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
