Question about Freud Tools & Hardware - Others
Have a Freud FT 2000 E on which the speed control has failed. Freud no longer has this part. Any suggestions?
I have the same router. haden't used it for a number of years and it would not start. I removed the cap(two screws). Used a wire to bipass the control and the motor ran fine.Unplug router and remove the screws holding the wires from the switch to the speed control. Disconnect the wire from the motor to the speed control. Remove the two screws holding the speed control to the router. Remove the speed control,. snap out the control wheel. I first sprayed liquid wrench into the hole then replace the wheel. shake the control and turn the wheel back and forth a number of times. Remove the wheel and dump out the fluid. then spray contact cleaner in the hole and repeat the process a couple of times. Let the control dry over night.Then reassemble the router and try it. It worked for me. Good luck!
Posted on Oct 28, 2011
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 190 Answers
If the router operates, and at full power, you could use an aftermarket rheostat for controlling the router speed. Rockler hardware sells one, others retailers may as well.
If this is not an option, a tool repair person (one of those old-timers...the "handy" ones that can improvise repairs and take pride in doing it) may be able to provide an option to keep it working for you.
Hope this helps.
Posted on Apr 27, 2011
Replace brushes in a ft 2000 vce 1900 watt motor
Hello Thomas,
My name is Larry Boccioletti from Ontario Canada.
I am a service and parts dealer for Freud.
If you are looking for parts to repair an FT2000 or FT3000
I have them carbon brushes,brush holders,almost anything.
I would be happy to send a quote if you like.
My company is Halton Maintenance Centre and my email is
haltonmaintenance@yahoo.ca
Thanks
Larry
Dec 09, 2014 | Freud FT2000E 3 Router
Freud ft2000 switch
You can find a part diagram and parts list on-line. Just enter the model #. The variable speed control module is no longer available. You can bypass the control, and connect the router directly. You will no longer be able to control the speed, or turn off the router. I used a variable 15A control box instead. It will function the same way.
You may want to just replace the router with a new up-to date router, I just purchased a 2 1/2HP Skil router kit tah has a 1/2 chuck, and both a plunger base a flat base, for $100 at a big box store.
Mar 23, 2014 | Freud FT2000E 3 Router
Freud router ft 2000 vce how to fit bushes
hi I am a service dealer for Freud in Canada If you still need parts let me know I can help.
Thanks Larry
haltonmaintenance@yahoo.ca or 416 824 6653
Oct 22, 2012 | Freud FT2000E 3 Router
I have taken my FT 2000 E to my local saw shop for repair because it would not run. They diagnosed the problem as a faulty speed control switch. After attempting to get the part from Freud twice and...
I have a FT2200 with a bad speed control unit 76348.
8015. Freud no longer supplies this part. I bypassed it, and I am using an external variable speed control supply. The only setback is there is no longer "Torque Control". This presents a problem if the bit burns, but I control the speed of feed. So for, I am getting by. A new one is TOO expensive.
Jun 21, 2011 | Freud FT2000E 3 Router
Would any one know where to get parts for and Freud FT2000E online. I am looking for a new switch.
Hello George,My name is Larry I am a service tech for Freud Canada.
I can get for you almost any Freud parts
larry_boccioletti@yahoo.ca
Dec 19, 2010 | Freud FT2000E 3 Router
My Ft2000E Freud router stopped working when I was setting up to run some moldiings. No humming . no burning= nothing. Any Ideas?
Hello Blonsan I am a service dealer in Canada and the speed control will do that no warnings ---the speed control is 89.00 canadian ---give or take--
Nov 04, 2010 | Freud FT2000E 3 Router
I have a fe-2000 router in the middle of a project it refused to be turned on . i suspect the switch is faulty but where do i get replacement parts . i am in Indiana
Hello Mr INDIANA,
My name is Larry Boccioletti and I am the last remaining dealer in Ontario Canada.I have the parts
.My company is Halton Maintenance Centre
my email is haltonmaintenance@yahoo.ca
Freud has been bought out by Bosch and their tools are being fazed out.
I think your speed control module went on the fritz not your switch.
The speed module is still available and the switch to.
If you would like a quote I would be happy to oblige all I need is the colour of the cap,the serial number and make sure of the model.
Thanks Larry
May 20, 2010 | Freud FT2000E 3 Router
My Freud 2000 router has started sparking where the brushes are and slows down. Increase in speed control to max blew a fuse. I have tried changing brushes to no avail. Is the problem the armature/winding?...
if that is the case it may be a better option to replace the router. check online for freud spares suppliers but make sure you order the correct part with correct model number as some of them do not accept returns
Dec 12, 2009 | Tools & Hardware - Others
Tools & Hardware - Others Logo
630 people viewed this question
Top Freud Tools & Hardware - Others Experts
Jim Goldsmith
Jim Goldsmith
jairo sanchez
Are you a Freud Tool and Hardware - Other Expert? Answer questions, earn points and help others
