Question about Garden
I have a coleman 220k lantern. I can pump it up but it doesn't seem to get any fuel to the mantels. I have read about a generator but what is it and what does it do?
    President:
  • 1,273 Answers
Hello, W/D here.
The generator is the small brass tube located close to the mantles. Here's how the lantern works: You pump it up until you get a decent pressure, or your thumb falls off, whichever occurs first. Next, you turn the main knob to the lighting position, which is usually marked as a 1/4 turn to the right. Then, you manipulate the small valve in between the mantles until you hear a gas flow. Turn the valve until the gas flow is lessened, then light the mantles. Adjust the small valve to get the mantles glowing. Re-pump up the main tank, and close the internal stem valve by rotating the plunger in a clockwise manner. Open the main gas knob to the run position, or fully, depending on your model. Adjust the gas flow at the small valve to keep the gas from flaring up at the mantles.
The heat from the mantles heats the generator, which atomizes the gas, and maintains pressure on the tank via the return tubing. As long as the mantles are heating, the length of time between tank pumpings is greatly extended, but usually not eliminated completely.
Best regards, --W/D--
Posted on Apr 08, 2011
My coleman powerhouse dual fuel lantern brightens and dims continuously. could this be the generator acting up?
Hi bradley m925...
Try using the cleaner for the generator, it is a twist type crank, make a few turns on it if you have it.
If not then your right, replace the generator as it is faulty.
Please take time to rate me
Coleman Generators website...http://www.summitcampinggear.com/lage.html
Sep 21, 2011 | Coleman Cable Coleman Twomantle Dual Fuel...
Hello, I have a number of older Coleman lanterns of the pump style from the 60's or even 50's. The problem is when I light them they all flame vigorously for a couple of minutes before settling...
Hi smcdowell625...
Be sure you are using fresh fuel
You should change the "generator" on each of the lanterns
You should flush and clean out the fuel tank of any dirt,debris, residue,etc.
The link below is to a website to show you the generator...I am sure there are many other websites also.
Please take time to rate me thumbs up
Sep 19, 2011 | Coleman Camping, Backpacking & Hiking
I have a dual fuel, two mantles, coleman lantern. I have changed the mantles several times and they keep getting holes almost every time i light the lantern.
Make sure that the vapourised fuel is coming through the mantle before lighting up. You should hear a hissing sound when the flame adjusting lever is turned to high. If not it is possible that the generator is clogged up and that vapourised fuel is not getting through to the mantle. So when you light up you are essentially just burning the mantle. If the generator is knackered it will need to be replaced. One way to check it to remove the generator, primed the tank and turn the valve on. If fuel spurts out when the generator is removed (DON'T LIGHT IT U)P THOUGH) but there is no hissing sound when the generator is intact then it is a sure sign that the generator is clogged up. In the UK a replacement generator should set you back £10-15. Hope this helps, Bandit
May 23, 2011 | Coleman Cable Coleman Twomantle Dual Fuel...
I cant get any petrol to pump into the mantles
If the petrol doesn't come through first check that you have enough in the tank. If the tank is not full enough it won't come through. If it still fails to come through it's likely that the generator is blocked. This is the tube which the mantle sits on and it has a very narrow opening to force the petrol to convert to vapour when it's warm. Try heating it for a while and it may clear it. Otherwise you'll need to buy a new generator.
Note: while the dual fuel lanterns can burn petrol you should be aware that it gives off poisonous fumes, like cars did before they had catalytic converters. The lantern should not be used indoors with petrol. They are safe with coleman fuel. If you live in the USA, Coleman fuel is cheap but if you're in Europe it's much too expensive. Rather than buying a new generator, if you live in Europe, you could buy a parafin burning lantern like the Petromax 500 available from http://www.pelam.de/index.php?cPath=28_31&language=en&gclid=CIOe46DQnqYCFQkf4QodQxz2Zg
and other sites, or you can pick up second hand Optimus lanterns on Ebay. Both burn parafin, though they need to be primed, and provide at least as much light as the Coleman.
Jan 03, 2011 | Coleman Northstar Dual Fuel Lantern
I have a Coleman 228F model lantern. When I go to light it, it barely produces any gas. I have made sure it is pumped adequetly and full of new fuel. I can hear gas coming out very faintly and sometimes...
It's likely that it was left away with fuel in it. This causes gel to form which blocks the fuel getting through. The blockage could be anywhere between the tank and the mantles. The order I would check in are;
  1. The feed tube assembly
  2. The generator
  3. The Burner
It's possible to get these parts from coleman or coleman suppliers. To find which needs replacing you'd need access to another similar lantern and try replacing one at a time. Otherwise it's going to be trial and error or just replace all.
There's a manual which shows the assembly and the order number for parts at http://www.coleman.com/coleman/images/pdf/220f_228F.pdf
I hope this is of some help.
Dec 16, 2010 | Coleman Sport & Outdoor - Others
How to light coleman lantern
Kerosene lanterns require a little more than just lighting the mantles. Go to Coleman's website and find the directions (for free) for KEROSENE lanterns. The generator on the lantern needs to be preheated with alcohol before it will actually light. Make sure lantern is a Kerosene lantern and not a white gas (Coleman fuel) type, there is a difference even though they look similar.
Aug 05, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
How to fit a mantel to a coleman propane lantern
Hi, First remove the knurl nut on the top. Remove the top and then the glass globe. There are several types of mantels most of which tie with a string that is part of the mantel top. The newer ones have a wire clip in place of the string. Which ever type you had on before you need to remove the old pieces completely. Since the mantles burn to an ash they will disintegrate when touched but if it had the metal clip you need to remove it. Tie or clip the new mantle over the lip on the output orifice being careful with the screen underneath. Replace the glass globe and top, put the nut back on finger tight. Remember that the mantel turns into ash when it burns for the first time so keep the gas low to start it till the mantle forms properly ( in the first minute) Good Luck, this should Fixya!
Mar 16, 2009 | Coleman Camping, Backpacking & Hiking
Garden Logo
375 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
