Question about LG Dryers
LG DLE2150 3 mths old until will not turn on or any lights on front panel inside light is on and unit clearly has power
  • 1525 Answers
SOURCE: duet dryer ygew9200ll1 will not turn on
make sure the door connecting also theres a capacitor inside these can stop your dryer working
goodluck
shaun
Posted on Jan 11, 2009
ginko
  • 19396 Answers
SOURCE: Whirpool GGw9250Pw3 no power on Control Panel Inside light works
Hi.
Please read the Fixya article below explaining how to fix the problems related to control lock on Whirlpool dryers and washers.
The front light lit on my Whirlpool.
Regards.
Posted on Feb 22, 2010
  • 32 Answers
SOURCE: my whirlpool duet front load
Sounds like the door is not closing completely. Check the connectors that tell the unit the door is closed.
Posted on May 27, 2011
SOURCE: lg dle2516 wont start. i checked the power to the
Did you ever figure this out? Mine did the same thing today..died in mid cycle now nothing.
Posted on Aug 11, 2011
hunter19_46m
  • 7482 Answers
SOURCE: I have a maytag dependable
Hi ohcop603
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley,faulty capacitor, or a faulty motor.
Note: This method works for most front loading machines.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place, some seals are furnished with the cement to glue it in place.
Remove the electrical console that holds the timer switch,start switch, etc. from the top of the dryer if necessary. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the two screws that hold the filter housing to the top of the dryer lid.
Then remove the top of the dryer by inserting a screwdriver between the top and frame on each side of the dryer to pop the lid up from the retaining clips.
Note: Some of the tops tilt backwards on a type of hinge and do not have to be removed completly.
Remove the front of the machine by disconnecting the door switch and removing the two screws located on either side of the dryer frame.
Move the door and front of machine forward to remove.
This will expose the belt,idler bracket and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
Note:The way the belt goes back on is, as the belt comes off the drum has to be doubled (pushed together to form a loop) and goes under the idler pulley then to the motor pulley.
Here is a link to see a picture of your belt routing in case the belt is broken when you open your dryer:
http://www.expertappliance.com/dryerbeltconfiguration.html
While you have the drum out, I would recommend that you remove and lubricate the drum rollers.
And also clean the shafts of the rollers as they will collect hair,dust,etc and cause problems and then lubricate the shafts and rollers with a good grade of machine oil like 3 in One oil or a vasoline type of lubricant. This will save you a problem later with the rollers getting dry and making a squeeling noise, also check your drum rollers for flat spots, if they have flat spots on them this will cause a thumping type noise.
You will need to replace the drum rollers if they have flat spots on them.
Please take time to rate me thumbs up
Posted on Sep 18, 2011
No power on LG TV
Could be power supply failure
Oct 16, 2016 | LG Televison & Video
The power light comes on but the screen stays blank there is no picture or sound
Hi Judy
How old is your unit?
Probably your unit has leaky capacitor or shorted driver transistor.
Jan 19, 2014 | Haier L32B1120 32 LCD TV
LG WM3001HPA Washer interior light is on but will not power up
Door close interlock switch is out of adjustment. Remove side panel(s) and adjust it back to a point where it recognizzzzzzzzzes it closed. Bolt eveything back to gether and you be done!
Jul 17, 2010 | LG Washing Machines
LG WASHER WON'T Power on
Hello. If the lid switch is defective, your washer may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
May 24, 2010 | LG WM1814CW Front Load Washer
LG plasma TV turned off, after the picture very light
I think you have a defective power board. the pop sound in coming from the board and giving you a low output voltage. do it yourself price about two hundred for parts.
Feb 18, 2010 | LG 42PC5D Television
Lg dle3777w dryer filter light remains on and dryer is not working even after cleaning the filter.
I'm sure you solved the problem but as i had the same problem on my electric LG front loader and saw no response i figured I would leave one for anybody else in the future. My girlfriend told me the dryer would not start and as i looke i saw the panel would not power up, I unplugged the power cord for 5 minutes and the LG reset and the panel was on and reading clean filter after checking the filter which appeared clean I tried to restart the dryer at which time it powered off. I again unplugged the dryer and replugged it and again the display read clean filter. I then gtabbed a phillips #2 and unscrewed the filter lint sceen which had a total of 4 scews in the interior of the dryer holding the filter housing unit. Youll see a piece of the housing unit remains screwed into the washer hooked up to two electrical plugs. Seperate both plugs from the unit and unscrew it and remove the unit youll notice two silver strips on the unit and I'm guessing will be covered with a small amount of lint. Clean the unit with a brush and damp cloth inside and out reattach the unit screw first and housing unit and turn on. If the dryer again turns off unplug and youll see the clean filter light. Simply push the custom program light or anything similar and the panel should start working again. I hope this helps someone.
Aug 08, 2009 | LG DLE3777 Electric Dryer
I have a LG LSC26905SB refrig that has stopped getting power to any part of the fridge. The compressor does not run and the lights do not light up on the front (water/ice area) or inside the fridge. I...
Possible control board failure ...you may notice the freezer lights do work but nothing else.There is a diagnostic push button on the board located on the top of unit under a panel where the power cord enters. andrews electronics .com is the oem provider for this very expensive control board.
Jul 12, 2009 | Refrigerators
Dryers Logo
88 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
