Question about Zanussi Refrigerators
Where is the serial number on aZFT610X Under Counter Freezer
2 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: Where can I find oven
1-800898-1879 is the Customer Service number.
This is the website http://www.eurotechappliances.com/support/index.htm .
Contact Eurotech for a dealer near you.
Posted on Oct 16, 2010
Serial #
What problem are you having? All you need is the model number.
Jul 05, 2013 | GE Monogram ZICS360NRRH C... Bottom...
How do you winterize Model GE20P06SAG? There is no drain at the very bottom...?
Thank you for including model number for EZ identification of water heater
To drain tank without drain valve: Remove TP valve at top of tank and siphon out the water. Then reinstall with correct pipe configuration shown in product manual.
Product manual shows drain valve is not supplied with this unit.
http://waterheatertimer.org/pdf/GE20P06SAG-under-counter.pdf
Product manual shows the Installer should add both shut off valve and drain valve on cold water inlet line.
http://waterheatertimer.org/images/GE20P06SAG-under-counter-60.jpg
More resources:
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html
Sep 30, 2012 | RELIANCE 19.9 Gallon Electric Compact...
Copier model canon ir 3300 error 000354-0002
E354 is a mismatch or absence of the serial number stored in the Serial Number PCB and Main Controller/Image Processor PCB or Counter PCB. Check and reseat connections to the counter and Serial number boards on the main controller.
Jan 10, 2011 | Kitchen Ranges
Where can I find oven racks for my Eurotech under counter oven. Serial number 306840006 model E-136B
Oct 16, 2010 | Microwave Ovens
How to get serial no. for Nokia N900
Try typing this in to get the serial number:
*#0000#
Feb 27, 2010 | Nokia N900 Smartphone
Canon ir2020-seystm err e354 please tel me what ido tanvir gillani
E354
•When turning ON the power, inconsistency of the serial No. of
the serial number PCB and that of the controller PCB
(SRAM)/counter memory is detected.
•When turning ON the power, it is detected that no serial
numbers are assigned to the serial number PCB and the
controller PCB (SRAM)/ counter memory.are you trying to change the counter board this not possible bec the serial no of the machine is embedded on the counter board so no counter tampering allowed
Oct 01, 2009 | Canon imageCLASS D320 Digital Copier
Canon IR-3300, error 354
E354
controller PCB (SRAM)/ counter memory , if you are try to change the counter pcb to get rid of high meter reading this error is possible, this a security measure of canon to prevent meter tampering
Jul 14, 2009 | Canon Office Equipment & Supplies
My Dometic trailer refridgerator is warm but freezer is freezing.
Brandi4723,
Unfortunately, you have a bad cooling unit in your refrigerator. Then ammonia smell means that you have a leak in the unit. TURN THE FRIDGE OFF!!! Do not use the fridge on AC or Gas until you have the cooling unit replaced or buy a new fridge. Depending on the model number and serial number of the fridge, it may be under recall by dometic and you might be able to have it repaired for free. If you will provide me with the model number, serial number and the serial number of the cooling unit (found on the outside of the unit in the fridge compartment, lower tank of cooling unit), I can then tell you the pricing of the repairs or whether it is under recall.
Again, TURN THE FRIDGE OFF and do not use it...RISK OF FIRE!!!!
Hope this helps,
Jeff
Jul 03, 2009 | Dometic RM2652 Refrigerator
Help me.....faster....
Errors commencing with E3---- means that something to do with the reader unit,,,, apart that error mentioned does not exist. If youhave plenty of parts that you can try out I will try to replace the reader board....
Dec 15, 2008 | Canon imageRUNNER 5000 Copier
Refrigerators Logo
18 people viewed this question
Top Zanussi Refrigerators Experts
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a Zanussi Refrigerator Expert? Answer questions, earn points and help others
