Question about Quickie Wheelchairs Auto Sunrise Med Guardian Quickie Wheelchair Seat Belt
Lights on controller just keep flashing starting at bottom and go up constantly ? what would be the problem?
ABS light is constantly on this happened after I went through some snow I had also the (((!))) sign flashing, but now it is gone Golf 4, 1.4 16V 1999 Please advise. Thank you so much
that sign is your traction controll kicking in trying to keep the car under controll by applying the brakes to the tire that is spinning it can engage the ABS too your ABS controller is more than likely damaged and needs replaced it is a common problem with VW ABS systems.
Feb 08, 2010 | 1999 Volkswagen Golf
Printer 1270 front control panel lights are flashing constantly and the printer wont move or react to any manual inputs
Turn the printer off.
Press down the ink button and the paper button at the same time and turn the printer on (while keeping them pressed down)
After a second or two, the red paper light should start flashing.
Immediately release the buttons and press and hold the paper button again. Keep the paper button down for about ten seconds and release. After a second or two, the printer should go back to it's normal state.
Please try this and reply me for further doubts.
Regards, Nandini.
Sep 14, 2009 | Epson Stylus Photo 1270 InkJet Printer
Constant flashing clean light
count the blinks shoud be 7 times it blinks then a pause if it does that its a heat circute problem need to check the heater and replace the controls
Jul 13, 2009 | Whirlpool Dishwashers
The air conditioner control lights on dash bord keep flashing off and on
Try this and see if it works. Let me know.
Start your van. Then slide your temp lever all the way to the left (full cold). Then turn the Mode Control to 'panel' (the one that sends air to your face only). Then turn the 'blower switch' to all the way to full. Now go to the leftmost three buttons. Press the top one (rear wiper on constant) and the bottom one (rear wiper washer fluid). Hold these two for a few seconds. Once the lights come on solid then begin to flash you can let go. The AC will now calibrate. You will feel the air blow out of all the different zones at different intervals and see lights come on and go off. Then after a minute or two the top button you pressed will be slowly flashing. This means it has been completed . Press the last flashing button and you are done.
Jun 29, 2009 | 1997 Chrysler Town & Country
Lights flashing on a/c and air recirulate buttons
Sounds like its gone into programming mode. All you need to do is start your van. (if you are unsure what knob or lever is which I am looking in the manual for proper terms) Then slide your temp lever all the way to the left (full cold). Then turn the Mode Control to 'panel' (the one that sends air to your face only). Then turn the 'blower switch' to all the way to full. Now go to the leftmost three buttons. Press the top one (rear wiper on constant) and the bottom one (rear wiper washer fluid). Hold these two for a few seconds. Once the lights come on solid then begin to flash you can let go. The AC will now calibrate. You will feel the air blow out of all the different zones at different intervals and see lights come on and go off. Then after a minute or two the top bottn you pressed will be slowly flashing. This means it has been completed (I actually let it run for 5 more minutes just in case something else started blinking). Press the last flashing button and you are done.
Mar 17, 2009 | 1997 Dodge Grand Caravan
VW Passat failing to start/security alarm issues are they linked?
Usually on the passat, if the immobiliser is on, there is a yellow key symbol flashing on the clocks as you try and start it. Do the doors unlock with the remote key? If no flashing light and the key fob working, i would be looking at possibly starter relay. This is either located under the fuse box or under a plastic cover near the windscreen under the bonnet. (hood)
Jan 21, 2009 | 1999 Volkswagen Passat
Quickie Wheelchairs Auto Sunrise Med Guardian Quickie Wheelchair Seat Belt Logo
52 people viewed this question
Top Quickie Wheelchairs Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Quickie Wheelchairs Health and Beauty Expert? Answer questions, earn points and help others
