Question about Baxter BXA2G Stainless Steel Gas Single Oven
ROTATING RACK DROPS TO FAR, SEAMS TO COAST DOWN AND TRAP CART.
  • 43 Answers
The brake in your hydraulic lift actuator is worn out.
Posted on Dec 30, 2011
  • Joe Winner
    Joe Winner Apr 27, 2017
    Some manufacturers suggest putting a rubber bungeecord to keep the rack from overriding.
My LG oven racks are slipping and falling down. The oven cavity seems to have warped outward. Is there any way to make the oven usable?
-You mean the opening in width is too wide then
it suppose to and the rack keep falling down?
-If so then look for other rack instead its brand and must be
fit in the groove good. Or ask some one do wielding to wield another 3/16" diameter metal next to the 1 side of the rack, (Add on to make wider) so it can stay in the groove.
Good luck and enjoy
Mai
Oct 25, 2017 | LG Ovens
I replaced my door springs but it seams the hinges pop out of the track when opening the door and it causes the door to drop down to far
Tom, I am pretty sure you have not reinstalled door quite right, try again till you get it seated into proper position.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 03, 2016 | Ovens
Rotating Rack. How do I replace flame sensor?
How To change a flame sensor on a furnace and what to ...
? 17:13
www.youtube.com/watch?v=iDnkdKsZhc0
Dec 8, 2011 - Uploaded by kevin miller How To change a flame sensor on a furnace and what to look for. ... The gas flame heats the electrode, allowing electrons to be emitted as from the ... I found a Honeywell "universal"replacement unit for my furnace on eBay for ...
Aug 19, 2015 | Baxter Ovens
How do i fix an oven that bakes unevenly
the cooking I can't help with, but the oven I can.
sounds to me like the bottom element or what controls it is not working. the reason the ones on top are cooking is that the top element is coming on and browning them on top after the heat has made the dow rise and cook.
so essentially everything is cooking from the top down. so when the temp drops its using the top element to heat with and thus browns the top rack.
check ur elements to make sure both work, if so, move on to the thermostat which I have to be the culprit many times.
Feb 26, 2015 | Ovens
How do i take out an oven rack of a Kenmore stove thats been put in the wrong way i mean upside down!
lol.. I had the same problem a few years back, but my rack was totally jambed in there... I think if you raise the back of the rack and the front at the same time you can get it out.. with mine I had to keep jiggling it till it broke free.. good luck and have a great turkey day.
Nov 26, 2014 | Ovens
The rack inside has stopped rotating
On top of the oven is a cover with 6 screws in it, loosen the screws and remove the cover. You will see two pulleys, most likely one of the pulleys are loose, try tightening the set screws, the one on the right can be tricky because the set screw is under the pulley. Good luck!
Dec 04, 2010 | Baxter OV300E Stainless Steel Electric...
Ovne do not turne withe rack in side the ovne
Does the rack raise? Are you hearing a buzzing every second? You could have a bad rotation motor, or the drive chain could have just fallen off. Both of these repairs aren't terribly difficult but are extremely annoying. It might be a best use of your time and resources to call an authorized service provider and have them repair the issue.
If you're feeling ambitious the first thing you want to do is verify that your rotation motor is still functioning and that the gearbox is not stripped out. Make sure the supply power to the oven is off, climb up on top of the oven and remove the covers over the lift and rotation assembly if they are not already removed. You should see a black cylindrical motor with a plastic fan blade on the top, this is your rotation motor. Spin the fan blade with your finger while looking at the motor shaft, it should be rotating, if it is not you need a new motor. To change your rotation motor you will need a 5/16" ratcheting box wrench and it can be a nightmare the first time you change one. Unwire the motor, pay attention to which wires you disconnected. Remove the four screws underneath the motor and slide the motor straight up through the hole. Change the chain sprocket over to your new motor and reverse the steps.
If your motor IS rotating when you spin the fan then your chain may have slipped off. Loosen the four screws holding the rotation motor in place so you can slide it back and forth. Lift up on the shaft and place a screw driver in between the metal disc above the big sprocket to keep the weight off of the sprocket. Put the chain on the small sprocket first and then slowly work the chain onto the large sprocket. Once the chain is on lower the shaft back down and tighten the motor back up. Hopefully your rack should start rotating again, if it doesn't the gears in the gearbox could still be stripped causing it to slip, in which case you should call an authorized service provider to service the oven, or see above.
Aug 17, 2010 | Baxter BXA2G Stainless Steel Gas Single...
All food is browning too quickly on the bottom. I
Turn heat down, try covering said foods that brown too fast with some foil.
Jul 07, 2009 | Ovens
Bosch HBN 455 Oven Cooling-Fan Issue
After the oven is switched off, the after-run of the cooling fan is controlled by an electromechanical thermostat switch. The fan can switch back on, due to residual oven heat that accumulates within the oven's outer case and reactivates the cooling fan temperature switch. Considering yours is making buzzing sounds and activates on and off, the fan's thermal switch may have dirty contacts or just be defective and require replacement.
Sep 12, 2007 | Bosch HBN 455 Stainless Steel Electric...
Baxter BXA2G Stainless Steel Gas Single Oven Logo
90 people viewed this question
Top Baxter Ovens Experts
Owen Barnes
ray gallant
Are you a Baxter Oven Expert? Answer questions, earn points and help others
