Question about Dryers
I have a kenmore gas dryer belt is ok but when i try to start the dryer it make a noise but won't start. Please somebody help me
  • Dryers Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Apr 08, 2011
Kenmore 110.96273100 won't start. Power ok.
heatman101
Jun 18, 2011 | Kenmore Dryers
My whirlpool gas LGB6300PW0 dryer won't start. I press the start button and hear a humming noise, but no motor turning over. Please tell me that my 5 yr old dryer doesn't already need a new motor!...
heatman101
May 18, 2011 | Whirlpool LGV4634JQ Gas Dryer
Dryer drum turns by hand, belt ok, motor hums but doesn't turn duum.
you have a bad motor,change it out,try this,open the door and put your hand on the door switch and with your other hand spin the drum while somebody else hits the start button,sometimes this will help the motor start but you still need to change it out,easy job to do
Oct 12, 2010 | Kenmore Dryers
Kenmore gas dryer....stopped working mid-cycle and will not restart. when I push the start button, i can hear a noise by the timer...?
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Oct 07, 2010 | Kenmore 74602 Gas Dryer
Kenmore dryer making rumbling noises
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication. Check the belt condition for wear. Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt. Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them. If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good Luck, I hope this helps Please rate me, Thank You
Dec 12, 2009 | Kenmore 74602 Gas Dryer
Will not start.
check the drum belt, if it is broken the dryer won't start.
Nov 07, 2009 | Kenmore 73952 Gas Dryer
Heat cycle stops/goes off
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here + new25.gifExpanded repair helps for a common "Even Heat" dryer
May 15, 2009 | Whirlpool GGQ8831L Gas Dryer
Kenmore gas dryer 97273100 was drying, but making a loud noise
You need a belt. Here's a link to a site with a good set of instructions if you want to try repairing it yourself. (You should DIY. You can save a bunch on the service call and the belt is only about $20.)
http://repair2000.com/wpoolbelt.htm
Dec 08, 2008 | Kenmore 72982 Gas Dryer
Dryers Logo
37 people viewed this question
Top Dryers Experts
