Question about Quartet gbc Office Equipment & Supplies
I have Model No 80S-1. Half a check book was accidentally put through and jammed the machine. Part of it appears stuck in there. Is there anything that can be done? Thank you.
4 Suggested Answers
rockitman187
  • 2559 Answers
SOURCE: can't get paper jam msg of Canon MP530 printer to clear.->prntr 2
If you need the manual you can get it here.
http://safemanuals.com/user-guide-instructions-owner-manual/CANON/PIXMA%20MP530-_E
Posted on Jan 18, 2009
  • 10865 Answers
SOURCE: paper jam msg. in Canon mp530; doesn't appear to b a jam though
look for a paper jam in the front and the back of the printer. open the compartments and take a look. if all is clear unplug the printer and then plug it back in. this will reset it. good luck.
Posted on Jan 25, 2009
goodgold
  • 389 Answers
SOURCE: Paper Jam 8-112 when power on Xerox DocuColor DC 1250 Printer
You it is necessary to make sure visual(optic) to see the sensor(pick-off) of that node(knot;element), which(who) you is informed.Byvat that conk or клинят sensors(pick-offs) of the passing, electronics in this case her(its)(her) fault is practically excluded. Extremely(Most) seldom(rarely) such быват.I work(operate) 18 years I had 1 or 2 times, but only mechanical damages much(highly;very much) often were. The Sensor(Pick-off) conks or клинит, when remoove the stuck paper. I am simply(merely) run away that reason in sensor. Good luck you!
Posted on Sep 20, 2009
The dispenser drawer on my AEG Lavamat is stuck half open and appears jammed. Help please
Open the machine up on the top lid. 2 screws at the back of the machine at the top. Slide the lid back and remove it. The drawer can now be accessed. There should be a bunch of clips holding the lid of the drawer . You can carefully open these clips to remove the lid or just remove the entire drawer assembly and replace it or try to figure out what is jamming it.
Jan 22, 2018 | AEG Washing Machines
I keep getting an error message about a paper jam for my printer but there is absolutely no paper jammed anywhere in the machine.
Have you tried a new toner cartridge, The toner cartridge has moving parts, and of the cartridge gets stuck, the printer may indicate a paper jam.
Also paper often tears when clearing jams, and the little shreds of paper can stay in the rollers of the printer and keep it jammed. Make sure to inspect all the rollers to make sure they move freely, and do not have anything stuck in them.
Aug 21, 2014 | D-Link D LINK DELL B1260DN MONO LASER...
F-05 MESSAGE HAS COME UP ON MACHINE WHAT DOES THIS MEAN?
hi have a look below hope this helps, then goggle how to fix it!
Sep 06, 2011 | Hotpoint Aquarius WD640 Front Load...
Printer was working fine, until it's outflow was accidentally obstructed. Obstruction removed, but now error light comes on immediately, and printer won't print. There is nothing blocking the paper path,...
Try this troubleshooting prodedure. Turn on/off, unplug, plug in2_bing.gif, should reset configs.
Take all the paper out, put half as much back in.
check the rollers to make sure no paper or particles are stuck preventing from accepting paper.
Go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats.
Go to web site of printer model and check site for trouble shooting if this does not work above. Hope this helps and good luck
May 31, 2010 | Brother HL-2170W Laser Printer
The feeder on the top of my d1150 will not accept paper it keeps jamming, i have been scanning alot of documents the last two days and now it will not scan anything, it keeps jamming
turn on/off, unplug, plug in, should reset configs.
take all the paper out, put half as much back in.
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above.
hope this helps and good luck
Apr 29, 2010 | Canon imageCLASS D1150 All-In-One Laser...
Hi our washing machine keeps displaying error code f12 and will not go on does anyone no what this means carolyn
F01 - Short circuit motor triac - Book a washing machine repair. F02 - Motor jammed tacho detached - Book a washing machine repair. F03 - Wash thermistor open/short circuit - Book a washing machine repair. F04 - Pressure switch jammed on empty - Book a washing machine repair. F05 - Pressure switch jammed on full - Book a washing machine repair. F06 - Program selector error - Book a washing machine repair. F07 - Heater relay stuck - Book a washing machine repair.  F08 - Heater relay cannot be activated - Book a washing machine repair.  F09 - Incompatible eeprom - Book a washing machine repair.  F10 - Pressure switch not sensing correctly - Book a washing machine repair.  F11 - Pump cannot be activated - Book a washing machine repair.  F12 - Communication error - Book a washing machine repair.  F13 - Dryer fan or dryer thermisotor faulty - Book a washing machine repair.  F14 - Dryer element faulty - Book a washing machine repair. F15 - Dryer element relay faulty - Book a washing machine repair.  H20 - Not fillings. Check tap, hose and inlet valves LOCKED - Check interlock - Book a washing machine repair.  Here is a list of fault codes. I hope this helps !
Nov 21, 2009 | Hotpoint Aquarius WD640 Front Load...
Carriage jam after following instructions to reboot
check if there is anything stuck on the rollers like put ur fingers in the machine and check with a flashlight
May 07, 2009 | HP PhotoSmart C4280 Laser Printer
Paper jam msg. in Canon mp530; doesn't appear to b a jam though
Jan 16, 2009 | Brother MFC-3240C All-In-One InkJet...
How to Clear carriage jam on HP PSC 1610 Printer? No obvious paper jam visible.
Dear it's the carriage jam error. so it mean that your carriage is jam not paper. so open the printer where you insert the cartridge. check whether it is jam or what . cartridge carrier is jam kindly turn off the printer and try to move the cartridge head by hand very gently and if seems to be stuck than check for anything which abort him to move freely so than might be anything like dust or else. when you get success in moving the head put some machine lubricant on the rod on which head moves and check it ok.
Dec 04, 2008 | HP Office Equipment & Supplies
Xerox 5837 with 08-310 Error
If you donot find paper in the machine check for a stuck actuator or a bad sensor.
Jun 03, 2008 | Xerox 5830 Copier
73 people viewed this question
Top Quartet gbc Office Equipment & Supplies Experts
Pie-man
Level 1 Expert
pantomac nv
pantomac nv
Level 1 Expert
Bill Boyd
Are you a Quartet gbc Office Equipment and Supply Expert? Answer questions, earn points and help others
