Question about GE DRSR483GD Gas Dryer
I have a brand new dryer and needed to reverse the door. One screw will not screw all the way into the pre drilled hole.
  • 42 Answers
Is the screw too long? Maybe a little oil on the screw and work it in and out going a little deeper each time.
Posted on Apr 08, 2011
    President:
  • 2,468 Answers
There is a, by trade name known as a "ready-clip/handy clip" inserted in behind the cover of the front door and it has become dis-lodged and now won't catch the door screw to let you tighten this single screw,remove the front panel and you can either find this clip or purchase a new clip
Reversing door
some can be many can't use your head and look at the hinges
May 11, 2015 | Freezers
I have a samsung microwave SMH8165St and the door handle broke, how can I change it?
Before install it you need to pre drill the screw hole one size bigger.
Then use clear silicone on base to help it hold to place better.
Factory uses a power drill . Do not use a power drill you bend the cpvc and crack it and you be in same spot again. (Hand Tools only)
Apr 26, 2015 | Samsung Microwave Ovens
Replace shower door
Hi
You did not mention any additional information about your problem except replacing shower door.However use basic hand tools to complete the job.
Try this following general steps :-
1. Remove the doors by lifting up on one door at a time and then pulling each out. The top of the door has rollers attached to it, and the rollers rest on the inside of the top rail of the frame. Set the doors aside.
2. With your drill, remove the two screws on each end of the top rail, located on the inside of the shower frame. Then lift off the top rail of the shower frame.
3. Use your box knife to cut the caulk on the side and bottom rails of the shower frame. Shower frames are caulked on the outside where they meet with the walls and floor of the shower.
4. Use your drill to remove the screws from the side rails. There will be two screws on each rail, securing it to the shower stall. Then, take the rails out. Remove the screws from the bottom rail and take it out.
5. Use your tape measure to measure the old side rails, top rail and bottom rail. With a pencil, mark the lengths on each new rail. Use your hacksaw to cut each rail. Hold a side rail in the exact location where the old rail was located. With your pencil, mark the screw holes on the shower wall. The new shower frame screw holes may not line up with the old shower frame screw holes. Use your drill and 3/16-inch drill bit to drill new holes if necessary. If the shower walls are ceramic, use the concrete drill bit. If the shower walls are fiberglass, use the multipurpose 3/16-inch drill bit.
6. Insert the 3/16-inch anchors into the holes that you drilled. Put the side rail into position and insert the screws into the holes. Use your drill and Phillips head drill bit to tighten the screws. Place the bottom rail into position and mark the holes. Drill new holes if necessary and install the anchors. Insert only one screw at the end where you installed the first side rail. Lift up the loose end of the bottom rail and slide the second side rail into place. Mark the holes. Remove the side rail and drill the new holes using the 3/16-inch drill bit. Insert the anchors and put the side rail back into place. Insert the screws and tighten with your drill using the Phillips head drill bit.
7. Set the top rail directly onto the side rails. In each end of the top rail, insert the two self-drilling screws until the top is secured to the sides. Insert the tube of clear caulk into the caulking gun. Cut the end off of the tube with your box knife. Caulk the side rails and the bottom rail to the shower walls on the outside of the shower. Re-hang the shower doors by lifting each door and placing the rollers on the inside of the top rail.
Also giving you some links from where you can find a detailed information regarding replacing shower doors.
http://www.diynetwork.com/how-to/how-to-replace-a-shower-door/index.html
http://www.thisoldhouse.com/toh/how-to/intro/0,,214441,00.html
Thanks for contacting fixya.com
Please do get back to us for further query.
Jan 20, 2012 | Home
Is it possible to reverse door swing on dryer? My daughter has a new Elite front load dryer that swings from left.
REVERSING DOOR SWING
Your dryer is designed so the door swing may be reversed at any time without additional parts. Conversion is accomplished by transferring hinges to the opposite side of the cabinet.
To change the direction of the door opening:
1. Open the dryer door. Remove the four hinge hole plugs from the left side of the door opening. Place nearby for future installation. NOTE: You may need a plastic knife to help pull out the plugs. Be careful not to scratch the paint.
2. Remove the four screws that secure the door hinges to the dryer front panel (see below). NOTE: Remove one screw from each of the two hinges first. Hold the door firmly before removing the last two screws.
3. Rotate the door 180° and reinstall the door hinges to the dryer front panel with the four screws.
4. Install the four hinge hole plugs in the open screw holes on the right side of the door opening.
Hope this helped Tim
Dec 01, 2010 | Kenmore Elite HE4 Electric Dryer
How do I reverse the door?
If you can reverse the door, you will find the screw holes on the other side of the unit, just like where the screws are on the side the door is on now, will be just like reversing the door on a refrigerator if it is set up for it hope this helps
Feb 18, 2010 | Frigidaire Electric Dryer
Change the door direction on Kenmore 600 dryer
hi there. this is an easy fix. just take a close look at the hinges and screws on the door. note the size of the screws and the type of screw [usually phillips].
Now look at the other side of the door and the frame and you will see little plastic caps. pry those off. those are the screw holes to allow you to reverse the door.
now just unscrew the door and the latch and reverse everything... enjoy.
Sep 09, 2009 | Dryers
How to install flush mount leds on a motorcycle
Take off existing mounted stock turn signals (unplug ground and live wire).  Plug new ground in from flush mounts as well as live. make sure wire plug is same size as pre-drilled hole in fairing. Otherwise it will not be flush of course. If the flush mounts purchased seem to need pre-drilled holes for a pair of screws mark them out and do so. Make sure to wrap and protect wire connections accordingly.
May 13, 2009 | 2007 Yamaha YZF-R6
Front door speakers
I just replaced mine on my 2002 Diamante LS yesterday. It really isn't that difficult. To get to the front door speaker you will need to remove the door trim panel. This is done by pulling out on the bottom part of the panel. I used a flathead screwdriver to help with the separation. Just be careful not to scratch anything.
There are 4 or 5 clips that lock the panel on to the door frame. After you have pulled the clips out you will want to lift up on the separated panel as it hangs on a rail adjacent to the window. Pull the panel out far enough to reach behind and disconnect the various wiring clips. They have quick disconnect fittings and come out easily. You will also need to disconnect the door interior light by rotating the base about a half turn to get it out of the removable panel.
Once you have removed the door panel you will have full access to the speaker frame mounting. It has a removable plastic frame that you screw the new speakers in to. It attaches to the door frame with 5 or 6 Phillips type screws. I found it easier to remove the mount and get it ready to accept my new speakers. I just srewed it back on before actually attaching the speakers.
While the dealer spec for door speakers on a Diamante is a 6 3/4" speaker, a 6 1/2" will work just fine if you have a drill to pre-drill new screw holes. Just line the new speaker up on the speaker mount, mark where the new holes should be and then go ahead and drill them. Make sure the drill bit isn't bigger the the screw. It is a machine type of a thread and is easy to self thread with a regular phillips screwdriver.
After you have the speaker mount ready to accept your new speaker you can go back to your car, screw the mount back on to the door frame. Next attach the two speaker wires to the back of the new speaker. White goes to the positive post. (You might need to change the fitting type to match the car wiring and the new speaker) You can get some quick connect friction fittings and put one on the end of each wire that attaches to the speaker. Walmart, Autozone, Radio Shack all have these as they are readily available.
With the speakers in place, just reverse you installation of the door panel. I found it was easier to roll the window down so I could hang the panel back on the channel. Line up the clips and the bottom of the door, push in and you will feel and hear them engage. Once you are sure they are lined up correctly, go ahead and give it a good push where each clip attaches to make sure its on tight.
All done, enjoy your new sound system.
Oct 02, 2008 | 2004 Mitsubishi Diamante
I would like to reverse the door on my dryer,the door needs to remain with the same side up,so the hinges need to be moved to the otherside of the door.There are not enough holes for the new placement of...
Are you sure your door is reversible?
Most dryer doors are, However if you have a window? it may not be reversible?
I would suggest taking the door completely apart, remembering how it came apart and then flipping it as needed and reinstalling everything. You should not have to drill any holes? For instance the Speed Queen dryer door will have the screws on the bottom now instead of the top.
Read your owner manual and installation manual, if you dont have those look on line most Manufactures have manuals on line for down load no charge.
May 26, 2008 | Whirlpool Dryers
GE DRSR483GD Gas Dryer Logo
97 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
Sal DeAngelo
Are you a GE Dryer Expert? Answer questions, earn points and help others
