Question about Garden
I have a karcher k5.55m. when turned on the motor works fine but when the water is turned on the motor start to churn on and off when the gun is actived it work but their is no real pressure . we have cleaned all the pipes and the gun. could it be the water pump which we have not accessed. have open the water hose checked the valeu that seens to be working ok and works ok without the gun on the pipe
  • 2,510 Answers
If you say that it works ok when the gun is removed from the hose, it seems to indicate that the gun has some restriction in it or is not opening fully, check the gun again. The pump is supposed to go into an by-pass mode when no demand is made from the gun and it will also surge if the supply to the inlet is not enough to supply the pump's requirement. If your machine has a pressure gauge (my WAP has) watch what that is doing while you are trying to spray. Some recommendations I have come across is replacing the control head on the pump, spares are readily available, and generally comments about the Karcher have not been too favourable. The Nilfisk is preferred far above the Karcher,
Posted on Apr 09, 2011
Have a karcher k7.85 electric power washer .it won't turn on, or let water flow through gun nozzle. Checked fuse,and water pressure. Both fine.gave one attempt to start when I pressed trigger, then...
your going to have to email the company directly so that you might get it replaced if you have warranty on the product here is the email address and phone number enquiries@karcher.co.uk & 01295 752 000
Aug 14, 2014 | Garden
Karcher K2.94 intermittent pumping and buzzing
try the machine with the lance removed from the gun.
buzzing is usually the noise made by the motor when it cant turn. if the pump start to pruduce pressure but the pressure builds up too high then the motor will stop turning... faulty lance or faulty spill valve (dump valve)
If you have a Karcher then you should always post your machines barcode.
The karcher barcode is on a silver sticker and is usually 15 digits long. Example 156987400000123 is actually model 1.569-874.0 and serial number 00123....
Aug 05, 2013 | Garden
Karcher K2.36 motor cut out and won't restart
Yes, the water should be turned on first but if it only ran for a minute or two it should be OK. Most late model pressure washers have an automatic shutoff when the trigger on the wand is released. Turn on the water and then the machine and then squeeze the trigger on the handle of the wand and the motor should start as soon as the air is cleared from the line by the flowing water (about 10 seconds). If the unit was put away wet last season you may need to clean the nozzle with a piece of wire too.
Apr 16, 2010 | Karcher Garden
Hello there.My Karcher pressure washer motor constantly runs with no pressure coming out of trigger gun.I have tried another gun with the same result.The motor should stop/start when you press gun.The...
The valve that admits more water to be compressed is stuck. It is likely the O-Rings on it need replacing. No water to the pump, no pressure!
The motor will stop when pressure is up to the designed pressure.
Oct 03, 2009 | Karcher Garden
Karcher K 3.86 electric. Was working fine and
It sounds like you have cracked part inside. Parts availability depends on were you live???
Sep 18, 2009 | Karcher K 2.25 R Electric Pressure Washer
Karcher G 3000 BH Engine Pumping Problem
This may not be a motor problem. It sounds like your pump is not working properly and the motor is just following the pump. First thing to do is check for leaks in the pump, wand hose, gun etc. It may also be a blown water seal inside the pump.
Aug 17, 2009 | Karcher 2500 PSI Pressure Washer
Karcher Power Washer that surges up and down with water pressure.
Before you start it up:
1. Disconnect the high pressure hose 2. Connect the water supply and turn on 3. Make sure water is flowing through the pump
Start the motor, run for about 10 seconds and then turn off.
Turn off the water supply, connect the high pressure hose, turn water back on, start the motor and away you go.
May 29, 2009 | Karcher 2500 PSI Pressure Washer
Karcher K 3.68 M operation
These units have pressure valves that automatically turn off the pump once the pressure is high enough. The pressure switches do fail and sometimes stick and act as you've described.
May 07, 2009 | Alfred Karcher K 5.93 M Electric Pressure...
Karcher electric press. wash. Hums when turned on then trips bre
Dear K_mccurdy,
I am assuming that your washer is single phase. A comon reason for humming is a faulty capacitor. This must be changed by a new one.
Now one must see why the capacitor got damaged. This could happen, when the gun is closed the machine starts and goes off again in short intervals. In this case a control valve, often called the Spill Valve, needs lubrication or replacement. I prefer to replace it. Even if the pump has no faults and you have a habbit of closing and opening the gun more than necessary...the capacitor will get damaged. It is also important that if you use soap or chemicals, always rinse with fresh water before storing away the washer. Also never store the washer with pressure still built up. Always release the gun, before storing. Well in your case it must be the capacitor. If the capacitor is OK or you have changed it....try the washer without load. This can be done by removing the gun. You can leave the water supply, for this has a cooling effect during this test. Things should work fine now. If not...then the electric motor must be checked. But I repeat...the most common fault for humming is a faulty capacitor.
Regards,
Fulltech.
May 06, 2009 | Karcher PSI Electric Pressure Washer
Karcher 211 - no motor action
Dear Tigger82 (also montaver2000),
This explaination is relavent to various Karcher models, especialy your model. When you are using the machine with the gun open....presurised water comes out of the lance. When you close the gun, the machine stops. This happens by means of a Spill Valve or often called the Control Valve. When the gun is closed, this spill valve cotracts with built up pressure and at the same time works on a miro switch which cuts the electricity....and thus stops the electric motor. Now in many cases when the gun is again opened, this spill valve sticks and keeps the electric circuit closed.
In all cases you must open the cover, and locate this spill valve. Sometimes it is easy to see a micro switch on it. If you remove the miro switch from the spill valve the motor will for sure turn.
Now the spill valve gets stuck for many reasons. One of the reasons is that you leave the machine under pressure for a long time and even store away the machine with pressure still in the system. A spill valve also gets stuck due to detergent. I sometimes service the spill valve and lubricate with special solicon grease. But the best way is to change the spill valve with a new one. So in a few words, the spill valve is stuck and leaving the microswitch off. So the electric motor cannot turn. One final hint is that sometimes the spill valve is difficult to remove. So all one has to do is attach water supply and switch on the pump. With the pressure produced the spill valve will be pushed out. In my oponion this job must be done by a person who knows what he is doing. Carefull that you have safety electrical breakers. See that you have safety shoes, safety gloves and eye protection.
Regards,
Fulltech.
Apr 29, 2009 | Karcher K2.26 Electric Power Washer
Garden Logo
104 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
