Question about Bosch Washing Machines
Hi how do I get my Bosch v454 washing machine to spin and drain water? It is on setting 'd'
SOURCE: washing machine not spinning or draining water
I have the same washer, WT-R801. Does the machine stop all together when the spin cycle arrives?, if so check the pump on the drain. Mine was burnt out. Its available for $61.00 delivered from Adelaide. Steve.
Posted on Mar 31, 2008
  • 130 Answers
SOURCE: BOSCH WASHING MACHINE WONT SPIN, FLASHING RED SPIN LIGHT
check the pump clean out. sounds like something is jammed in the pump
Posted on Feb 16, 2009
SOURCE: IFB Bosch washing machine.
I have an IFB washing maching it does not spin dry the clothes any solution
Posted on Jul 25, 2009
barkencoa
  • 3463 Answers
SOURCE: my Bosch classic 1200 express washing machine wont drain or spin
Possibly a blocked filter or pump.
Ths filter should be at the bottom right front of washer, sometimes behind a removeable cover at the bottom of washer.
To clean it, unscrew anti-clockwise, remove and clean.
Posted on Dec 09, 2009
SOURCE: Bosch wfd2473 washing machine wont drain or spin
I have a bosch wfd 2473 washing machine...wont drain,I have had this problem before and resolved it by removing drain/filter plug...normally a button or hair clip....but this time there are no objects blocking.I am guessing the drain pump is faulty and needs replacing...?????
Posted on Feb 17, 2010
The machine won't pump water or spin and makes nasty noise. When I turn the drum by hand there is no noise and feels normal.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jul 08, 2011 | Bosch Washing Machines
Won't spin water from clothing
heatman101
Apr 17, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
I have a Bosch SHU3036UC dishwasher. While sitting idle - during the day or over night, it fills up with fresh water. I shut off the water supply last night and this morning it was dry. Any ideas?
heatman101
Apr 12, 2011 | Bosch SHU3036UC Dishwasher
WIll not drain water.
heatman101
Apr 02, 2011 | Bosch Classixx WFL 2066 Front Load Washer
The water will not drain out of the machine
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Sep 10, 2010 | Bosch Nexxt 800 WFMC8401UC
Bosch washing machine will not fill, spin, drain..has power and water to machine...perhaps circuit board?
If it won't fill it may not spin or drain unless the water level switch is bypassed. I would check the water valve & the water level switch and tube from level switch to tub must be air tight no holes.
The water level switch must kick in to agitate. I'm not sure on Bosch but some work like this..
Jun 09, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Apr 05, 2009 | Bosch WFL 2063 Front Load Washer
Bosch 2460 washime machine. washed, will not drain r spin
i think thew buzz you hear maybe something stuck in the pump impellor. remove filter and check
Jul 23, 2008 | Bosch Logixx WFT 2806 Front Load...
Washing Machines Logo
215 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
