Question about Aurora Electronics AS1015CD Cross-Cut Shredder
Hi, my Aurora AS1002MSB is jammed and it will only go in reverse. Is there any way to fix it?
  • 6,993 Answers
Move the power switch to AUTO (l) position and depress the manual forward button for five seconds to clear paper blockage. Make sure the paper is engaging sensor located in the center of the shredder opening.
Good luck....
Posted on Apr 09, 2011
  • Shirley millar
    Shirley millar Apr 17, 2014
    Have not got a manual button!!
2001 oldsmobile aurora right rear window will not go up or down, you can hear the motor running and how do you get the door panel off. there are no screws showing.
the rear windows on the aurora move on the guides using cables and they jam up in the runners to fix this yuo will need to replace the window regulator.
Mar 11, 2011 | 2001 Oldsmobile Aurora
Jammed in Auto, but works fine in reverse. How to unjam?
Continue to alternate between auto and reverse a number of times. Try to shred narrower pieces of paper at opposite ends to see if it can trigger the auto trigger wire. All else fails, carefully take the shredding part apart and you may find a hugh paper jam underneath.
Sep 02, 2010 | Aurora Electronics AS662C Shredder
Our Aurora AS1712X paper shredder is jammed in a couple of places with paper so badly that we cannot free the jam and the tooth wheels cannot turn freely. Is there an easy way to clear the jam?
Try running the shredder in reverse and oiling the blades. More help with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder up and running, it looks like you might have to pick up a new paper shredder. Paper shredders can be pretty cheap though, great guide to cheap paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
May 20, 2010 | Aurora Electronics AS882C (Cross-Cut)...
JAMMED SHREDDER
if you have reverse, run reverse.
if you don't have reverse, you will have to disassemble the drive shaft/cutters and clear manually
Apr 05, 2010 | Aurora Electronics AS662C Shredder
The motor on my shredder will only run in reverse
You need to remove the top section, make sure it's unplugged, and use a tweezers or very narrow needlenose pliers, and pluck out any paper chunks, and use canned air to blow out the paper dust. Reverse only means the chopper thinks there is paper jammed inside and will only run in reverse to clear the jam.
Jan 31, 2010 | Aurora Electronics AS662C Shredder
Aurora Papaer Shredder circuit board problem?
It just sounds like a paper dust problem.
use canned air to completely clean all sensore.
Oct 23, 2009 | Office Equipment & Supplies
I have a as501x-ms that jammed. all the paper has
Have you tried running it in reverse?
Also, unplug it and make sure that ALL of the paper has been removed from the shredding teeth before you try it in forward mode again.
Jul 09, 2009 | Aurora Global AS501X-MS Shredder
Shedder one works
This is an issue with the paper feed sensor which may be a electronic eye or a mechanical switch if it is mecanical you may just have to jiggle the switch a few times, occasionally paper may get stuck behind it not letting it activate. If it is electronic you have bad sensors or bad pc board and you'll have to contact the manufacturer for further info.
Mar 07, 2008 | Aurora Global AS501X-MS Shredder
Aurora AS1512X Cross Cut Shredder
Sounds like the cutter is jammed. Do you ever feed staples or clips in it? Will it reverse? If not, the power borad is burned out.
Jul 24, 2007 | Cross Aurora 15 Sheet Cut Shredder -...
Aurora Electronics AS1015CD Cross-Cut Shredder Logo
480 people viewed this question
Top Aurora Electronics Office Equipment & Supplies Experts
k24674
Jim Keysor
ka4iup
ka4iup
Are you an Aurora Electronics Office Equipment and Supply Expert? Answer questions, earn points and help others
