Question about Hayward SAND FILTER, PRO SERIES
I have a sand filter when I back flush and return to filter in 4-5 hr. it needs it again. I chang sand last year it at 16psi for a bit then starts to go up.I used baquseal never had this befor. thanks Wayne
  • 640 Answers
When you say that your filter needs to be backwashed again, what exactly is making you come to that conclussion? Are you getting a reading on your pressure gauge or are you experiencing problems, such as loss of pressure and problems with your return lines? If it is just a reading, it is probably you pressure gauge going bad. This happens very often in these pool filters.
Posted on Apr 20, 2011
Once in awhile my pump will start returning the water at a very high pressure on and off like if its clogged making my pool shake very bad. Is there a solution to my problem?
sounds as if your getting an high back pressure from your sand filter , more often back flushes will help this from happening , also installing a prefilter on suction hose will keep large debris from entering sand filter and blinding it off , this pre filter can be purchased or made from a simple pair of used ladys stocking , but all will need to be checked often for clogging off
Jun 27, 2015 | INTEX Sand Filter Pump
Not filtering
too many chemicals will cloud contact the company website or did you maybe its the water change the water
Feb 28, 2017 | Pentair Tagelus TA 60D Filter
My Hayward sand filter is pumping sand back into pool
Normally when I run into a problem with this type of filter like the one you described there is a problem with the pick ups in the bottom of the filter unit. If you did several back flushes and now when you set it back to pump it is essentially back flushing back into the pool the problem is in your controller and it is not closing off like it is supposed to. as far as how much sand to put back int he filter I don't have that information as it is specific to the pump/filter size. A pool supply center would most likely be able to answer that question when you purchase your sand. That filter sand is not the same as sand box sand and should only be purchased from a pool supply center. The same supply center that you get your filter sand from would also be able to advise on the valve problem.
Nov 27, 2011 | Hayward SAND FILTER, PRO SERIES
Sand being returned to the pool after vacumming through filter
This could be caused by several things. . After back flushing,did you rinse? Turned pump off, moved selector to rinse, and allowed to run until clear water was observed in the sight glass? If you continue to see the plume of particles, and it never stops, then you probably do have a problem. Your multiport valve gasket could be leaking by. Be sure you keep handle down when moving valve, and the gasket will last longer. You may have a broken, lateral (little fingers at bottom of the filter return piping. This would usually allow sand to flush out of the filter and it would be all the time. The "O" ring where the multiport valve seals to the down pipe could be leaking, letting the dirty incoming water mix with clean outgoing. Have you "cleaned" your filter lately? This is where you add a chemical to flush materials from top of sand pack? You can download a manual with troubleshooting instructions from www.haywardnet.com Enter your exact model number
Nov 06, 2010 | Hayward SAND FILTER, PRO SERIES
After you backwash the filter do you have to put in a powder through the skimmer?
If you're using a sand filter you don't use diatomite like you do on a DE filter. You should 1. Turn pump off. 2. Move valve to backwash. 3. Allow to back-flush till water is clear (check sight glass). 4 Turn pump off again. 5 Move valve to rinse 6. Turn pump on till water is clear again.7 Turn pump off, return valve to filter. 8 Turn pump back on again. No power is added to a sand filter. There are some materials to "clean" your sand perhaps twice a year, follow the manufacturer's directions for this.
Jul 04, 2010 | Hayward SAND FILTER, PRO SERIES
We have a hayward sand filter for our 24ft round above ground pool. We changed the sand this season and replaced the 8 fingers @ the bottom of the filter tube. After doing so and turning the pump on it...
its more likley to be too much sand in it and its just cloged up,,,take the sand out and run the pump out of the pool in a big tub of water to flush it out and also to back flush it,,,if its working ok after that fill it up with the right type of sand but only a little at a time,,,,
i dont think the phosphates are a problem its not being filterd thats the problem this needs sorting out fast or the pool will fill up with algy and green slim
Jun 20, 2010 | Hayward SAND FILTER, PRO SERIES
Pressure doesn't last & seems to blow out cloudy, dingy water
if you are on city treated water, sand will last aprox. 7 years, if on well water typically 3 - 5 years. so yes, could be a sand issue. also, double check that the there is no water trickling out the backwash / drain outlet of the filter, this could indicate that the diverter valve gasket (spider gasket) could be worn and cause sand from the filter to flow to the pool. this is a common problem if you move the position selector often with the pump still running - the pump should always be off when moving the handle. good luck!
Jun 01, 2010 | Hayward SAND FILTER, PRO SERIES
I have a 85 elcamino that has been a project of mine for the last 2 years. My step brother and I don't get along and he put sand down the dipstick tube of the auto trans. What are my options, rebuild,...
Turbo 350 or turbo400 not that expensive to rebuild,maybe parts 60 to 80 dollars,try changing the fluid,if this fixes the problem,have a rapid lube place flush the transmission system.The filter change is the first step,the filter should have stopped the sand from getting into the transmission.But it will have stopped up the filter.
Apr 14, 2010 | 1985 Chevrolet El Camino
When does rack go bad my van is 4 and half years old less than 28,000 miles
Steering Rack? Have to change /flush oil every few years. Should last ten or more years but some don't. Flush system and install an inline filter on return line, before you install rebuilt rack. Instructions to same, come in box.
Mar 11, 2010 | 2005 Dodge Caravan
Dirt comes back thriugh the return when I vacuum
if your pool is clean its not sand when we vac customers pools we put vac in pool and put vac hose over pool take a wet vac put on end of hose outside pool keep it on only long enough to get water flowing save your filter and water if you want to vac through skimmer make sure you are in filter mode good luck
Jul 16, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward SAND FILTER, PRO SERIES Logo
66 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
