Got a problem with my house central heater, the unit is inside the house, don't know the brand , but the problem is that when I turn it on to warm up the house, it comes on for a few minutes then before reaching the desired tempeture, it turns off, sometimes I can see the igniter gloss bright, but the gas valve does not open, I alredy replaced the wall thermostat but that did not solve the problem, any ideas? Thank you.
  • dklmn66 Apr 09, 2011
    when the flame goes off, the fan still works, so, when the heater goes off , without reaching the set tempeture it's only the flame that turns off, not the fan ,which still blows , but not heat, this heater does not have a pilot ,it comes on with an igniter, wich glitters bright orange to ignite the flame when the gas valve opens, now, when I first turn it on, it comes on, the igniter comes on, then the gas valve opens and the flame comes on , the fan comes on and starts blowing warm to hot air thrugout the house( 2 story house) then after just a couple of minutes the flame goes off, but the fan keeps working, and sometimes I can see the igniter trying to lit the flame, but the gas valve won't open, Ialready replaced the air filter, wich was very bad, installed a new filter , and also replaced the thermostat, but still with the same problem, (just FYI ,also ran a self test on the main board (electronic board) and everything seem to be ok).
    thanks.
    President:
  • 1,654 Answers
I have a couple of ideas, but they will probably involve getting a service tech to look at these. First the gas valve may be bad, thats why it is not openeing after the igniter is coming on. Second the control board that controls the gas valve may be bad and not calling for gas when it should. At least part of this is working, you get the igniter and the blower but no gas, that makes me believe the gas valve would be the main suspect here. I assume you have good gas service and it has not been interupted. If it is working a little sometimes, I am not sure by your statement, then this model may even have a thermocouple involved for flame temperature and this may be bad. I would have to know much more detail on the make and model along with the gas valve manufacture to give you any more on this. But If this were me I suspect the gas valve and a tech would have to read the valve with a meter to determin if it is bad.
If you have a volt ohm meter you can see if your getting any voltage in DC current to the gas valve, that would tell me if the board is bad.
Posted on Apr 09, 2011
  • Dcramer531
    Dcramer531 Apr 09, 2011
    Ok, I did not see the previous answers or added information till now, so with that being said. The problem seems to lie with the pressure switch that tells the main board that the combustion fan is running, or the flame temp sensor that I had mentioned. I still need more info along the lines of the manufacture so I can see how they have things set up, but I think I narrowed it down to these 2 items.
  • 794 Answers
Hidklmn66,
I have a general troubleshooting for most central heater issues. These includes checking on the parts that may cause the problem that you are getting. Before doing any checking with your machine please remember your safety.
1.On your main service panel check out if there's a blown fuse or tripped circuit breaker. Replace any blown fuse or if the breaker is tripped reset it, depending on the type of your system.
2. Inspect the air filter. There must be proper air flow and any obstruction can cause your system to work less efficiently.Replace a dirty air filter with a new one or clean a reusable air filter.
3. Look at the compressor unit outside. There might be surrounding vegetation that obstructs the quality of air flow. Sometimes there are foreign objects that has fallen into the unit and affects the ability of fan to rotate. Remove any object obstructing the fan. Do not attempt to straighten out a bent blade because even minor damage to the blade can adversely affect performance. If the fan has damaged blades, replace the whole fan.
4.Make sure that the fan is not frozen as well. Try moving the fan by hand, if it's difficult to move, lubricate it. You have a user manual where you can the instruction how to do it and what type of lubricant needed.
5. Check the tension on the fan belt. Check if it's too tight or too loose. Pressing down on the belt should result in the belt giving between 1/2 inch and 3/4 inch in slack.
6.Is there any damage to the fan belt like tears or cracking? If there is, then fan belt needs replacement.
7. Pilot light should be lit on a gas system. If it won't stay lit, you have to turn the adjustment screw so that the flame burns strongly enough to stay lit. If the pilot light won't come on at all, turn off the power to the heater and clean out the pilot orifices with a toothpick.
Hope it helps.
Thank you for using Fixya.
Posted on Apr 08, 2011
  • 2,382 Answers
Hi, the unit will not run and perform optimally if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
If you are using this inside your home with central air running do you have to vent it to an outside window?
Yes, it must be vented to the outside, even if you're using central AC, too. The reason being is if you don't vent it to the outside, the hot air and humidity that normally goes thru the duct and out the window, will stay in the house and your Central AC will have to run longer and harder to overcome this rise in heat and humidity. In addition, the room that the portable AC is in, will get extremely hot & humid.
Hope this helped you. Please let me know. Thanks.
Jun 15, 2011 | Haier CPN12XH9 Portable Air Conditioner
I have 3 central ac units for my house. 1 for the upstairs and 1 for the west side of house and 1 for the east side of house. just had a very cold night and the east side of house vents smelled like...
To make sure that there is not a problem with your blower test it on cool. if it runs good. then start the heater on auto and it should be okay. but still supervise the operation for about 5 mins. if you still smell something burning . then call an AC Technician for help.
Albert Saavedra
AC Technician
Fort Worth/Dallas TX
773-627-8766
Dec 28, 2010 | Heating & Cooling
I just move in to this house, and I figure out that the gas consumption is to hight. The gas bill this month is close to $200.00. I want to know if that is the average cost to keep my small house warm....?
well depending which country you live in and what price your consumption is per kilowatt. And are you running the thermostat at low comfortable temperature instaed of high temperatur set points that just waste money also has the unit been sized right for area its heating if not it will run more longer than it needs in some cases the heater never turns off becuase it can't beat the cold as it is to small for area, look there could be a many a factors to why it coast this much but it also comes down to a well insulated house as well, when it comes to heating its just common sense to make sure your house will retain heat and hold out the cold firstly before making sure heater is good enough any heater is good enough as long as your house can hold the heat in and with central heating with gas it should only take about an hour to warm the house any longer and it maybe undersized so run heater for about half an hour if it doesn't seem to feel warmer around you it could be heater to small but if heater sized right and insulated right through and you run about 18 or 20 degrees centigrade (australin temp you'll have to convert fernhieght if u.s.), if you try trhis your coast should come down, alot of people also turn up temperature to get more heat well you don't get more heat it just runs longer than it needs too which will coast you more, whatever temperature you set it will always run the same temperature out of air supply, so another money saver is over night and while your out turn down about 6 or 7 degrees then turn back up when your up or home, i know people who run on L.P.G (propane bottle gas depending where you are again) and spent about $300 to $400 a month and if your on a gas reticulation ((natural gas)we call town gas here as its only where they have run pipes here to peoples house so five minutes out of city and its the more expensive bottled gas **** as i can't get town gas and its very cheap apparently), its cheaper again on natural gas! so there are many factors involved on central heating it pays when getting these systems to research and find a installer that knows what he's talking about than a cowboy i've replaced about 6 this year due to undersizing by other companies that obviously are only after money, just about to finish my last one on monday and already told client that they will be happy no ifs or butts i know they will be happy as i have sized correctly and re done most ducting under floor as whoever installed had no idea about air flow and how important it is on central heating! i would get an central heating engineer to look at it for you (someone form a place that didn't install it they like to lie and blame everything else except the obvious that they have ripped you off and deffinatly don't want to give anything back, but honestly $200 sounds slightly high but probably not really that much higher than norm. do you have friends with same sort of heater if you do ask them how much they pay a month and compare
Dec 15, 2010 | Dayton Gas Furnace Heater
I have a central heating and air unit. The unit
sunds like the fan bearings have seized up or u have a bad fan capacitor take a screwdriver and spin ith blade to where the air would be coming out the top and if it startswhen u spin it u need a fan capacitor
Feb 23, 2010 | Coleman Propane Forced Air Heater...
My central heating unit is in the attic of my 2bd/2bth house. I don't know its age. It's a gas unit, but doesn't have a constant pilot flame. Rather, the pilot is ignited electronically. The problem is...
You don't mention make or model so here is my guess as to how to thinkout the trouble of what ever is in your attic.
For some reason, your heater is mis-firing. Normally, I would expect 3 to 5 such events at which time the heater goes out on safety. The heater knows it is on safety but you don't until it gets cold in your house. When you turn the power off, wait the 30 seconds, turn it back on, the heater no longer knows it is on safety (memory cleared) so it fires. Your heater continues to fire until ? at which time it starts counting again to 3 or some number. At the max mis-fire number - it goes out on safety again ... repeat - turn it off, wait 30 seconds, turn it back on - no memory and so forth.
Do you have a service contract or regular service man? Might be time to find one.
Thanks for your question at FixYa.com
Jan 05, 2010 | Heating & Cooling
I am attempting to turn on the home central gas heater for the first time this year. It is controlled by a honeywell self ignition model number sv9541. I follow the instructions on the front panel and...
Check to make sure the gas valve is opened. I've turned mine off for the summer months; when I went to use the heater for the first time...I realized I had turned the gas off.
Nov 17, 2009 | Honeywell Programmable Thermostat Heater
TRANE 1984 Home A/C Where are How to Clean Coils inside House
the best thing to do it with airhandler shut down at breaker. 1st soften dirt and crud with 409 or different brand. 2nd take a wire brush and clean in up and down motion following the fins on coil.3rd rinse with spray bottle . this is the best you can do without coil removal.
Jul 02, 2009 | Heating & Cooling
20 year old central a/c heater not working
Check your thermostat and mode selector setting, thermostat setting should be set at warmer and mode selector setting should be at low heat or hight this is applicable for manual unit.
If it is a remote control just set the remote to heat mode.
sample only
Jan 02, 2008 | GE Quiet-Aire Ductless Split System Air...
Heating & Cooling Logo
20 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
